Introduction: Resurgent-class Star Destroyer
Hi guys. What we're making today is the Resurgent-class Star Destroyer. The only one of these ships ever made, the Finalizer is twice as long as a Imperial-class Destroyer. It's got a fairly flat shape (compared to the Imperial), which was fun to recreate with K'Nex. It appears in Star Wars VII: The Force Awakens. From it, Ren, Hux and Phasma have a clear vantage point of Starkiller Base. This ship was constructed illegally in a secret shipyard. It goes against all peace treaty regulations enacted and enforced by the New Republic.
Step 1: Parts Count
Let's get started. Please note that the build calls for a green connector, while I use a 3D-grey connector. That is located on the top layer, right next to the light grey connector. Thanks.
Rods:
Green-15
White-33
Blue-4
Purple Flexirod-1
Y-clips-14
Connectors:
Light Grey-3
Orange-5
Red-2
Green-1
Yellow-22*
White-2
Misc:
Blue spacer-4
(Black) ball joint-7
(Black) socket joint-1
* 1. One of the pieces is broken: That is neither intentional nor necessary.
2.This build will damage 4 of your yellow connectors: Be prepared to lose those for most other builds.
Step 2: The Base
Step 3: The Bridge
Hey, guys. Hope you enjoyed the build. See you next time.
5 Comments
Nice! I like the super star destroyer a little more ;)
Are you sure 4 yellow connectors will be damaged? It doesn't look like they are being stressed :)
If you connect the y-clips and ball joints, it strains the connection points on the yellow connectors. Enough time and tension will bend the connectors to the point where they can't hold a rod rigid.
KNEX ball - kball - Instructables
This link shows a ball made up of strictly connectors. The level of tension bends the connectors out of place.
I see it now :) doesn't look too bad
I seem to think it's rough. The way it's bent, makes it unable to hold a rod without it essentially falling out. However, it does stay in for the most part. I guess it isn't too bad, really.
looks good!
