Resurrect a Polaroid Land Camera
 by randofo
Featured
The Polaroid Land Camera was named after its inventor, Edwin Land. It introduced the world to the idea of instant photography and, in some regard, paved the way for the modern era of instant digital gratification.
This is a complete guide for getting started with the Polaroid Land Camera. It goes over cheaply acquiring the camera and film, upgrading the battery, basic functionality, timing exposures, photo tips, and using a flash.
It may take a little while to get the hang of it, but you will quickly learn it is a ton of fun. There is a sense of anticipation as the photo develops that you just don't get from digital photography.
Step 1: Find a Camera
This Instructable deals largely with 100 series Land Cameras. This includes all cameras with a model number between 100 and 455. Countless quantities of these cameras were manufactured and sold between 1963 and 1976.
You can still find them at thrift stores, garage sales, estate sales, antique stores, and online (think Ebay).
Your best bet is to find one at a garage or estate sale. Although antique cameras sometimes tend to fetch a little bit of money, most people think you can't buy Polaroid film anymore and will offload these cameras on the cheap.
The current market for Land Cameras is good because no one wants to buy them and everyone wants to be rid of them. This makes your job of acquiring one all the easier.
I got this whole camera kit for $5, and with the warning, "You know, you can't get film for those anymore."
Step 2: Get film
While it is true that Polaroid stopped making film for their camera, it is also true that other companies historically have made instant film and continue to do so.
For instance, Fujifilm makes 4.25" x 3.25" instant film ("pack film") for Polaroid Land Cameras and have announced that they currently have no plans to stop manufacturing it.
This means that not only is instant film available, but it is also much more affordable than the remaining Polaroid Film (and don't even get me started on the prices of the Impossible Project).
While most respectable camera stores should carry it, you can also buy it online from B&H Photo and Video or Calumet.
Film stock available for pack film Polaroid cameras include:
FP-100B (black and white)
FP-100C (color)
FP-3000C (black and white)
Note that the product numbers correlate directly to ISO film speed.
Step 3: The camera and its accessories
The camera I found was a Polaroid 250 Land Camera. This is one of the higher-end models and boasts a Zeiss-Ikon rangefinder, all-metal body, and 3-element glass lens. It was manufactured between 1967 and 1969.
Along with the camera I got:
- the #322 Polaroid Camera Case
- an instruction manual
- a Cold-Clip
- the #128 development timergg
- the #268 flashbulb unit
- (x5) M3 flashbulbs
- obsolete print ordering cards
I will go more into detail about all of these accessories later (except the ordering cards).
Step 4: The battery
The battery used by this land camera is the #531 4.5V alkaline battery. This battery is expensive and kind of a pain to get a hold of.
Instead, I highly recommend converting the camera to work on AAA batteries (see the next 5 steps).
To find out what type of battery your land camera needs, check out the Land List.
Keep in mind that every A-series battery is 1.5V and this voltage adds up when you put batteries in series (such as in a battery holder). So, if you need a 4.5V battery, that will be three AAA batteries and a 3V battery would translate to two AAA batteries.
Step 5: Battery upgrade
To upgrade the battery pack you will need:
- 4 - AAA battery holder (3V cameras require a 2 - AAA holder)
- Few inches of wire
- Soldering setup
- Wire strippers
- Phillips screwdriver
- Electrical tape
Step 6: The new battery pack
We are going to need to convert the battery holder to only use three AAA batteries. The reason we do this, as opposed to getting a three-battery holder, is that the 4-battery holder is actually more compact and fits better into the battery compartment.
That said, we are going to bypass one of the battery slots by soldering a wire to the spring on one side to the plate on the other. This will create a 4-battery holder that only takes three batteries (and thus be the necessary 4.5V).
Step 7: Out with the old
Remove the old battery if it is still in there. Then, remove the battery holder by unscrewing it.
Finally, break away any plastic tabs that were supporting the old battery holder.
Be careful not to cut the battery connector wires.
Step 8: In with the new
Trim away the ground (black) connector, leaving as much wire intact as possible. Strip a little of this wire's jacket away to expose the conductive core. Solder the black wire from the camera together with the black wire from the battery holder.
Repeat this process with the white wire and the red wire.
When you are done, insulate each solder joint separately with electrical tape.
Step 9: Power
Install the new AAA batteries and close up the battery compartment. These batteries should last a long time. You will take hundreds of pictures before you need to worry about replacing them.
Step 10: Remove the cover
Removing the camera cover is simple.
First lift the top up over the viewfinder and rotate it forwards to expose the front of the camera.
Next, to detach it completely, press up on the silver tab keeping the cover connected to the bottom of the camera.
Step 11: Inspect and clean the rollers
Before you load the film for the first time, you want to inspect the rollers on the inside of the camera that are used to disperse the developer.
First, open the back door of the camera all the way. There should be a switch on the bottom right-hand side to release the door.
You should then see the rollers right next to the door where the film is pulled out of. The rollers can be released for inspection by pulling the red metal tab located on their side.
Make certain that they are not badly scratched or dented. If they are, they will need to be replaced as this will cause the photo to come out corrupted and/or the film to jam and leak into the camera.
If they are merely dirty, this is a bit easier to deal with. They will simply need to be cleaned with a soft damp rag. Do not use any solvents or cleaning products when doing this.
When you are certain the rollers are smooth and clean, then you are ready to move on.
Step 12: Load the film
Loading the film is easy.
Simply drop the pack in such that the notched side is facing up and the black tab is sticking over the side of the camera. The pack should be lying flatly in place.
Before you close the case, make certain that the white tabs are not stuck under the film pack.
Make sure the black tab is coming out of the small slot on the side and then close the case by pressing firmly on the top and bottom.
Pull on the black tab until it is entirely out of the camera. This should advance the white tab labeled "1" through the small slot. This indicates that the film was loaded right and the first picture is ready to go.
Step 13: Film speed settings
Setting film speed is accomplished by adjusting the round knob below the lens on the front of the camera.
If you are working with 3000 speed film, you will want to set this to 3000.
If you are working with 100 speed film, you will want to set it to 75. This will let in a little too much light for the film speed, but can be compensated for by adjusting the aperture to be darker.
Step 14: Lighting selector
The lighting selector specifies to the camera what type of film is being used and how large the aperture should be.
It is important to set the Lighting Selector correctly.
Unless you are using 3000 speed film outdoors or with a flash, you will always want the 75,150, and 300 Speed column to "Bright Sun, Dull Day and Also Flash" (this will also set the 3000 speed column to "Indoors without flash").
Step 15: Adjust the exposure settings
The camera's aperture can be adjusted by turning the ring around the lens. If you want to darken the film, move the dot towards "Darken." It goes to follow that you would move the dot towards "Lighten" if you want to lighten the film.
I recommend setting the aperture to neutral until you know how your pictures are coming out.
Step 17: Timing the film
Timing the film is critical when working with pack film. The development time for each particular film is specified on a chart on the packaging. This chart will give the proper development time based on ambient temperature of your environment.
If you have a timer, set it according to the development time specified on the film box.
For instance, at 86 degrees, FP-100C has a 75 second development time, at 68 degrees it drops to 120, and at 50 degrees, it recommends 270.
It is generally recommended that you don't shoot below 60 degrees using color film, or if you do, use a Cold-Clip (more on that later).
Also to note is that black and white film (FP-100B and FP-3000B) have considerably shorter development time than color film.
Lastly, if you are shooting below 60 degrees you will want to move the aperture dial slightly towards lighten and if shooting over 80 degrees, you might want to consider moving it a notch towards darken.
Step 18: Focus on the subject
Look through the viewfinder and push/pull the focusing bar back and forth until your subject is in focus.
As a general rule, if your subject is between 3-1/2 to 5 feet set it to the portrait. If the subject is between 5 and 10 feet, set it to the group setting. If it is greater than 10 feet, set it to landscape.
Step 19: Arm the shutter
Push down on the shutter lever until it locks in a "down" position. The shutter is now armed and ready to take a picture.
Step 20: Take a picture
To take a picture, press down on the big red button labeled "2". This will release the shutter.
Step 21: Expose the film
To start exposing the film, first pull firmly on the white numbered tab until it is completely out of the camera.
This should then expose the picture tab from the long camera slot.
Hold the camera horizontally with your left hand and pull the film tab firmly and at a moderate speed with your right hand. Pulling it should take no more than a second or two. Make certain that you pull the film straight out of the camera. If you pull it at an angle, you risk damaging the picture and getting gunk on the rollers (which can damage additional pictures). Additionally, if you pull it too fast, you will get white specks all over your image. Next time, pull it slower.
Once the picture has passed through the rollers and is outside of the camera, development has started. Immediately start the timer if you have one. If you don't, start counting in your head or aloud.
When the development time is up, peel apart the development sheet from the image sheet. Be careful not to get any of the developer chemicals on your hand. If you happen to, wash your hands off with water.
Throw away the development sheet and let the film dry off for a few minutes before you handle it. As general practice, it is good to avoid touching the picture's surface even when dry.
Step 22: The Cold-Clip for color film (optional)
As the temperature goes down, the developer chemicals slow down and development time increases (especially in color film).
If the temperature drops below 60 degrees and you are using color film, you will want to use the Cold Clip.
The Cold Clip is basically a metal clip that you keep in a inner pocket to keep it warm.
When you are developing a color picture in a cold location (or you have been in a cold location for a while and have recently moved to a warmer spot), you will want to use the cold clip to warm up the photograph as it develops.
Basically, pull the photo out of the camera as you normally would then, within 10 seconds, fold it inside of the cold clip with the tab sticking out the top. Then, simply, place it back in your pocket and wait about 60-90 seconds. Actual development time depends on how hot you are. I'll leave this up to you to decide.
*Note: The Cold-Clip should never be used with black and white film.
Step 23: Compress the bellows
Press down on the bar labeled "Press to close".
Simultaneously push the front panel of the camera back towards the body of the camera until it is locked into place.
Step 24: Common photo errors and solutions
White image - This probably means that you are shooting with 3000 speed film at too slow of a film speed. Try setting it to 3000 speed and see if this corrects the problem.
Black image - This means no light got to the film. The typical cause for this is that the shutter did not open. Perhaps the camera batteries have died. Try replacing them and see if that helps. If this does not help, check to make sure the battery pack connection to the camera has not come loose. If still no luck, set the film speed to 75 and the environment type to indoors. Trigger the shutter and listen for it click. If it does not click, then the shutter is broken and needs to be repaired.
White specks - You have pulled the picture out of the camera too fast. Slow down.
Too dark - The aperture needs to be rotated towards lighten.
Too light - The aperture needs to be rotated towards darken.
Undeveloped U-Shape - This is caused by pulling the film too slowly, dirt on the rollers, or the white tab being folded over the film pack. Next time pull the film faster and make sure the white tabs are not pushed into the camera (but don't open the film compartment!). If it persists, clean the rollers when the pack of film is used up.
Muddy print - You did not let the film develop long enough.
Undeveloped edge - The film was pulled out of the camera at an angle and the developer was not spread evenly. Next time pull the film straight out of the camera.
Edges very dark - This is caused when shooting in bright sunlight and using 3000 speed film with the lighting selector set to "Indoors without flash." Simply change this to "Outdoors or flash."
Step 25: Flash photography
The Land Camera is an m-sync camera and was designed to be used with M3 flash bulbs. It even has a state of the art (for 1967) electronic light meter for sensing the flash and timing the shutter for optimal exposure.
Unlike later Polaroid cameras, it was not at all designed to be used with electronic flashes. However, with a little bit of an ingenuity, you can get it to work with manual electronic flashes.
Step 26: Flash bulbs
The flash unit for this camera uses M3 flash bulbs and it is recommended that you use the clear tinted M3 bulbs and not the blue tinted M3B bulbs, as the #268 flash unit already has a blue plastic shield and this will under-expose the film. However, you can compensate for this by setting the aperture towards lighten.
Other flash bulbs should also fit into the #268 flash unit, such as M5 and M2 bulbs. Keep in mind that they produce different amounts amount of light than M3 bulbs and you should adjust the aperture to compensate.
All of that said, no one manufactures flash bulbs anymore, but you can buy them online or find them at garage / estate sales. Unlike Polaroid film, you don't need to worry about flash bulbs expiring. However, you do want to check old flash bulbs for dents or scratches because surface damage will make it more likely to break when you use it.
Keep in mind that flash bulbs are one-time use only because the filament burns out after the first exposure. So, every time you want to take a flash picture, you will need a new bulb.
Needing a new obsolete bulb for every picture is what makes electronic flashes so appealing, but they have their own set of problems (which will be addressed a little later).
Step 27: Replace the flash battery
The #268 flash unit uses a single AA battery.
To replace the battery, remove the two screws from the bottom and take off the lid.
Pull out the old battery, stick in the new one, and close it back up.
Step 28: Using a flash bulb
Make certain your flash unit has the plastic cover still intact. This is important because flash bulbs (especially old flash bulbs) have a tendency to burst and you wouldn't want to send glass flying everywhere. If the cover is broken, consider covering the bulb with a clear sheet of plexiglass. Do not use the flashbulb if there is not a solid cover.
Attach the flash bulb unit to the camera by hooking it to the top of the camera and pressing the button in to extend the the gripping edge. When pressed down atop the camera, release the button and the gripping edge will hold it in place.
Plug in the PC adapter to the front panel of the camera.
Fold down the protective cover and insert an M3 bulb into the socket. Fold the protective cover back up.
Set the lighting selector appropriately for flash photography based on your film speed (this is the yellow selector boxes on the top of the front panel of the camera).
Once everything is set, take a picture as you normally would.
When you are done, press the red button on the flash to release the bulb from the socket. Check to make sure that the bulb hasn't broken, then open the protective cover, and then throw the bulb away (if it is broken, obviously be more careful).
Unplug the PC cord when you are done using the flash. If it is left plugged in, all subsequent pictures will come out over-exposed.
Step 29: Electronic flashes
Electronic flashes don't particularly work well (or at all) with Polaroid Land Cameras. The reason for this is that the camera has a 0.26 second (26 millisecond) delay between the flash being triggered and the shutter opening. This delay accounts for the time it takes for an m-series flash bulb to illuminate. This is called m-sync.
However, electronic flashes do not have delay. This means that as soon as you press the photo button, the flash goes off, and then, 0.26 seconds later the shutter opens. By the time the shutter has opened, the flash has already began to decay (or left town entirely).
This is particularly a problem if you are using the specialty PC adapter designed to work with the camera's flash unit. The PC adapter for Land Cameras have a special plastic tab which push a cover inside of the camera out of the way to expose a special photo meter. This is used by the camera for metering the intensity of the flash, and adjusting the exposure of your picture. If you use this option and flash goes off right away, the shutter will remain open too long because it is waiting for the flash of light that has already occurred. Obviously, this will over-expose the picture.
The two ways to get around this is to:
1) Not use the special PC adapter that activates the light meter and just use the electronic flash as-is. This might work with some flashes, but is not a perfect solution, as the lighting from the flash may be unevenly distributed throughout the picture.
2) Modify the flash to have a slight delay to account for the delay in the shutter. You can then use the specialized PC adapter. In my opinion, this is the best solution.
Step 30: Electronic flash m-sync hack
If you are going to want to properly use an electronic flash with a Land Camera, you will not to hack the flash to be compatible with m-sync.
A full guide to doing this can be found in this Instructable.
Step 31: Electronic flash mount
Land Cameras do not have any sort of native electronic flash mount.
You can build an electronic flash mount as specified in this Instructable.
Step 32: Using the electronic flash
To use the electronic flash, mount it to the camera as you would the flash bulb unit.
Make sure that the cable from the flash is connected to the mounting base by the 3/32" cable, and plug the special Polaroid adapter cable into the camera.
Turn on the electronic flash and take a picture as you normally would.
When you are done, don't forget to unplug the flash from the camera, or this will keep the light meter and/or flash active and ruin further pictures.
boneskully says: Apr 16, 2013. 1:45 PM
This was helpful thanks. I put mine up on Facebook under The Camera Hut.
lauriematthews says: Mar 17, 2013. 2:03 PM
I was in the process of converting my Polaroid 240 from the 4.5V battery to three AAA batteries and realized that the white wire is severed and is no longer attached to the inside of the camera battery compartment. Is this repairable?
avatar_i says: Oct 14, 2011. 5:09 PM
i have several of those Polaroid Land Cameras, and you can still get most of the original batteries from BATTERIES PLUS, so check before you do a conversion. The originals took a battery w/connectors like the 9V transistor battery, so those are very easy to replace.
BUT: Make sure you verify WHICH Polaroid film the camera took, BEFORE you buy it, even if for just a few dollars.
Early Polaroid Land Cameras took ROLL film, which has not been made since about 1970 +/-. The roll film cameras cannot be made to take any modern film without spending a LOT of money on it....
Later models took 'Pack' film, which Polaroid actually stopped making in the USA several [6?] years ago, but which was still made overseas by several companies- England & Japan, among others.
Fuji made the Polaroid 'Pro Vivid', which is still marketed in USA by Fuji. It is the same film under the new Fuji label, FP-10C [colour]. We call it 'FUJI-ROID'. Readiy available at most high end camera stores, and onlne. I think there is also a B&W, and they still make it in the standard film pack & 4"x5" sizes.
** DO NOT BUY OUT OF DATE POLARIOD FILM FROM ANY SOURCE, AS THE CHEMICAL PACK IN THE FILM CRYSTALIZED SOON AFTER THE EXPIRATION DATE AND IT IS ALMOST ALWAYS USELESS/UNUSEABLE**
jakebaldwin in reply to avatar_iJul 3, 2012. 9:55 PM
I *just* used instant pack film that was dated to expire in 2007, and it worked fine. It was a pack of "Fuji-roid" FP-100C. Maybe I'm misinterpreting your warning. Do you mean all instant films that fit Polaroids, or film made by Polaroid?
avatar_i in reply to jakebaldwinJul 4, 2012. 10:01 AM
I am surprised the Fuji FP-100 lasted 4.5~5 years; someone must have kept it refrigerated at a very stable temperature! Fantastic Luck!!!
No, ONLY 'POLAROID' marked film packs, as Polaroid stopped selling film many- perhaps 7~8?- years ago, and it will have gone bad.
If the film was frozen, the chemical packs would have crystallized, and if not refrigerated- which only extended the expiration for about one to three years- the chemical pack would have gone bad about 5 years ago.
Anything marked "FUJI' should be O.K., maybe another year if refrigerated, but NEVER freeze it, as the chemical pack goes bad sooner.
jakebaldwin says: Jul 3, 2012. 10:03 PM
I learned only after spending an entire nine-out-of-ten exposures on my FP-100C pack that Fujifilm manufactures packs entirely in plastic. Polaroid packs had metal casings that could withstand the force of the tough springs inside my Land 450. The plastic in the Fuji pack bent under the pressure, and made it impossible to remove the exposure units. The big tip I found online was to open the back just slightly, relieving the pressure on the film. Unfortunately, I consistently opened the back too far, and the film missed the rollers. I managed to get one developed picture out of the ten in the pack. I found out that it was alright to remove the springs entirely, so I did. Unfortunately, I'm out of film to test with.
Here's a very helpful link for those of you with the affected camera models.
uhclem says: Oct 13, 2011. 8:22 AM
This is a good alternative to paying $$$ for a Fuji Instax. I hope I can snag a nice used Polaroid camera before the local used camera store gets hip to what's going on here.
uhclem in reply to uhclemNov 22, 2011. 9:32 AM
Auuugh! Too late! The manual exposure packfilm cameras are expensive (on eBay). The auto exposure cameras are still cheap.
I found a Polaroid 210 locally that was cheap and in excellent condition. It needed a new battery, of course. A cr123 lithium fits perfectly. I soldered the leads directly to the battery. The drain on the battery is such it will probably die from exceeding the shelf life than be worn out by the meter.
I find the exposure is very easily dominated by bright spots. If there's a patch of sun or a bright lamp you really have to lighten the picture or it will come out too dark. Otherwise the quality is excellent.
I only wish I could use the ASA 3000 film with the f/8 aperture and still get a correct exposure. Keep in mind that on most packfilm cameras, setting the speed to 3000 means using f/45 - there is no gain in exposure vs 75 or 100/
I recently saw the "king" of packfilm cameras - the Mamiya 600. Interchangeable lenses, viewfinder focusing, can shoot 120 film etc... costs more than $600.
jakebaldwin in reply to uhclemJul 3, 2012. 9:51 PM
You soldered the leads directly to the battery?! Shame!
neuropol says: Oct 10, 2011. 7:13 PM
Love Land cameras. Thanks for the great instructable. I'll be using that battery hack.
neuropol in reply to neuropolNov 19, 2011. 9:48 AM
Update. I've now done the battery mod on a couple cameras. The first was a 360, which sadly appears to have some major issues. The second is a 450 which works great.
One issue with the 360 and 450, and any other model with an electronic timer bult in. These models take two batteries of the same type, one for the timer and the other for the exposure control. Performing this mod will disable the timer. What I haven't tried yet is using a 4 cell holder and separating it into two, two cell holders to be able to still use the timer. Next time.
The parts and batteries needed to do the mod are less than the cost of one original spec battery. A no brainer imo.
nnichraith says: Nov 18, 2011. 6:53 AM
Do you think that these fujifilm instants would be compatble with Polarois spectra ?
randofo (author) in reply to nnichraithNov 18, 2011. 7:54 AM
Not really sure. There is this:
http://www.instructables.com/id/Packtasticor-How-to-use-100-Series-Film-in-an-/
...which is not quite right, but demonstrates that you can sort of use it in other Polaroid series film cameras.
kosherbacon says: Oct 17, 2011. 2:40 PM
Awesome instructable!
I'm a photo student, and love using old cameras to take picture. I'm SO excited to try this out, best of all, the camera is cheap on ebay.
Thank you SO much!
_Billa_ says: Oct 15, 2011. 4:26 PM
Amazing instructable. The final effect is pretty cool.
CHARLESCRANFORD says: Oct 10, 2011. 3:47 PM
Great Instructable. Makes me think, "I am not that old." but I do remember being excited when my dad said I could use a whole pack of film to take any photos I wanted. It took two days for me to take eight photos. It was winter, so I had to "develop" the film under my armpit. A far cry from taking three hundred photos without hardly thinking about composition, lighting, focus.
Thanks for the flashback,
Charles
vincent7520 in reply to CHARLESCRANFORDOct 14, 2011. 7:05 AM
You're right Charles,
Digital photography is great but we tend to rely on quantity with the hope that well get quality with a few of the takes : this goes against common sense and the need to progress and get proficiency with a medium…
I must be about the same age age as you and I guess this instrusctable also says a lot about the pace we should give to our projects and our lives.
vincent7520 says: Oct 14, 2011. 6:59 AM
FANTASTIC INSTRUCTABLE !!!…
Everything is here, crystal clear, comprehensive and no fuss.
Makes me wish to go Polaroid again.
Moreover is is very useful as this type of equipment is due to vanish and we need such testimonials as yours to revive our memories and leave as 20th century technology legacy to future generations.
Thanks a lot.
juniejuniejune says: Oct 14, 2011. 2:21 AM
On a film photography video podcast, I found out that you can actually save the negative from the instant film. From there you can scan it in and do whatever digital people do. If you want.
So don't throw it away! You can always use it later.
beaubolique says: Oct 13, 2011. 9:27 AM
Resurrecting memories of working at the camera store "back in the day"...
Those numbers on the film packs actually correspond to the ISO (ASA) film speed, rather than shutter speed. Yes, that is an ISO 3000 B&W film. Great fun at night with the goblins...
crazyg says: Oct 13, 2011. 7:48 AM
fuji make the film , great heads up!! i will have to reconcider what i do with my cu5
AdamVanMeter says: Oct 13, 2011. 7:41 AM
I think I have a working polaroid land gathering dust in my storage room - time to brush it off and get to picture taking!
-excellent- instructable! You really covered all the bases.
dsmith68 says: Oct 13, 2011. 7:37 AM
As a kid I was fascinated with photography and had many different cameras but my favorite was always my Polaroid camera. I had several of them w/ all the accessories including my last the SX-70. The old Land cameras would allow a person to double expose the film and make "ghost" pictures...lol So much fun and so many memories...
peterbryenton says: Oct 13, 2011. 7:25 AM
Very well written and illustrated, thank you.
Most flashbulbs contain a chemical dot to show they are undamaged. This little indicator should be blue if good. Pink means it's gone bad and will be unlikely to fire properly.
marcintosh says: Oct 10, 2011. 10:06 PM
Yes the battery info is great and I"m sure I'll be working on that shortly as I have a PLC 360 gathering dust- as an aside Polaroid had (as far as I've been told by those that should know) the very first Electronic Flash and used it on the 360.
Fuji is still making this film! I had given up on buying film for it. I had no idea this was in production. I can't thank you enough for showing this.
I can't wait to get to work on this - Thank you muchly!
knife141 says: Oct 10, 2011. 4:14 PM
Very nice job! Thanks for posting this.
mikeasaurus says: Oct 10, 2011. 3:57 PM
Awesome job, Randy!
I love the vintage effect of the old Polaroids, and the battery hack shown is genius.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
