iImage Information
I have two cordless drills. One that was dumped at work and another one that I bought at a flea market. Both had their motors burnt and smell like so. So I tried something radical: replace the dc motor. But were to find one alike?
Step 1Secrets of the elders!
iImage Information
I will reveal my secrets of material sourcing. There is a guy that lives in the city's dump (very common in Mexico) and has an army of people looking thru junk to find stuff tha might be worth money. So on sundays, he deploys his load of junk on the road, so costumers go through all of it to find useful stuff. I like the old saying "one man's junk is another's treasure".
Ya just got'a like junk to share the hobby...Much Thanks !
At the top of the battery case there are four or six long screws. Remove them and the top comes off. There are 15 NICD (or sometimes NImh) batteries inside. Gently remove them. There are a couple in the long top part that goes into the drill or charger. You can leave them in, but disconnect them. Find and identify the + and - wires that go to the contacts and bring them out (solder extensions if necessary).
Go to Radio Shack and get three 4-cell AA adapters. Also get three clips with wires (or you can just solder them together) to connect in series. Load up the adapters with 12 AA Alkaline batteries. You will be able to just fit them into the cavity where the original batteries were located. You still have 18Volts. Put the top back on the case and plug it into the drill. DO NOT EVER PLUG IT INTO THE CHARGER AGAIN EVER. IF YOU ARE DARING, YOU MIGHT TRY IT OUTSIDE AND UNDER A METAL PAIL, BUT IT WILL PROBABLY EXPLODE.
The drill should operate well, and the batteries will not self-discharge. If it slows down over time just open up the battery case and replace the batteries. Why go to this trouble? A replacement or rebuilt rechargeable battery may cost much more than the original drill was worth. I was quoted $80.00. A 16-pack of AA will cost around $9.00. The adapters will be another $10.00 or so. NOTE: If it is one of the 19.2V types (16 rechargeables) you can remove and squeeze in another AA battery in the plug. An extra .3V shouldn't hurt anything.
BTW: There were only a couple of unrechargeable batteries in the pack, so i salvaged the rest to re-battery some very old Solar Lamps.
Next I'd suggest, see if the junk man has a camera upgrade for you.
Thanks for another great idea.
