Step 5Repairing the gas tank
Using a drill bit as a hand reamer, I unplugged the galleys in the petcock, then soaked it in carb cleaner.
For the inside of the tank, I first put a handful of nuts an bolts in it along with about a quart of degreaser, plugged the inlet and outlet, then rocked the tank back and forth and up & down for about 30 minutes to loosen the crud inside. Next I used a DIY commercial cleaning coating process which entailed soaking the inside of the tank in a weak acid solution for 8 hours, then using a neutralizer, then a permanent coating.
After taking care of the tank's insides, I then began work on the part that "shows." I used bondo to fill the four dents, carefully sanding and feathering the filler to the lines of the tank. Then I applied primer, then paint.
While the finaly coat was drying, I used a small knife blade to scrape away the rust from the tank's logo, then touched up the paint on the logo with an artist's brush.
Before reattaching the logo, I applied stair tread (sort of like a rough, rubbery tape) to the sides of the tank for decoration, then screwed the logo back on each side.
I realize this is not exactly how the original looked, but remember -- this is a resurrection, not a restoration!
did you de-rusted your tank? I had the same problem. My tank was more than 40 years old. no paint, just rust. I did electrolysis on it. It looks awsome!!
You should try that if you haven't already. It really works wonders, and no fumes or harsh chemicals.
Here's the before and after. I just rinsed it with a hose.
yes i am restoreing a 71 honda rebel i am haveing trouble getting the tank to stop leaking.i have used marine tex,to stop all the leaks but new ones pop back up . there is a coating for the inside but i don't know what it is ,i can't afford a hunderd dollar coating.i got the rest going great. i will show it to you after it is finished. it stayed in the rain for over a year so i had some rust and other problems.like i had to use screen wire to cover some big hole in the tank. now it looks great but ............any advise be nice........
