loading
Step 2: Sometimes things get bent
This clock was found in an antique shop in New Mexico, and I paid substantially less than what the clock was actually worth, because it would not run.  I noticed that there was a small dent in the wood of the case (indicating the clock had been dropped).  What I found wrong was that when the clock had been dropped, the thin brass mount where the pendulum attached had been bent slightly.  Straightening this mount fixed the clock.  The pendulum on this clock, by the way, is hidden in the back of the clock.
I love old clocks & watches! Never tried working on them yet, just collect them to save them from the landfill...Hope to have a collection as nice as yours. Awesome instructable, and thank you for the pics of all those beauties!
Glad you enjoyed the Instructable. As you probably could tell from many of the photos, I have a soft spot for old alarm clocks. These old clocks are fairly easy to find, and in most cases they aren't expensive, particularly when they no longer work! I have found that most of them are fixable. Thanks for your comment.
Thank you! This is very good advise.
WD40 doesn't fix anything, particularly in a clock. Never, never, ever, ever use WD40 for ANYTHING, much less a delicate thing like a clock movement. End. Of. Story.
It is very popular to "trash" WD40 -- my favorite is when people say "WD40 attracts dirt." It is true that airborne particles can combine with a surface coated with WD40, just like the same particles can combine with a surface covered with a very fine clock oil. The internet is filled with "don't use WD40" outcries. Unfortunately, most are just repeating what they heard or read somewhere else. There are six clocks in my office today keeping perfect time. All were lubricated with WD40 TEN YEARS AGO!! End. Of. Story.
It's not &quot;popular to trash WD40&quot; amongst most people that I know, nor &quot;on the Internet&quot;. My statement is based on much personal experience in many different applications. The only thing that I've continuously found it useful for is removing sticky label gum from new dishes or other non-porous surfaces. Even then, it's followed by soap and water to remove the oily residue. <br><br>I can't argue with your ten-years-no-problems claim, but I will firmly stand by my imperative to never recommend WD40 for much anything, let alone a clock movement.
I recently bought this gilbert alarm clock at an antique mall, it runs and the alarm works. A little issue i have with it, time can be set but the hour hand slipped and its where it is at and its supposed to say six fifteen and it was like that when i first wound it up.<br>I took the movement out and window off and gently moved the hand. Moved as any old clock hand should and the hour hand being attached to the shaft slipped.<br>I dont know when it was made
I've come to this article late in the day. I am a qualified watchmaker so I hope you feel my comments are valid - it is not my intention to offend anyone. <br> <br>Professional clock makers have a love-hate relationship with the &quot;WD40 mob&quot;. Hate because any decent horologist knows that treating a clock in this way does little more than hasten it's decline. Love? because you generate so much work for the professionals once the poor clock has ground to a halt again. <br> <br>A spray of WD40 will neither clean a clock, nor lubricate it properly. Clocks are not lubricated with light oils, they are lubricated with the heaviest oil you can get away with without compromising the motion and only at the bearings and other selected places - the teeth on the wheels must run dry or they wear rapidly. The only time WD40 would ever be used would be when struggling to dismantle an old, seized mechanism; then it would be immediately cleaned. Proper cleaning requires the complete disassembly of the movement. <br> <br>A spray of WD40 may get an old clock moving, but what you have applied is not a lubricant, but a cutting oil which mixes with the grit and dust and old dried oil to create a slurry that wears the pivots and their bearing holes with frightening speed. Once a pivot hole has been enlarged enough, no amount of WD40 will ever get that clock moving again. It will require the attentions of a professional to re-bush the clock and clean up the heavily scored pivots. Not a cheap job. <br> <br>My speciality is watches. The use of the correct oil in the correct place is critical not only for the function of a watch, but also its longevity. The gear teeth must run dry or they will wear like cheese. The pivots must have lubricant or they will score and the lubricant must be applied in such a way that it does not immediately creep away. If I open the back of a watch and the distinctive smell of WD40 wafts in my direction, I will either politely give it back to the owner, or, if pressed, double the price for looking at it because I know there is going to be trouble. <br> <br>If you don't know how to work on a watch, let me simply say that spraying WD40 in the back is as inappropriate as putting petrol through a diesel engine and your watch will grind to a halt again shortly afterwards. <br> <br>It's great to get old things going and I'm not trying to be a snobby professional sneering at the amateur - there are a great many gifted amateurs. But, if you are have a clock or watch of great sentimental, or actual value, please do yourself a favour and give it to someone who knows what they are doing if you don't. <br> <br>Knife141 is clearly an intelligent and resourceful guy, but this article could have been written deliberately to upset clock repairers, it contains so much bad practice and inaccurate information. Persuading an old clock to limp into action is not the same as caring for it.
<p>This is a very nicely written comment and greatly appreciated. It was very nice of you to make the effort to provide helpful information. You could have kept silent and let people keep making mistakes and ruining their precious time pieces. Thank you so much for such a tactful and informative post. </p>
<p>This is a vintage Howard Miller clock. A clock repairman told me it was past it's prime for repair. Can you give me any suggestions? I had it ticking for several hours after hanging the pendulum. Any help is appreciated.</p>
<p>I have been fixing clocks and watches for a long time. My grandfather taught me when I was young. I love the old clocks they have a soul. I recently gotten one in that's electric and I don't get many electric type this one is nice. Mid century modern I would say, I'm looking around for a gear for it. All the gears are metal except for one. It's like a ceramic material. I'm going to go onto the NWACA and ask around. Love the site keep on ticking...</p>
<p>We recently found an old vintage clock in my grandfather's attic! We have been trying to clean it up and get it working again but with no luck. I think that looking into restoration might be a smart thing to do. Do you have any tips for us or places that would be helpful? Thanks!</p><p>&lt;a href='http://www.johnagillclockrepair.com/Clock-Repair-Restoration-Lansdale-PA.html' &gt;&lt;/a&gt;</p>
<p>I wish I knew how to take off the clock hands without destroying them.</p>
<p>I have a E Ingraham mantel clock Manufactured in Bristol Ct 1889, that will not stay running the pendulum stops. my husband thinks it was over wound, it has 2 key holes in the face one winds the other does not, it also has a alarm that winds separately, we want to sell it, so I need to get it in working condition.</p>
The clock could have one or more of many issues -- can't diagnose without seeing it. One thing, however, its problem is not that it is overwound, which is a common misconception. Clocks were made to be wound fully. It could be dirty, it could need lubrication, it could be sitting unlevel, it could be out-of-adjustment, or could have a broken or rusted spring. Probably need to have a clock repairman look at it.
<p>Not a quarter movement--a quartz movement. Apologies.</p>
Hold the shaft with a pair of pliers, then try to unscrew. Some of these unscrew to the right, and some to the left. Try both. Good luck!
<p>Hello. I have a Bakelite Seth Thomas electric kitchen clock. It has stopped. I want to take the electric motor out and put a quarter movement back in but I can't get the time set knob, which protrudes through the top of the case, to come off. Any suggestions for me? Thank you so much. I'm a clock-a zoid, and I'm glad to have found this site.</p>
<p>Hi have a question, my clock temporarly works only if i repeatedly tap on it,<br>what can I do to solve this?</p><p>p.s. the clock is a chairman Mao wood case alarm clock<br><a href="http://www.theeastisred.com/clocks.htm" rel="nofollow">http://www.theeastisred.com/clocks.htm</a></p>
Probably needs cleaning &amp; lubrication.
<p>since i know close to nothing in terms of cleaning and lubrication, what should i do?</p>
<p>You probably should take it to a clock repairman.</p>
<p>I made a comment before but somehow it didn't get through I guess. This is an old Owl clock advertising piece for &quot;Wise Potato Chips&quot; the glass is cracked so it was dropped at some point. When I plug it in it just hums but none of the hands move. Any ideas how to proceed and how would I be able to fix the glass (Plastic) or find a replacement?</p>
Where the glass is curved, I've had success using plastic that I heat and form over something (like an old globe) to get the curve. Clear plastic food containers are a good source for the plastic. As for the hum without movement in the hands, that's usually a sign that the motor lube has hardened. If it's a telechron movement, sometimes you can drill a tiny hole in the back housing and either squirt a little wd-40 in it, or use a really thin penetrating oil to free it up. Good luck!
<p>I have a old advertising clock for &quot;Wise Potato Chips&quot; The glass is cracked so I think it was dropped at some point. When I plug it in, it hums but nothing moves. Any suggestions on how I should proceed? It has a Lanshire movement but I can't find a # on it anywhere.</p>
<p>Why do you have to shake wind up clocks to start,Is ther something binding?</p>
<p>Well, I enjoyed reading about your work with old clocks. I love old clocks, and have an old general electric mantle clock that would be nice to have working again - but I can't even figure out how to remove the main knob on the back, picture two - I did take it to a clock maker, who is super busy, and didn't want to put in the effort it would take. That's why I thought I'd ask you; do you know how to open this old fellow? If it isn't fixable, I could take off the electric cord and just see how pretty it is. It's been in the family a long time. The knob on the back (for adjusting the time) just won't come out for love nor money. Thanks much in advance, I appreciate any comments you might give me about this. Linda</p>
Without seeing a photo, it's a bit difficult to say. However, you can remove a lot of these knobs by holding the shaft with a pair of needle-nose pliers and unscrewing the knob using another pair of pliers (some unscrew clockwise, some counter-clockwise). Good luck, and thanks for your kind words.
hi!!! are you still here??? I have an old alarm clock and it was working until this morning when I wound it and it just didn't work anymore, I opened it and saw that the mainspring is fully wound but it won't unwind. Could it be just rust? the spring is bearly new! <br>thank you! <br>
If the mainspring is still good, it's probably needs lubrication. Use a very light oil, and apply just a tiny bit beginning to the escapement wheel pivots. Again, use a very light oil (not household oil). If you don't have any light oil, try something like a silicone based penetrating oil. After oiling the escapement wheel, you might have to start it rotating manually the first time. Once it is running, put a tiny bit of oil on all the other pivot points. Go easy on the oil. Hope this helps.
My grandfather gave me an Elgin wind-up pocket watch a few weeks ago that would only run for a little while then stop. After researching for a while I found this instructable today and tried spraying a little WD-40 on the balance wheel. Now the little 128 year-old watch is ticking happily alongside my Spartus Alarm clock. Thank you for this great Instructable!!!
Glad to hear you got your watch running. I've also had some luck cleaning &amp; lubricating old pocket watches with cigarette lighter fluid. Sounds a bit odd, but it helps to dissolve solidified oil and provide a bit of thin lubrication. Thanks for your comment!
I have heard in the old days they used to use kerosene (sp?) to clean watches. Never tried it myself. I don't know how useful it would be as a lubricant.
In the old days, they cleaned clocks with benzene which is not available anymore since it causes cancer. Watches were cleaned a hundred years ago in a solution of potassium cyanide. Many a watchmaker was found dead at his bench from accidentally inhaling the fumes. They oiled the watches with porpoise jaw oil. It stinks to high heaven when it goes rancid in an old watch.
I worked cleaning watchs for several years and using WD-40 isn't the best thing to use. It can dry out and become sticky which allows bits of dirt stick to parts and can then abrade parts. Its not a good idea to run a pocket watch without its being cleaned and oiled with a watch compatible oil. A pocket watch spring is generally powerful enough to run with jewels dry which causes wear on the staffs of the various wheels and can lead to them needing to be replaced.
Great Article......I love clocks and watches. When I was working, and making good money I was a member of the NAWCC...National Watch and Clock Collectors Association. I highly reccomeand giving them a try. I left when we had financial problems, and could not justify getting magazines, etc. Now that I am retiree I shall look into joining them, again. They have a magazine, and an advertising publication called &quot;The Mart&quot;, where you can buy clocks, parts, tools, services, etc. You can also borrow books from their library to learn about clocks... After I lost good paying jobs, I sold off my small collection of clocks and watches. My wife bought me about 10 in- expensive mechanical clocks, for our anniversary's. I thought I would have to completely tear them down to get them going. Now, after reading your tips, I shall take a look at them and see if I can get them going at little or no cost. <br>The NAWCC that I mentioned above, has a national museum in Washington DC. They have chapters all over the USA, so you can join the national chapter by mail, then join a local chapter...go to meetings,...shows and see a lot of collectors and clocks.!......I would like to add a tip.......many times there is ONE gear that has worn its pivot hole and is out of alignment that prevents the mechanism from working. If you can find this gear, push it back in center and stake it with a small screw in the brass plate, and a repair bushing. You can buy an in expensive kit of repair bushings and screws from many clock repair companies on line. Don't forget to check out local hobby stores who may have the kit and the tools the author suggests. <br>Thanks again for a great article. Monday I am going to examine all the non working clocks I have........................... and resume my hobby !!!!!
Thank you for the comment -- and the tip! I have made my own repair bushings in similar fashion a couple of times in the past to repair a worn pivot hole. Its a great way to salvage an old clock that just needs a little bit of help! I'll have to check out the NAWCC. Thanks again for the comment.
Lately, I've seen some suppliers are actually selling replacement rotors even telechron style units that are compatible with old clocks, but they run like $25 but you can get them cheaper if you buy in bulk. For example see clockworks.com
A great instructable!
Thanks for the kind words!
Great Instructable! I love old geared clocks and this is a great guide for fixing them. Thanks!
Be wary of WD40 and electric clocks, as WD40 is very flammable and can be explosive in a confined space.
I've been collecting and rejuvenating old clocks for a couple of years now. I have over 70 clocks that date anywhere from the 1820's through the 1970's. Almost all mechanical and some electrics. Using lighter fluid, kerosene, WD-40,etc. dissolves old thick or hardened lubricants and only temporarily lubricate pivots. Once the old oil and junk is dissolved and removed from the pivots and the solvent is evaporated, almost any clock will run just fine being dry. It's just wears faster. A good clock oil should be used for lubing the works, and only a tiny amount is necessary. Too much oil is actually worse than too little oil since it collects dirt and debris which acts like an abrasive on the bearing surfaces. Maybe I'll do some Instructables in the future dealing with cleaning and lubing clocks. It's good to save these cool machines!
WD40 is NOT a lubricant. its a water displacer and contact cleaner. It will do more harm than good on a watch. I have heard it can triple the cost of having a watch repaired.
I have heard that, too. But in all my years of fixing old clocks, that has not been my experience. In my testing of WD40 I've found that it floats above water (like most lubricants) rather than displacing it. That's why it is not effective in preventing rust (again, based on first-hand testing). It does make for a really good light lubricant, though, and attracts dirt less than regular light oils.
I absolutely love wd-40 and was surprised to see so many repair experts take a strong stand against its use with clockwork mechanisms. Many feel it will provide a temporary fix and will initially seem like a GREAT idea but will eventually (within a year or two) form a shellac that will coat the mechanism causing damage and undue wear.
Yes, I've heard the same stories, but again that has not been my experience. I have clocks that have been running for a decade that were lubricated with wd-40, and they're still ticking away. Plus, I've yet to see a clock repairman that doesn't keep a can of wd-40 handy. I think the &quot;don't use wd-40&quot; legends are similar to the &quot;don't use Armour All&quot; ones in the automotive world.
I certainly believe that wd-40 in the right hands can do wonders, have you ever used wd-40 to repair a pocket watch/wristwatch?<br><br><br>
No, I've only worked on a couple of watches -- they're too small for my old hands and eyes. Wd-40 is too hard to control on a mechanism that small. I have had success lubing a couple of pocket watches with a tiny amount of cigarette lighter fluid, though. I've. Heard of others using kerosene, but have never tried it myself. It may be the same thing, though.
I have an older pocket ben &quot;dollar watch&quot; pocket watch and I am thinking about trying a small amount of lighter fluid, it has a shroud covering the majority of the movement and only the balance wheel is visible when you pop the back off , I have been told taking it apart to clean would be suicide for a beginner like me. Theres no way I can justify the price of a professional cleaning since the watch is not an heirloom, just a neat garage sale find that i would love to have working.
About This Instructable
127,204views
69favorites
License:
Bio: I enjoy taking a pile of junk and making something unusual out of it. I like wheeled vehicles, and currently own two motorcycles, two electric ... More »
More by knife141:Chromebox Computer In Old Case Easy mp3 amplifier Gas Nozzle Lamp
Add instructable to:
