Retooth Oscillating Blades / Sharpen Oscillating Blades
Published
Introduction: Retooth Oscillating Blades / Sharpen Oscillating Blades
Oscillating blades, they're expensive, it doesn't take them long to wear out.
When they're worn out, take your grinder and cut some new teeth on the blade. That's it. Then the blade will cut well again. As you see I made big triangle teeth. The little ones don't last long.
I use this tool all the time in woodworking to correct little mistakes. Oscillating tools are not a replacement really for any other tool but once you realize the convenience and things you can do with them that you can't do easily with any other power tool, the oscillating tool becomes an indispensable addition to your tools.
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    keets
    6 months ago
    Smart idea! Indeed the blades are worn out to fast for the price.
    I will try this next time.
    Does me remember, I do have a machine to grinding machine to grind chainsawchains. Maybe it's possible to make an adapter so the teeth are equal.
