Step 15Adding Speaker Outputs
Clean holes can be drilled in wood with Forstner-style bits. These are definitely recommended if the hole will be visible. Standard drill bits will often tear and splinter wood upon entering and exiting regardless of how careful you are!
Once everything's bolted in place, the filtering capacitors that were originally soldered across the outputs of the T-amp are soldered across the binding post outputs.
comments
Add Comment
Mr. Rig It
says:
Add Comment
