3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Retro Hi-Fi Project
Step 3Eloooongate Cables
Eloooongate Cables
I decided to elongate the ribbon cables connecting the display using left over IDE hard drive cabling. Luckily the spacing of the wires were the same (0.100" wire-to-wire). Other common sizes are available . . . check Digikey if you need another spacing.
I tried various ways to strip the ends of the wire, but finally ended up carefully slicing everything with an xacto knife, then pulling. Solder a wire on each end, then do all the wires in between them to help with keeping things aligned. Once everything was soldered up, I encased the connections with a non-conductive epoxy to prevent shorts if the wire were to get kinked.
The second picture shows just how much extension I needed!
1 comment
Mar 7, 2008. 9:21 AMcanyonmn says:
I'm sure what you've got works perfectly, but for future use, there are "clip-on" ribbon cable ends that you could have clipped on both cables and created your extension that way. I get a headache just thinking about how difficult that soldering job must have been .. :-)
Mar 7, 2008. 11:39 AMcanyonmn says:
Yes .. I noticed, after reading through your instructable, that you enjoy soldering .. so it probably wasn't a bit deal for you .. :-) Great job!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:jeffkobi
