Portable iPod and phone chargers are by no
means anything new. However, there are two main aspects of portable chargers that I think could be improved without sacrificing any of their functionality. These are:
Aesthetics. There is nothing wrong with an Altoids tin, but there is also a lot of room for improvement as far as looks are concerned.
Batteries: The vast majority of DIY portable USB chargers use alkaline batteries, which means that they must be replaced when they run out. Also, their capacity is not especially impressive.
My goal was to fix both of these problems, while using only parts I had lying around. Every single component of this charger I either already had, or I pulled out of some broken electronic device. Because I only used what was available, the charging circuit uses a 7805 voltage regulator, meaning it is not especially efficient. On average, it will still be more efficient than a 9V charger, because the peak voltage of the Li-Ion battery pack is around 7.5-7.8V. Had I built a Mintyboost type circuit, it would no doubt have been more efficient. However, as the battery pack I used is significantly larger than AA batteries or a 9V (it is 1/3 of a 15" Macbook Pro battery, in fact), this device should be able to power any iPod, phone, or other USB powered device for hours at a time before it must be recharged.
http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
the point of what i didn't say (at least what link say), handling batteries is not rocket science and also over-discharge is something to take in consideration.
nuff said.
from what i can remember about the 7805 datasheet, as you mention, you're working below the ideal input voltage to work in the linear regulation range and despite what many people think the 78XX family is not predictable in that range, so whatever is the differential voltage the regulator may feed current to the load (or maybe not), so be careful, that's it.
great work and nicely documented!
I particularly like how you dealt with the charging and discharging problem :)
But I have two minor concerns:
First, how hot does the heatsink get in operation? Maybe there are better options than hotglue to hold it in place?
The other is, minature, but strong neodymium magnets close to a magnetic harddrive like in an Ipod, "possibly" could cause problems (?!).
And now an additional idea, what are the measurements of the components? Maybe one could fit all of it into a external harddisk case instead of custom-building one.
Regards,
Confu
As far as the magnets, I would personally not use a hard drive based iPod with the charger, because as you say, it may very well cause problems. However, I do not own a hard drive based iPod, and the trend is moving away from magnetic storage.
As I built it, the components are 6.5cm by 11.5cm by 2cm (at the very thickest point, which could be reduced), so all the parts could easily fit inside a 2.5" portable hard drive enclosure.
