This is my second project since I began my public project deadline framework, and my first instructable. The first project wasn't extremely technical, so I don't really feel that it is necessary to make an instructable for it.
Project: I wanted to start out with something simple that could just be a fun conversation piece, and came up with the idea with a user controlled RGB LED lantern. To make it a bit more interesting and coffee table worthy, I housed the electronics in an antique lantern body that I picked up at an Antique store. It turned out pretty well, and got the appropriate "oohs" and "aahs" when handed around for people to play with. There is a photo of the finished product below, as well as a lantern showing the ways a user can affect the lantern's operation.
There are two "Modes" that the lantern operates in. The first mode is simply color cycling. The user can change the speed the colors change and the brightness. The second mode is a solid color, and the user can change the color and the brightness.
Remove these ads by
Signing UpStep 1Materials
Antique Miner's Lantern (~$20)
Arduino Pro ($19.95)
2x RGB LED's (2 x $1.95 = $3.90)
Battery Holder - 4xAA Square ($1.95)
JST Jumper Wire ($0.95)
2x Rotary Encoders (2 x $1.08 = $2.16)
1/8" plastic sheet ($3.45)
3 resistors: from my toolbox. I don't remember what values I used, but will look them up and update this later.
6 capacitors: I used 1microF, but 10picoF is what I was aiming for. I only had larger values on hand, and my deadline was fast approaching, so I used a slightly less than optimal solution.
6 screws: 4 for attaching the Arduino, 2 for the plastic. I tapped the holes in the wood, but if you had some short wood screws, that could work, too.
4 standoffs: These are small standoffs to screw the Arduino into.
Scrap wood
Wire
Epoxy or some other glue for plastic to metal and metal to metal.
I have a minor quibble with the description however. I believe this type of lantern is correctly referred to as a "(metal) hurricane lantern". A "miner's lantern" is a somewhat different beast - if you want to compare, search each term on Google and compare the images and descriptions. (I'm just nit-picking really.)
All said though, well done! I'm sure it will spawn some variations from other members as well. Look forward to seeing more from you as well.
I like that you kept the beaten and "well-used" look of the original
I've got an oil lamp like yours out in my garage - found it in my in-laws basement when we were clearing the house and meant to convert it to LEDs but haven't gotten past the idea stage yet.
Thanks for the inspiration and a *kick* to get me started.
And I like the idea of using the wick adjustment wheel to control the circuit!
I'll post a pic once I have my lamp converted. Any thoughts about making it solar powered? I want to hang mine in a tree!
