feeder, house, etc.?
This example was my real first try. I was able to get everything mounted perfectly while
also keeping it all dry and hidden. I also used the best feature of these lights and that
is the photo-sensor for night only on action. You should have a basic knowledge of
soldering and dealing with fine gauge wire. Wood cutting tools and skills would also be
appropriate for this retrofit.
Items I used:
- old bird feeder or house
- Solar LED outdoor light with photo-sensor
- new Rechargeable battery with full charge
Tools:
-drill
-dremel type tool with wood/plastic cutting bits
-soldering kit (for back up or wire extending)
-glue or window caulking
Remove these ads by
Signing UpStep 1Disasseble your night light
the basic guts of your project. Try to keep all the wires still attached. My wires
were thin and kept braking so be forewarned.
Parts to salvage:
-solar panel
-photo-sensor
-LED
-circuit board
-battery tray
-I unscrewed the two halves of my light and popped the small solar panel and photo-sensor
out of the top half as they are glued on.
-unscrew the circuit board from the bottom half
-Then I used the dremel tool to cut the battery housing off of the bottom half.
-Fix any loose wires or now is the time to make them longer if necessary.
comments
Add Comment
lemonie
says:
Add Comment
