Tools you will need:
- drill
- bolt cutter
- small flat-head screwdriver
- small hacksaw (I used a coping saw)
- some bolts (small thread, M2.5 or 0.1" thread diameter)
- some screws
- ruler & pencil
The only requirements for the existing drawer:
- approx 12mm (0.5") clearance on either the left or the right of the drawer (almost any rail system will have this)
- approx 9mm (0.35") clearance behind the drawer
The drawer can be made of wood or metal - doesn't matter.
Note about the small piston-type door buffers / dampers:
Before this project I attempted to use these to damp my drawers, but they didn't work well (drawers wouldn't self-close, or still slammed shut.) The Blumotion system with its long throw and spring+latch mechanism overcomes these issues. Thanks to adamazing for bringing this up in the comments.
Remove these ads by
Signing UpStep 1Obtain the Blumotion mechanism
WARNING #1: IKEA also sell an AU$10 RATIONELL damper add-on kit. This will NOT work as it contains only the damper and not the spring-latch mechanism which is so crucial to the system.
WARNING #2: Don't buy the bigger drawers as they use a different damping mechanism which is much harder to modify.
Obtaining this kit from IKEA is relatively straightforward. If you need a salesperson's assistance when ordering the kit(s), you will probably be asked if you have the correct RATIONELL cupboard in which to install the drawer - a lot of people have obviously tried to screw their existing drawers onto the RATIONELL rails with little success.
Once you have purchased the kit, take out the 2 rails and set the rest aside.
http://www.ikea.com/ca/en/catalog/products/30108928
it is listed as being 41 cm in width by 30.5 in length. Do you think this type of drawer will work for me to use the soft close out of to retrofit my drawers. I would appreciate your opinion on this. There are other width sizes but all are 12 inches (30.5 cm) in depth.
Thanks again for the great information.
Have fun with your retrofit :)
I do have one more quick question. Did you happen to do any retrofits on your cabinet doors to create the same soft close affect. Reason I am asking is I was thinking of purchasing dampers for the cabinet doors. I'm not sure if the blumotion items would work.
http://www.blum.com/us/en/01/30/40/20/index.php
Just wondering if you had done something that works.
Thanks,
Jamal
You can install these closer to or further from the hinge to lower or raise the damping effect. Installation is as simple as drilling a hole and slipping the damper in.
I tried to use these as drawer dampers, but unfortunately they don't work since it lacks a spring+latch mechanism, which is required to pull the drawer shut. With doors, there is enough force in the hinge and the load is always the same (i.e. a door always weighs the same, but a drawer will vary in weight depending on its contents)
