3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Retrofitting A Delta T2 Fence to a Craftsman Table Saw
If you have one of these older Craftsman table saws, you already know two things:
1) With a little tweaking, they're surprisingly adequate saws.
2) The fence really sucks. Like, a lot.
Luckily there are a lot of options out there to upgrade that shotty old fence. In this instructable, I'll cover the procedure for installing a Delta 36-T30 T2 fence & rail system onto a Craftsman 113.298762. This is a popular upgrade for these old saws, but the documentation out there on how to do it is pretty sparse. Hopefully this little guide will help a few folks.
Step 1A note about compatiblity...
The Delta 36-T30 fence & rails are a bargain no matter how you look at it. Its basically a clone of the ever popular and ever expensive Biesemeyer fences. Those can run upwards of $300-400+. The T2 is sold by Lowe's for around $150. A true bargain. But here's the thing...
The Delta T2 rails are supposedly universal, but none of the pre-drilled holes line up on Craftsman saws. There's lots of drilling and nervousness involved, so be forewarned. If you take your time and measure, measure, measure, this works great. If you try to rush through it, you could damage the fence and render it unusable...and un-returnable.
The saw in this instructable is a Craftsman 113.298762, but this process should apply to most other Craftsman table saws.
30 comments
May 4, 2012. 9:55 AMWoodChip7 says:
Haven't put my fence on yet but it seems to be much beefier and by the comments more accurate repeatability. For those looking to buy this little beauty try ToolsPlus.com seems to be the most reasonably priced by as much a $50.00 or so in savings, free shipping and I ordered mine on sunday evening and recieved it tuesday afternoon. Will repost after the fence is mounted.
Apr 6, 2012. 11:28 AMwallerps says:
I love this Delta T2 kit but am having trouble getting it attached. I used one of the existing hole on the front and one on the back. When I lay the fence on the saw table the fence doesn't even come close to fitting the back rail. I'm sure I will have to re-drill all the hole and mount it again. I was glad to read that you could remove the measurement tape and re-position it. My Craftsman has metal sides and not the steel ones.
I have attached some of my photos.
All of the comments on this project have helped me a lot. Any ideas on my project would be appreciated.
Sparkie Waller
Quinton, Alabama
Apr 17, 2012. 12:13 PMjeffver says:
Mr Waller,
I don't know if you have figured this out yet, but it appears that you have the back rail on upside down. The fence rides on the flat part of the rear rail. I attached a photo.
Hope this helps, it's a great fence.
Jeff
Apr 11, 2012. 3:11 PMBlackie_ says:
Thought I'd chime in a bit late, thanks for these great instructions cornflake, I have an Hitachi C10FL and was looking for instruction for installing the T30, I ran across yours for the craftsman and thought well shouldn't be that much different and it wasn't actually using your method I had it installed within 5 hours, no trips to the hardware store either, I found that a 1/2" counter sink was enough as I didn't have a 5/8 on hand, I used these adjutable roller stands
http://www.harborfreight.com/132-lb-capacity-roller-stand-95621.html
to hold the rails up with and made minor adjustments getting the fence proper height and also 2' level. I optioned for the drill press as well.
All in all your instructions fit my application perfect once again thanks.
Randy
Jan 30, 2012. 1:56 PMhome8401 says:
I am trying to install my new Delta T2 fence on my craftsman table saw and it is a 113.226880 I have owned for a lot of years. The table is only 23" outside to outside old rails still on the saw. New fence is 6" longer. I would like any experiences you have had with this problem. Looks like moving the rear bracked on the fence forward about 6" is my only hope. Any advice would be appreciated. Need to install this and just received it today.
Thanks in advance.
Wendell
hwendell6487@yahoo.com
Jan 28, 2012. 9:45 AMhome8401 says:
I tried to find the Delta 36-T30 T2 and called every Lowes I could find.
No one had one. I got on the Internet and found several places that had them at different prices The one I selected was Tools Plus, Inc. They had them for $147.97 and shipping was $6.50, UPS ground. They shipped it the day I ordered and am waiting for it to arrive. Good Price.
My saw is a Craftsman #113.226880 and I hope it works. Not sure of the saw width but this seems to be a critical width or fence won't fit.
Hope this helps those of you are now searching for a Delta fence upgrade for your Craftsman saw.
Home8401
Dec 31, 2011. 5:05 AMMosheim Jack says:
The installation went great following your procedure; lots of measuring. Required two trips to hardware store; what project doesn't require that? Took the motor off which made working on the rear rail much easier. Oiled the old motor while I was working on the saw. The motor burnt up on restart (go figure). I assume the cause was my penchant for over lubricating. New motor, belt and I've got a great running sw. Definitely wirth the time and money.
Oct 21, 2011. 12:48 PMPinhead9 says:
Where have you placed the switch? I'm trying to locate a position that doesn't interfere with the operation of the fence.
Dec 31, 2011. 4:56 AMMosheim Jack says:
Just finished installation on mine this weekend. My saw is Model No. 113.298031 from the late 70's. I mounted the switch on the bottom right leg for the base, just below the saw housing. Easy enough to reach to start, then very easy to stop with a tap of the toe.
Oct 18, 2011. 1:39 PMpfred2 says:
I'm in the process of writing up my fence right now. Oh BTW your craftsman saw isn't that old. This is an old Craftsman saw! Like 1948 old
Oct 18, 2011. 3:25 AMobstreperous82 says:
I did this exact thing a couple of years ago! Kudos for posting about it. Definitely a worthwhile upgrade!
Aug 12, 2009. 4:54 PMshafiqj says:
Nice instructions! However, I found that drilling into my saw table was a lot easier. I lined up and used one existing hole on the table with the front rail and drilled the next two. 10 mins for the front of the table (front rail) and 10 mins for the back of the table (rear rail) and I was done. The only remaining thing to do was to remove the sticky measure tape on the guide tube and move it over to the zero point. No other measurements needed.
May 10, 2011. 2:32 PMbsczap says:
This is the way to go. Here's my writeup about it. http://tiny.cc/craftsman-t2-fence
Dec 10, 2010. 12:57 PMjster says:
Alot simpler
Feb 17, 2010. 1:53 PMjesseroscoe says:
Just wanted to drop you a line and let you know that I used your instructions and installed the T2 on the exact same model Craftsman saw (16 years old).  Huge difference.  Thanks!
Aug 20, 2009. 10:34 AMUnstoppableDrew says:
Small correction: you are counter sinking the holes, not counter boring them. Counter bore is for fasteners with a flat underside like a hex head cap screw. Counter sink is for slope-sided heads like wood screws.
Apr 9, 2009. 3:53 PMmoosetooth says:
Great instructable, thanks! I have a craftsman saw that's quite a bit older. Model 103.27270 . Great saw, lousy fence. I bought the delta fence because this instructable made it look do-able... Imagine my surprise when the Delta fence bolted right up! All the bolt holes fit, I just had to peel the measure tape off (it came off easy!) and reset it about 1.75 in. to the left. I thought I would spend all weekend on this project but it only took less than an hour. The Delta fence is a Cadillac....Thanks again for the how-to... I never would have bought the fence otherwise.
Mar 5, 2009. 1:41 PMrweerstra says:
Does this upgrade work with the same saw if it doesn't have the two table extensions as pictured? It would be nice if the fence can be used beyond the edge of the existing table on the side without the extension.
Mar 7, 2009. 3:43 PMrweerstra says:
I did the deed. I got the kit from Lowes yesterday. The results are fantastic. I found that there were no mounting holes in the rear of my saw cast iron table. I drilled them and started to thread the holes and broke my tap. After getting the broken tap out, I redrilled the hole and used bolts and nuts to attach the rear rail. Then I found I had reversed the rail when I marked the zero spot so I had to redrill the rail to match the holes I had drilled in the saw since the holes in the rail lined up with the castings on the saw table. To get the 1/16 inch clearance to the table you suggested, I found two pieces of sheet metal 1/16 inch thick, placing them under the fence during the alignment process. That worked great. All in all, it worked out fine considering my mistakes. I found that there is a great deal of adjustment with the nylon screws in the fence so I could have mounted the front rail lower drilling the holes I farther from the edge of the front rail. The holes were close to breaking out while drilling. I am so glad that you compiled the instructions as you did. The instructions with the kit were lacking if you were not using this kit on a Delta saw. I would say that I am so glad to get rid of the original fence. It was great fun to toss it into the trash. Now that I have replaced the original motor ($140) with a sealed unit, and replaced the fence ($150), my saw probably is worth about $190 now. Thanks for your help.
Jan 12, 2009. 5:28 AMgraywolfy says:
Worked like a charm, had it done in one evening. I've been hunting for an affordable replacement fence for ages. Best instructions I've had to work from in ages.
Jan 8, 2009. 12:13 PMrichz says:
I just finished putting the Delta fence on a 1980 Craftsman saw. It took about three hours-mostly measuring. Your directions were on the money. The fence works so well I can't believe I waited this long to make the switch. Thanks again.......Rich
Jan 4, 2009. 6:32 AMLinuxH4x0r says:
Great job! I have the same exact saw. I also bought a newer saw when I moved (sill have the other one in the old house) and trust me, the new ones SUCK!!! 5/5
Jan 4, 2009. 8:49 AMLinuxH4x0r says:
Thats true of almost everything nowadays. My dad would buy a new microwave about every 3 years when his friend was still using a 20 year old one. His packard bell from 91 outlasted two laptops and is now being used in a factory to control machinery. I'd rater use my Minolta from 82 than my digital camera. Kind of sad how its going backwards. He bought it new for $2-300
Jan 4, 2009. 7:33 AMTool Using Animal says:
Nicely done! Best improvement I made to my Craftsman was switching fences, but I just used a cheap aftermarket. Also, I noticed you made the second best improvement also, a link belt.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:cornflake_81
I have a penchant for anything that requires tinkering or fiddling. I unfortunately live in a newer home that requires little repair or maintenance, so I mostly sit around waiting for something to br...
more »
