Step 3Establish the zero reference line...
Go ahead and attach the guide tube to the front rail. Using your square against the front edge of the guide tube, find the "Zero" line and transfer a pencil mark to the front rail. Now, butt the back rail up to the front rail and transfer the mark. Set the back rail aside.
Now go ahead and pop the fence onto the front rail/guide tube assembly. Line up the sight on the fence with the zero line on the guide tube and lock it down. Raise the blade up to full height...you did unplug your saw, right? Of course you did. Lay the fence on the table and slide it firmly against the saw blade. Also make sure that the front rail is firmly against the front of the saw. Use a couple small clamps to make sure that the front rail is fairly level and that everything is secure.
Now transfer the pencil mark from the front rail to the front of your saw table. Remove the fence and front rail and set them aside. Now, using a small square, extend that pencil mark up the front of the table. Using a larger square, extend the pencil mark all the way across the top of the table, and then down the back of the table. Now we have all the guides we need to line the scale up properly.
Note: The fence's sight is adjustable a few millimeters from side to side, so you have a small margin for error in this step.
Add Comment
