3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Retrofitting A Delta T2 Fence to a Craftsman Table Saw
Step 4Mark the front rail for drilling...
There are a couple different ways to go about making this fence fit. You can use the pre-existing holes in the front rail and drill new holes in the saw table. Or, you can use the pre-existing holes in the table and drill the front rail. I chose the latter simply because I can't get my table saw onto my drill press.
First, we need to get the front rail/guide tube into position. I just propped the whole front rail assembly up on a saw horse and slid it up to the front of the saw table. I lined up the line I drew on the front rail with the line I just marked on the table. I then used a combination of scrap wood and paper to shim it up to where I wanted it. I would occasionally clamp the front rail in place and pop the fence on to check it for clearance over the table top.
This required a LOT of trial and error. If you position the rail too high, the fence will ride really high over the table. If you position it too low, you'll have to drill too close to the edge of the rail. Take your time and find a good equilibrium. On my saw, 13/16" from the top of the saw table to the top of the rail was the butter zone. I used a combination square to make sure that this measurement was constant across the entire length of the rail. That gave me just enough room to drill, and the fence rides a mere 1/16" over the table.
Note: Another thing to look out for are the little nylon adjusting screws on either side of the fence. If your fence is riding too high, they will actually be above the level of the table top and will interfere with your work piece.
Once the fence was where I wanted it, I used a Sharpie marker to mark the drilling locations. I just crouched down beneath the saw table and marked through the existing holes in the table top. Once I was confident that everything was marked correctly, I disassembled the front rail & guide tub and headed for the drill press.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:cornflake_81
I have a penchant for anything that requires tinkering or fiddling. I unfortunately live in a newer home that requires little repair or maintenance, so I mostly sit around waiting for something to br...
more »
