Step 5Drilling the front rail...
I used a 7/16" drill bit for all the holes. Its roughly the same size as the pre-drilled holes in the rail, and it gives us a little wiggle room for fine tuning later. When drilling the holes, be sure to keep a can of WD-40 handy to keep things cool. Also, be sure you've got your safety glasses on as you'll be flinging around lots of metal shavings. After the first hole is drilled, just slide the rail down and drill the second hole.
Next, mount a 5/8" countersink bit into the drill press. Countersink the holes just until the screw heads sit flush. The front rail is done, just mount the guide tube to it and bolt it to the saw and make sure everything lines up as it should.
comment
Add Comment
cornflake_81 (author)
says:
Add Comment
