Retrograde- Knex Ball Machine Instructions (Not My Design)
5,307
11
8
Posted
Introduction: Retrograde- Knex Ball Machine Instructions (Not My Design)
This is not my own design, this is MarsCrystalMans ingenious design and I made an instructable for him on this. This instructable is quite long so it may take a while to build. This instructable is not intended to be high-quality but good enough to be understood.
video at https://www.instructables.com/id/Retrograde-A-Knex-Ball-Machine/
Step 1: Piece Count
RODS:
Grey: 58
Red: 175
Yellow: 173
Blue: 403
White: 363
Green: 340
CONNECTORS:
White: 78
Blue 3D: 134
Purple 3D: 255
Yellow: 255
Gold-track connector: 17
Green: 209
Orange: 125
Red: 184
Light-grey: 67
Dark-grey: 244
SPECIAL:
Black Y-clip: 63
Tan-clip: 28
Blue-clip:10
Gold-track clip: 14
Ball-socket joint: 2
Silver spacer: 79
Blue spacer: 132
Purple flexi-rod: 16
Orange flexi-rod: 7
Golden(red) rod: 8
Red gear: 1
Blue gear: 5
Large yellow gear: 1
Tan(red) rod: 7
Small triangle panel: 11
Triangle panel(3 holes): 3
Small square panel(1 hole): 1
Square panel(3 holes): 3
Small tire with tread: 11
Medium tire with tread: 5
Large tire tread(no tire): 2
small snap-on tire: 2
Medium snap-on tire: 1
Motor(newer green ones): 1
Step 2: The Base
Step 3: Support Structures and Return Tracks
A Big Step.
Step 4: Path Selectors and Drop-Path Selector
Another big step. This also fulfills a request for the Drop-Path separator for a member.
Step 5: Stepper- Lift System
This fulfills another request for a member. This is an instructable in an instructable!
Step 6: Path 1
I  found this element to be very cool.
Step 7: Path 2 ( Wormhole Element)
This path has the Wormhole Element someone wanted instructions on. Includes part of another path.
Step 8: Path 3
The path that traps the ball behind the wormhole.
Step 9: Path 4
This step may seem complicated but just copy what you see. I didn't feel like taking the whole thing apart. I used a tv jack cable for the tubing. I modified the element with spacers. The element didn't work for me for some reason, maybe because the cable was too thick so try roller coaster tubing.
Step 10: Path 5
This includes the spinning wheel element, a very clever piece.
Step 11: Path 6
This step includes the spinning basket element.
Step 12: Path 7
Just about done! This is the graceful turn that really makes this machine unique.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    8 Comments
    looks awesome! I'm going to build it but do I need 17 gold track connectors?
    up to this step waiting for big yellow gear o come from ebay then ill continue building the ball machine
    Knex.com has yellow gears, you just trying to find one for a cheaper price?
    Good job, the instructions are very good. (And you just saved me a ton of time :-D). Also, I like some of your modifications; they enhance the machine, especially the spacers on the spiral, much better placeholders. One note: you said there is no video for the machine, but if you wanted, you could say "video at https://www.instructables.com/id/Retrograde-A-Knex-Ball-Machine/". That would cover it!
    Once again, great job! The instructable has my seal of approval! (Not that you needed it, but... ;-D)
    Thanks a lot :-D. I fixed the description so thanks for the tip.
    Very clear, and instructions for the stepper lift.
    yes you made instructions i going to start building tommorow ,good job :-]
