loading
Step 2: Contact paper
To create a whiteboard-like coating for the posty notes you can either get them laminated or cover both sides with contact paper. I used some inexpensive contact paper that I found at the dollar store which could cover two and a half sheets of 8.5x11paper (whereas laminating an 8.5x11 sheet of paper would cost $2.50.)
To apply the contact paper cut two pieces large enough to cover the computer paper that you are using for your notes.  Peel off the backing of the sheet and stick it to one side of the note paper.  Start from the top edge and roll the backing down, use a ruler to smooth it out and prevent  bubbles or creases.  Repeat on the other side.
This is a very cool instructable. I love it. <br> <br>I'm sure you know this, but they make dry-erase board Con-tact paper now. It's a bit pricier than the traditional stuff, but it'd be great for something like this! <br> <br>I actually prefer your method in that you can customize the appearance of the post-it paper. Excellent idea with unlimited possible variations! Thanks for sharing it.
this is just brilliant !!!!!!!!!!! very nice
Thanks! I use it a lot at work.
I just really like dis!!!<br>
A.M.A.Z.I.N.G.!!! :D
Thanks!
wow you are truly inspirational, great job!
Thanks!
your welcome!
Nice job on the win, Chrys!
Thanks!
Very cool. I use Post-it notes constantly to keep organized and would love to get away from the one time only use.<br><br>Instead of Blu-tak, you could also use movable glue, aka stick it again and again [not sure of the actual name, but that's close]. It's sold in hobby shops and people who do dollhouse miniatures use it to tack down small objects, but still enable them to be moved...BTW, Blu-tak can leave marks on some surfaces, so you have to be careful not to put it on wood or anything absorbent.
Thanks for the tip, is it something like this:&nbsp;<a href="http://www.gluedots.com/display/router.aspx?DocID=1083">http://www.gluedots.com/display/router.aspx?DocID=1083.&nbsp;</a> That sounds even better than Blu-tack.<br>
I use those in some of my artwork, to mount things. They're pretty cool, come on a little sheet.. They remind me of the glue that you find on things you buy in stores sometimes, you know, it sort of peels off pretty easily? The stuff they use to stick gift cards to their backing in grocery stores..<br><br>I think those would probably work for what you're doing, and they're not all that expensive for a *lot* of them.
Great idea/instructable ChrysN! Thanks. While still working in the lab I came up with the idea of recycling all the hardcopies we generated for reports...we also needed note paper at all phone locations and work stations. So I made small boxes as shown, cut the used paper that was slated for the recycle bin, and solved two issues at once. If you do this, all names must removed from the reports, of course. Most names were included only in the header of the report so it was a simple matter to cut off the headers. I liked the idea so well the hot dog box is on my counter in the kitchen!
That's a great way to reuse paper and cute boxes too!
I need to make a ton of these for work. Awesome idea.
Thanks!
Great idea, held up by a great Van cat. I have one too and he is such a gentle giant.
This is awesome. Very clever.<br />
Thanks!
About This Instructable
13,746views
44favorites
License:
Bio: I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and ... More »
More by ChrysN:Crochet Pokeball Keychain Flashlight Yarn Brain Analog Word Clock
Add instructable to:
