3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Reuse "Wallwart" transformers
Reuse \"Wallwart\" transformers
Lost that special plug for your favorite appliance or toy?
Want to utilize that "DC power" jack on your walkman, but it didn't come with a plug?
Need a power supply for that special project but not sure which one to use?
Here's my little guide for picking the best power supply for your needs.
Step 1AC and DC power
AC and DC power
AC and DC power are the two types of power which you are probably familiar with.
AC power comes from the power company, and is accessible through the outlets in your house.
DC power comes from batteries.
Sometimes we need to convert the AC power from the wall to DC power in order to run a device which normally might run on batteries. The tool for this job is an AC/DC adapter or transformer which is often referred to as a "wallwart" as it sticks out of the wall in an unsightly manner.
Most appliances that require an adapter like this have a label near the power jack which details about the voltage and polarity required.
48 comments
1-40 of 48next »
Jun 5, 2008. 7:58 PMocelot1633 says:
Ummm buddy, I dun mean to be rude or anything but to correct your statement "AC and DC power are the two types of power which you are probably familiar with. AC power comes from the power company, and is accessible through the outlets in your house. DC power comes from batteries." Truth is, that Power plants generate DC power, and it is run as DC until it reaches a transformer, witch converts to AC, but still the DC currents are EXTREMELY high.... regardles, proceede w/ caution
May 5, 2009. 3:29 AMemgonzalez says:
power plants generate power via different kinds of induction based electromechanical converters, and none of them output DC. DC is generated with chemical or photovoltaic processes, none of them very popular so far. Electricity is generated in AC, voltage is elevated to several hundred thousand volts with transformers and then transmitted using transmission lines typically staying in AC (with some very rare exceptions of high capacity voltage DC lines). The transformers outside your home are always DC and always take the voltage from several thousand volts AC to the 110 or 220v you use in your household. Tesla won this fight to Edison, early last century, and we haven't bested their discoveries yet.
Oct 14, 2011. 9:35 PMRobert_13 says:
Transformers don't convert AC to DC or DC to AC. They simply step the voltage that delivers the current and the resulting power either up or down. The power is almost the same out as in, since transformers are very efficient, so high voltage means low current for roughly the same power and vice versa. Power equals voltage times current and you don't get power from nothing, so they have to multiply together to give almost as much power out as in.
Mar 3, 2009. 6:53 PMjhvh.one says:
power plants did typically generate DC power...before CE 1900, that is... there is still some limited use of high voltage DC transmission today. mostly because of its ability to transmit large amounts of power over long distances with lower losses than with AC
May 9, 2009. 4:39 PMzvillesurfer says:
Power plants never generate DC power. That's impossible. The difference was, a long time ago, AC power was created and immediately turned into DC.
Mar 7, 2010. 11:07 AMscratchr says:
There are two ways to generate power:
AC alternator
DC motor
Most modern power plants use an alternator that makes AC
AC is a better choice because transformers only work with AC.
AC is also better because converting AC to DC only needs a diode.
DC to AC needs complex circuitry.
May 10, 2009. 1:26 PMjhvh.one says:
i've got to respectfully disagree. consult your history books and get back to me. you might want to read about the "war of the currents"
May 15, 2009. 2:48 PMzvillesurfer says:
No. I know about the "war of the currents". The problem there was not how they generate it, but how to transmit the power. Any power plant that uses a turbine, such as a coal, gasoline, nuclear, hydroelectric, wind, generates AC current. It is impossible for them to generate DC. Look at what thermoelectric said right below this. "They generate AC with a frequency equivalent to the input speed of the generators." That is exactly how it works. Consult your science books and get back to me.
May 15, 2009. 5:39 PMjhvh.one says:
Edison's original distribution system was all DC... from generation to utilization. because of the inefficiency of DC transmission, customers had to be within about a mile and a half of a generating station. it wasn't until after 1896, when westinghouse installed a hydroelectric polyphase AC generating system at niagra falls, that AC generation and distribution began to widely replace DC systems.
May 17, 2009. 7:44 PMzvillesurfer says:
Can someone help me explain here? There are very few ways to generate DC current, and none of those ways existed back then. Examples of this are photovoltaic cells or chemical processes like batteries.
May 18, 2009. 5:16 PMjhvh.one says:
"a long time ago, AC power was created and immediately turned into DC"
ok, i do see what you're getting at here...but this process is happening within the generator, through the use of the commutator. the armature windings rotating through the magnetic field of the stator do produce an alternating current, but since the experimenters in those days didn't really know what to do with AC, they employed a commutator to periodically reverse the connections between the armature and the external circuit. thus, the dynamo generator generated DC current.
for an example of an electromagnetic generator that produces DC without the use of a commutator, check out Faraday's Disk
Sep 10, 2009. 5:12 AMpyrorower says:
I have to agree with jhvh here. Edison's system ultimately produced DC current. The issue was that you either had to be very close to the power plant to get power, or have quite a few power stations to maintain the current in the power lines. Plus, they had to be HUGE to carry enough DC current for public use. Tesla's AC used much thinner lines relative to Edison's DC and stations could be spaced much farther apart, giving more people easy access to the power even when they were far from the plant. Now, I'm not sure how Edison generated his electricity, I just know that once it left the plant it was DC but that AC proved more efficient and triumphed over DC. Sorry if I rambled :P
Feb 18, 2010. 9:54 AMbuteman says:
The car I had in the 1960's had a dynamo this was an ac generator with a commutator and brushes to convert it to D.C These days cars use an alternator. It has built in diodes so it dishes out D.C.
Jan 15, 2009. 9:49 PMthermoelectric says:
The power plants don't generate DC power, They generate AC with a frequency equivalent to the input speed of the generators, They probably have a control on the generators to stabilize the speed to keep the frequency steady. Well something like that but they DEFIANTLY generate Alternating Current.
Jun 5, 2008. 7:59 PMocelot1633 says:
Edit: Good Instructable tho . Found it very useful
Dec 30, 2008. 8:47 AMjoinaqd says:
i did this when i was 5 years old!!!!!
Sep 22, 2009. 1:04 PMw0rm5 says:
Power PLANTS DO produce DC power till it get to a central near you home. Always this way, and like my man I also did this long ago, but good project, i use it to keep a stable voltage when charging BMW batteries, since their actual systems, navigation, start, and other stuff, can be damaged if power goes under 13V while charging the batteries.
Apr 27, 2010. 11:32 AMjohnny3h says:
Many, many of the following comments, as well as this one are in ERROR.
Power plants do create Alternating Current [AC], even though they could build "DC generators" as Thomas Edison first did.
The reason they make AC rather than DC is that DC is very inefficient to transfer [transmit] on wires, especially for distances greater than a mile or two.
AC is orders of magnitude more efficient to transmit on long distance high voltage power lines [often called "Hi-lines"].  The electricity/power is also easier to control by changing the voltage, and thus power, using transformers which do NOT work on DC.
This comment should apply to ALL of the following comments that erroneously transpose the terms AC [Alternating Current] and DC [Direct Current].
Oct 14, 2011. 9:24 PMRobert_13 says:
w0rm5's comment on DC may not be in error. His English usage signals that it is not his first language. In the U.S.A. we are currently looking at high voltage DC transmission that gets converted locally to 120V AC as on of our much touted smart grid options. AC is only efficient because it is easily and simply transformed from high voltage long distance lines to 120V local AC. Just need transformers, nothing else.
However, there are substantial radiation losses over long distances with AC. Who hasn't heard of the farmers who put up a power cable in parallel with a high voltage transmission line to power a home, etc. free of charge? In some parts of the world, as we're contemplating here, with modern technology we can transmit very high voltage DC (HVDC) and then convert to 120V AC locally. w0rm5 may live where this is already being done. My bet is Germany, where there are several such projects. Follow the link below:
http://en.wikipedia.org/wiki/List_of_HVDC_projects
Aug 2, 2010. 7:52 PMcoilsinamotor says:
it is actually DC till it gets to a substation because ur wrong on the DC is less efficent part is actually more efittent than AC simply baceuse it is direct. true that that power plant generates ac but it rectifys it into dc to carry over long distances then it goes to a substation where the dc is passed throught a step down transformer to feel ac current in to our homes it needs to be step down to 220v (canada or us) beause without this our mains supply would be 1000V 3 phase power. so johnny3h i think your comment is the error sorry. but i hope this clears things up for ppl :)
Sep 20, 2010. 8:18 AMantigfk says:
Coilsinamotor obviously has no idea what he is talking about. Same thing goes for w0rm5.
Johnny3h is 100% correct.
Source: I am an electrical engineer.
Oct 14, 2011. 9:30 PMRobert_13 says:
Wrong! See my new comment above. It's relatively new, but it's already happening. You may be indeed be an engineer, but if so, you're not keeping up.
Jan 17, 2011. 10:06 PM7654321 says:
Just curious, why is having less current going to make a "pyrotechnic time bomb"?
Jan 17, 2011. 10:37 PMkelseymh says:
You're thinking the wrong way around. What the author wrote (three years ago, by the way :-), is that if your device draws 1A, but you try to use a 600 mA supply you're going to have problems. In particular, the supply will overheat, maybe melt, and quite likely short out while it's plugged in. The end result, if you're not paying attention and yank it out of the wall, will be an electrical fire inside the walls of your house.
Feb 5, 2009. 9:47 AMPlasmana says:
Just so you know what is VAC, the manufacture actually mean V (volt) AC (alternating current), so it is an AC adapter.
Feb 9, 2008. 11:06 AMKorey says:
Im trying to power a label maker without batteries and i dont have a wallwart to fit the specs. It requires 7V 1.2A...Would i be able to just plug it into 7V out of my DC power supply?
Jan 18, 2009. 3:34 PMReCreate says:
anything from 6.5 to about 7.5 volts will be safe for your thingy though the amperage(which is 1.2a)should be at least 1.2amps and should not go to far above like 10 amps as for batteries you should not charge them with a higher amperage than what they are
Oct 18, 2008. 3:12 AMRanie-K says:
I also use a generic transformer (2,5A 5V) for my Creative Zen Vision:M -works just as fine as the original and way faster than charging through my laptop's USB.
Oct 13, 2007. 10:50 AMhondagofast says:
You can use a PSP charger to run a Sony Walkman, but that's limited to people that have PSP's.
Jun 15, 2008. 11:32 PMDerin says:
really?good job sony!
Jul 14, 2008. 1:03 PMDerin says:
oops,their u-nav lcd cracks easily,my friend had one which we took apart
it took me HOURS to make him not drill thru the lcd
Aug 4, 2007. 4:37 PMKyri says:
Good job, I'd been wondering how safe doing something like this would be...
Jan 21, 2007. 8:55 PMLasVegas says:
Yes. We call pressure, Voltage, but it's normally represented in the equation as 'E' (for energy). So the equations would be shown as E=IR and P=IE.
Jan 21, 2007. 6:42 PMstereo123 says:
i want to learn eletronics to make stuff that goes bleep and blink lights, but i'm having a hard time finding guides that don't delve into deep theory without explaining what are they useful for. I like your article. Just one question, why should i use an adapter with a higher current value if i don't have an exact match? I'll believe you and not try and underrated one, but why??
Jan 22, 2007. 9:20 AMJumpin says:
Stereo, Start w/ the Beginner's guide to LEDs, just search on this site. I found it to be helpful. I had the same goals as you *(and still do) and managed to build myself 5 or 6 wonderful blinking lights to use for my bike and my friends bikes. I did the basics first and through trial and error, I am learning a lot. Sure, I mixed my LEDs at first some 3V and 5V and quickly found out that didn't work so well w/a 3V powersupply. The good thing w/working that instructable is that if it doesn't work, you get to trouble shoot and figure out in what ways you may have goofed (this took me 3 days, but I was sure proud when I figured it out). So, start w/a project and then build on it. As you do, you will learn new skills. To use the hose analogy: Turn on the water slowly and then sip, don't turn it on full blast and try to sip... you'll get all soaked (and overwhelmed). Hope that helps:)
Jan 21, 2007. 7:32 PMjtobako says:
mathimaticaly, V=IR, the R (resistance) of a divice is fixed and the V(voltage) of these power supplys has a maximum value but can be lower. the wall current can supply a huge amount of current (15+ amps usualy, most wallwarts use something like 1/2 to 1/4 of an amp). the resistance of the device and the max voltage control the amount of current used. if the current is to low, the equation still has to balance, so voltage drops. many electronics require a minimum voltage to work (most chips need 5 v) or they won't work.
another way to think about it is how well does a flashlight work with AAA batteries vers. D batteries. the source voltage is the same (with the same number of batteries) but the avalible current is much greater with the D cells. motors are the same. HOWEVER, without a limiting resistor, flashlight bulbs and motors will try to draw all current avalible (they have very low resistance). the current in that small amount of resistance creates heat, and enough heat burns out the wire or spins the motor so fast that it falls apart.
Jan 21, 2007. 10:56 PMaustin says:
how can you have a high voltage low amp situation when resistance remains constant, like in tazers and electric fences?
Jan 22, 2007. 2:17 AMjtobako says:
because the power used/delivered remains the same. either a capacitor (or several) or a transformer is used to increase voltage at the expence of current. with transformers, the ratio of windings in to out determine the amount of change-but require an ac signal to work. there is a capacitor/spark gap method as well (marx generator). both systems temporarily store up power then release it in a different V-to-I ratio.
Jan 22, 2007. 8:47 PMaustin says:
i understand that but mathmatically if I=V/R then if R remains constant and vVgoes up so does I, unless ohms law doesnt apply in such a situation.
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pir8p3t3
