3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Reverse Bear Trap Mask from Saw I
This is how I made the reverse bear trap mask from Saw I.  I uploaded a picture of the one in the movie so you can see what it really looks like.
I really wanted to go as her for Halloween but couldn't find anything online that looked like this.  So I decided to make it out of cardboard, tape, some bolts, and a lot of spray paint.
It took me a few weekends but I trashed my first prototype.  My boyfriend went as billy the puppet and we won the costume contest!
Step 1Carboard Cut Out
Carboard Cut Out
The first step to making the reverse bear trap is cutting out the cardboard. I used some old boxes that we had lying around.  The thicker, the better.  You don't want a flimsy mask!
Then I used the bottom of a drinking glass and a ruler to make the outline.  The top and bottom of the mask will have the scalloped edge.  The part where the two parts touch in the middle (where your lips would be) is just a rounded edge.
Then you want to create a thicker piece of cardboard to go over your head and hold both sides of the jaw pieces you just made.  You can mold it a bit but the weight of the jaw pieces and lock on back should hold it to your head and make it easy to take on and off.
You can see in the picture with Billy how the side pieces look.  I glued a longer piece to the jaw pieces and wrapped them around to connect with the head piece.  I did the same with a piece in the back.  Make sure to put your head in and measure!
13 comments
Mar 7, 2011. 12:12 PMRadament says:
This is the mine.
Feb 19, 2012. 9:23 PMtinker234 says:
how did you get the front in so much detail
Feb 20, 2012. 8:10 AMRadament says:
the base is a single block of triangular shape. On it I glued a kind of "box" made of tailored pieces of cardboard glued together with masking tape (in total 8 pieces for the upper part, and 8 for the part below, which are identical) . Then, like the rest of the mask, I covered it all with 3 layers of paper mache. Within each recess I glued a piece of wood cut to size and painted (http://nbg-web01.opitec.com/img/602/899/602899-02-x.jpg). Above the grooves, the protrusions are wall plugs (http://www.manualino.com/wp-content/uploads/2010/11/tasselli-come-si-usanoJPG.JPG), the largest I've found, the I cut the tip and I glued the two parts together, I painted and then glued on the rest of the structure. This is the part that unbalances the mask, but the steel lock behind balances throughout.
Feb 20, 2012. 11:22 AMtinker234 says:
thanks your look so dafined i have a freind i might use this as a prank he is terrfied of jigsaw
Oct 21, 2010. 10:20 PMdarko crumbles says:
Hey, thanks a bunch for this tutorial; it was extremely helpful! Here's mine: http://ferriman.deviantart.com/art/Reverse-Bear-Trap-Prop-SAW-183495682
Oct 15, 2010. 3:56 PMtayatipoop says:
haha jigsaw traped his self
Jun 14, 2010. 4:21 AMpunky859 says:
great instructable.....if you want a more movie accurate one tho send me a PM and i will tell you EXACTLY what to do
Feb 14, 2010. 3:57 PMargy89 says:
Hey thanks to you I was able to make my own trap here it is:
Nov 13, 2009. 6:07 PMjoshproducton09 says:
your trap is soooooooooooooooo cool and i am making mine today because i am making a clip on youtube.com which is coming 2010
Oct 24, 2009. 4:33 AMfrollard says:
Good build - its just missing the gears off the side :D  Very well done.
Oct 22, 2009. 12:25 PMchi chi chippy says:
i personaly have never seen the movie but (i dont like to be scared i like scaring) i have seen previews and this looks like it. nice ible.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:abbyroad
