Step 3Basic Code Routines
Using previous knowledge from creating software based protocols, I created a header file with these functions:
• extern void epsnCartInit(void);
• extern void epsnCartStart(unsigned char addr, unsigned char write);
• extern void epsnCartStop(void);
• extern void epsnCartWrite(unsigned char data);
• extern unsigned char epsnCartRead(void);
I also created the following definitions that help with remembering which pin was what:
For you microcontroller, you will need to modify these values to suit your application
#define _ecSCKTRIS TRISCbits.TRISC0
#define _ecSDATRIS TRISCbits.TRISC1
#define _ecRSTTRIS TRISCbits.TRISC2
#define _ecVDDTRIS TRISBbits.TRISB1
#define _ecSCKLat LATCbits.LATC0
#define _ecSDALat LATCbits.LATC1
#define _ecRSTLat LATCbits.LATC2
#define _ecVDDLat LATBbits.LATB0
#define _ecSCK PORTCbits.RC0
#define _ecSDA PORTCbits.RC1
#define _ecRST PORTCbits.RC2
#define _ecVDD PORTBbits.RB1
#define wait() DelayUS(50)
Note: I used a PIC18F and used Latches for setting the outputs, it’s just my preference in choice. You’re welcome to use any microcontroller you’re familiar with.
void epsnCartInit(){
_epsnCartSCKTRIS = 0;
_epsnCartSDATRIS = 0;
_epsnCartRSTTRIS = 0;
_epsnCartVDDTRIS = 0;
_epsnCartSCK = 0;
_epsnCartSDA = 0;
_epsnCartRST = 0;
_epsnCartVDD = 0;
_epsnCartSCKLat = 0;
The start function pulls VDD high, waits, then sets SDA according to the address bit as well as SCK. Waits, pulls SCK low, waits yet again and then pulls SDA high accordingly to the address. This repeats 2 more times except on the 4th time, SDA is set Low because we want to read the data in the EEPROMs not write.
void epsnCartStart(unsigned char addr,unsigned char write){
char i = 0; // Used for counting
char tmp = 0; // Temp storage variable
_ecVDDLat = 1; // Set VDD High
DelayMS(1); // Wait for the EEPROMs to get ready
_ecRSTLat = 1; // Enable the EEPROMs for communication
tmp = addr; // Copy the address into the temp variable
if(write){ // If we want to write
temp |= 0x08; //set the 4th bit high ( ‘|’ means OR )
while(i<4){
_ecSDALat = (tmp&0x01); // Set SDA High or Low according to the LSB
wait(); // Wait roughly 50uS
_ecSCKLat = 1; // Set Clock High
wait(); // Wait another 50uS
_ecSCKLat = 0; //Set Clock Low
tmp>>=1; //Right shift all the bits in tmp by one
i++; // increment the counter by one
The next function to implement is stop:
void epsnCartStop(){
_ecRSTLat = 0; //Set RST low
DelayMS(1); //Wait a bit
_ecVDDLat = 0; //Turn off the EEPROMS
And finally the read function:
unsigned char epsnCartRead(){
char i=0;
char temp = 0x00;
while(i<8){
temp>>=1; // Right shift the temp variable by one
_ecSCKLat = 1; //set SCK High
wait(); //Wait roughly 50uS
if(_ecSDA){ // If SDA is high
temp |= 0x80; // Then set bit 7 high
_ecSCKLat = 0; // Bring SCK low again
wait(); //wait another 50uS
i++; // Increment the counter by 1
return temp; // Return what we have read
We now have the basic functions that we need to read data from the ink cartridges, lets set up our microcontroller and set the results.
I'm a student . now i am begin to do my project about 3d printing.i have very much difficult about printer head.I try to search information, how to control print head .but i don't see. fortunately, to day i written your project.I found very interesting. i hope you can shared for me about your experience,tell me more than information about your project.
and please give me some document to
tranngoclinh.cdt@gmail.com.
thanks you very much.
