For anybody new to photography, or for the odd macro this is an awesome thing to try, it's tricky to master and very time consuming, or at least I seem to end up really in to it. You get some interesting images and results.
If you're a person with shaky hands or clumsy you can buy adapters that'll mount the lens on backwards on the bayonet plate, which makes this significantly easier. Same goes for those with little hands. If you plan to do it a lot then get them, though experiment with lens tilt is quite fun too.
You can read more of my stuff at killerjackalope.com - my newly renovated website.
Remove these ads by
Signing UpStep 1: You'll need
A pair of hands
SLR (I've not had the chance to do this with a mirrorless but I can't see it not working.)
Lens
Your choice of lens is the big thing here, thankfully your kit lens is probably a great starting point. They tend to have a max aperture of no wider than 3.5 on most. That's a good thing here - your aperture will be wide open at all times as the electronics aren't in touch.
I'm making use of an old canon 28-70 F3.5-4.5 The standard kit lens does well, I just broke mine some time ago, not that I used it much. I say old, the lens is only two months older than me...
You can use a nifty fifty to good effect with this, but it takes a little practice as the depth of field is so tiny. Using old manual aperture lenses with this is great, sadly I've misplaced the minolta 50mm I'd been playing with...
Visit Our Store »
Go Pro Today »
Personally I use a lens on the body with a lens reversed at the end of that. You still have all camera controls and metering in-tact. That makes things a little easier...although nearly impossible to hand hold due to long shutter times. I have an instructable about this if you're interested.
I had a look at your instructable, nice job and great results...
There are lots of lenses with mechanical aperture control levers. Since you'll be reverse mounting, consider buying a cheap, older lens that could be totally incompatible with your camera, just for reverse lens experimenting. I try to pick up old lenses for $10-$30 on craigslist. Sometimes I have to open them up to clean fungus and copious amounts of internal dust (much easier for fixed focal length lenses), but it is really fun to do that, and a great learning experience.
Another thing--previously, I only shot indoor with a tripod and custom bright spotlighting on my subjects, or outdoors tripod-free but only on the brightest of summer days. I've seen people get great results with their own handmade flash diffuser rigs, and so I'm trying to build one myself.
Also--since a lot of my salvaged lens custom reverse-mount housings/adapters are made of hot glue and tape--I like to put plain glass filter between the reverse mounted lens and the camera body, to keep stuff from getting into the camera body.
I love old lenses, some of the coatings seem to degrade in the coolest ways, always worth trying them without a good cleaning.
I've done early morning (pre-dawn) dewdrops handheld reverse lens and it was very difficult, I'll admit. The moving subject stuff require's a mount ring really.
Good tip there - I started with no fear on sensor cleaning and haven't had an incident yet... Though the viewfinder lens is awful to get some dirt off so I'll maybe chop a body cap in to a cover and mount...
