3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Revised C Language Hello World.
Step 3The Opened Project and Starter Source File
Now you should get a window that looks like this screen shot, with a couple of exceptions that I'll tell you about. First, the branches on the project view at the left are probably collapsed on yours. I opened mine, by clicking on it like in a file tree anywhere else. Second, your file branch that is off of the Hello project is still mamed 'main.c'. There are a couple of ways to handle this. Either you can keep different projects in separate folders or you can rename the files to what you called the project. I find that this is what works for me, so I did it here as well.
Now, you should notice right away that the editor window to the right has inserted some code for you, as a start. This is nice, but occasionally annoying. The first thing to do is to select the words in the parentheses, 'int argc, char *argv[]', change that all to the one word, 'void'. The words originally in there are for projects you'll see later that use command line parameters, also called switches. For now, the program can start up and ignore these, so we use the data place holder 'void'. In the C language, functions, even the special main function, expect to be told about what data types are needed to start with and what data type they can return, or bring back as an answer. The 'void' just says, 'nothing' to the compiler (yes, well for our purposes here). You can use the yellow diskette symbol to save at any time.
The next screenshot will show the code below also. And here it is folks:
/* In C on a straight C compiler, this is a comment.
It is in block form, running until closed without
anything else necessary to keep it from harm's way.
Anything in between doesn't affect the compiled
program at all. Not even a little!
#include <stdio.h>
#include <stdlib.h>
int main(void)
puts("Hello, World!");
system("PAUSE");
return 0;
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Delta629
Yes.
