3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Revive Nicad Batteries by Zapping with a Welder
Step 2Check Your Battery
Check Your Battery
Charge your battery up for a few hours or overnight to make sure it's charged.
If you suspect your charger isn't working you can trickle-charge it from a different voltage source.
To make sure you don't overcharge it put some little lightbulbs from christmas lights in series so the current is below 1 amp. I use 1/2 amp usually.
When you're sure your battery has had a fair chance to charge, check the voltage with your multimeter. Since you're reading this, the voltage is probably a lot lower than the label says it should be.
To see how much current your battery can put out, run the drill. Grab the chuck and stall it to get a feel for how much power it has.
That way you can compare the "before" to the "after" and see which is better.
Science depends on rigorous methods like these.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1252
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
