loading
Step 4: Stencil prep
Each stencil needs to be applied to each chair. To do this you want to make sure that the stencil is centered, level, and has extra pieces of paper next to it to prevent overspray.
To center the stencil, mark the middle point of the stencil and the chair with a pencil.
Now apply a light coat of spray adhesive on the back and wait for a minute for it to dry out a bit. This way you can remove it without leaving residue.
So apply the stencil to the chair, using the center marks as a guide. Step away to check to see if it is level. If not, remove and adjust until you're happy with it.
With everything all set, tape or glue other pieces of paper to the side of the stencil.
<p>This is the exact reason why I simply love wooden furniture. I can customize them according to my personal preferences and should they ever deteriorate in their physical condition, I can always refurbish them to look almost brand new with the right tools. However, some materials like teak could be heavy especially in their bulky form. Hence, I always ensure I hire <a href="http://www.platinumremovals.com.au/blog/moving-bulky-furniture-into-storage/" rel="nofollow">furniture removals</a> to help me move them into my new place or to a storage unit.</p>
<p>This is really making me want to revamp my patio furniture setup. It seems like a good time, because despite it being February, is is 63 degrees outside. I really want to make sure that I am keeping up on this kind of stuff. The trick is knowledge and proactivity. <br><br>&lt;a href='http://www.elegantoutdoors.com/casual-outdoor-furniture/' &gt;http://www.elegantoutdoors.com/casual-outdoor-furniture/&lt;/a&gt;</p>
That outside furniture didn't look bad to me before you started. Bad is when you go to sit down and it breaks out from under you! The bench in the background of this picture was that bad:<br> <br> <a href="http://i.imgur.com/lt6hi.jpg">http://i.imgur.com/lt6hi.jpg</a><br> <br> I reslatted it and saved the back with this product called Minwax Wood Hardener. there are other wood hardening products out there but the Minwax stuff is the only thing I've any experience with. It can turn any dry rotted wood into iron.<br> <br> The little benches in the foreground of that picture are looking pretty bad too but they'll look that way for years I'm sure.<br>
those pieces are teak. teak has a lot of oil in it naturally which is why it stands up so well to outside use but also means you want to be careful when you refinish. <br>teak turns gray as it ages. when you sand, you want to get off all the gray and get back to the natural tan wood underneath. sand by hand to get into all the slots where the sander cant reach. stain is absorbed better by the bare wood than the gray so areas that aren't sanded will will show. take your time and do this right. make sure to whipe the piece down with a tack cloth to get off all the sanding dust. <br>I prefer teak oil instead of stain but which ever you choose you should go over with some teak sealer. <br>you really should do the stain and sealer first before doign the stencil.
Wow, they look great. Much easier than busting out the old wood stain in a can with a brush!
One time while I was pressure washing my patio I accidentally passed the water over a chair - wow - it was like instant sanding. It looked brand new. I ended up doing all the furniture, then I started on the tree trunks. It is way easier than sanding. These Chairs look amazing Fungus.
I know it's outdoor furniture, but after your stain is dry you can add a couple of thin coats of clear to help seal it, and make it last longer as well. <br> <br>another idea for the cleaning - use a pressure washer to liven up the wood. but be careful not to get too close or the pressure washer can damage the wood. It would be very similar to the way you refurbish a wooden deck. <br> <br>Nice set of instructions.
About This Instructable
164,825views
46favorites
License:
Bio: I like to make things for the internets. I also sell a pretty cool calendar at supamoto.co. You'll like it.
More by fungus amungus:Open a Stuck Jar with a Knife Pt. 2 Open a Stuck Jar with a Knife 3D paper signs
Add instructable to:
