Reviving Dead MailMate Shredder
 by DavAnt
Featured
Step 2: Gut the beast and evaluate what you can do with what you have.
In my case, I had no clue as to what was broken, so I just removed the circuit board and cut the wires as close to the board as possible, in order to give me some room to move later on. I of course kept the board for any salvageable components in a future project.
Apparently, this shredder came in a version with an AC motor, and a version with a DC motor. I have my doubts about reversible AC motors... correct me if I'm wrong, but nonetheless... When taking out the motor, check for a sticker with the specs. In this case it's a 120V DC motor. Note that there are 4 wires coming out of the motor,and two of those are obviously the DC power wires since they are black and red. The other two are blue, and from what I can tell, they are probably from a sensor of sorts, since there was an overload LED on the cover.
The fact that this is a 120V motor can be considered a good thing, since no transformer will be needed in the new circuit. We now also know that we need a way to convert 120V AC to 120V DC.
Enter the magical world of rectifier bridges!
Note : the actual voltage from the outlets in your home may vary.
If you dig a bit deeper, you can find a micro switch that cuts power to the unit if the bin is removed. Leave it be. I won't talk about it either in the following steps. Just remember that it's part of the AC wiring.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
