iImage Information
In this instructable I hope to convey upon everyone how easy it is to turn old furniture ino a showpeice that you will have for years to come.Whether it is something you were given from your family or something you found on the side of the road (as long as it is structually sound). I will usually refinish just the parts you can see since there is no sense in worrying about areas you'll never see. For demonstration purposes only I will just be doing the draws of a desk I was given. The items you will need are as follows:
Sandpaper in assorted grits ( for this project I used 40 and 80 grit)
Sander ( electric or hand but electric is far easier)
Stain ( in your choice of color)
Polyeurethane ( you can use a polyeurethane and stain mix and still get great results)
Paint brushes
Rags
Rubber gloves
Dust mask
The difference betwwen the beginning finish and the end result makes this all worth it.
Step 1Removing the old paint/varnish
iImage Information
The first thing you should do is check that all the drawers and doors open and close freely, if they don't now is the time to adjust them or sand them so they work correctly. After you have everything working properly you start removing the old finish by sanding all the surfaces that are visible. Once the finish is completely removed you can switch to a finer grade of sandpaper. You will notice the differance between the old finish and the new finish. On the sanded drawer you can see the beautiful woodgrain that some one thought of covering up so many years ago.
Once you have your surface stabilized level it. Build up some top finish leveling as you go and thinning your finish material more and more as you reach your final coat. Pro tip: Read the label for what the manufacturer recommends for clean up as an idea of what a good thinning agent might be for the product you are working with. Sometimes they just come right out and tell you what to thin with too but remember they're in the paint selling business so ... it doesn't really pay them to tell you how to stretch their product out.
I think a lot of painting is in the magic of thinning personally. I usually get a glass finish after 3 coats myself. A builder, a leveler, then a final spit polish.
Unless you really dig the fumes stay away from brushing lacquer. Putting lacquer down properly is pretty involved. All other modern finishing products are pretty great within their individual limitations.
Minwax and Varathane are good choices for paint finishes. I probably have Minwax's whole line of oil stains kicking around now. Well, maybe not that bad but easily dozens of quarts. Mostly I use their natural on things I make. Often I have to match pieces though then I need a lot of different colors.
When I strip furniture I use Zip Strip. Costs a bit but saves me a lot of work. I still have to sand it a little once it is stripped but sanding finish off can be hard.
I'm actually refinishing the top of a mid century modern table right now.
