Repairing Broken Hello Kitty Headphones
Introduction: Repairing Broken Hello Kitty Headphones
We have probably all had this happen to us at some point. You buy a decent pair of headphones, but after a few months, they break. The failure mode of these devices is typically (at least in my experience) the wires connecting to the speaker inside the headphones, or the wires connecting to the 3.5 mm jack. Interestingly enough, headphones are incredibly simple devices, and these failure modes are easy to correct. The headphone jack has three (or four) terminals (the 4th terminal can be for a microphone or for volume control as with Apple earbuds). The two outermost (away from the wire) terminals are the signal line, for the left and right sides respectively. The terminal closest to the base is ground. Inside the earphones is a speaker.
Each speaker has two terminals: signal and ground (or common). The wiring is simple. The ground terminal on the headphone jack connects to ground on both speakers, while the two signal terminals (for left and right) go to the left and right speakers respectively. It does not appear to matter which signal line you connect to the left or right speakers. It appears to work either way. There is probably some manufacturing standard, but I do not know what that is and you do not need to know that for this to work.
I bought my little sister these headphones a while back and they broke in a year or so. In response, I am fixing them for her. In this Instructable, I will demonstrate to you how to rewire a pair of broken headphones.
Step 1: Gather Up Your Tools
1 x soldering station (iron, solder, flux, helping hand, whatever you need)
1 x broken headphones
1 x replacement 3.5 mm jack
some jumper wire - I recommend 28 AWG or smaller
Step 2: Determine Your Failure Mode
You should figure out what part of your headphones is actually faulty. You can do this a few different ways, of course. However, this is how I did it.
  • I took a male-male 3.5 mm jack. This means the jack is on both sides. So something like this.
  • I connected some alligator clips to one of the signal terminals and to the ground terminal.
  • I plugged the other end of the jack into my iPhone
  • I connected the other end of my alligator clips to the speakers of the headphones.
  • Played a song.
  • If I heard sounds out of the speakers, that meant the speakers work and the failure is somewhere along the wire
  • Result: speakers work
  • Next action: Replace the wire
If your speakers do not work, then your speakers are probably broken and need to be replaced.
Step 3: Remove Outer Casing
This is pretty obvious. In order to get to any of the wiring, you need to remove the outer portion of the headphones to expose the connections. These Hello Kitty headphones came apart really easily.
Step 4: Desolder the Current Connections
When you take a look at the speaker, you can see the wires connecting to the two terminals. I don't think that there is a specific "ground" on the speakers. I think it can go either way. Again, there is probably some manufacturing standard that I am not aware of. I noticed that one of the speaker terminals was colored green and the other was colored red. This was consistent for both speakers. I chose to designate the green as ground because green typically denotes earth ground.
Step 5: Solder Your Replacement Wire
Again, pretty self explanatory. Cut yourself a good length of wire and solder it to the terminals on the speakers.
Step 6: Solder Your Wire to the Replacement 3.5 Mm Jack
Solder the two ground wires to the ground terminal of the 3.5 mm jack and the two signals wires to the signal terminals.
Step 7: Add a Little Bit of Tape to Keep Your Wire Together
I used a bit of tape, about an inch long, and taped the wire together so they do not get tangled. The bits of tape were spaced about 6 inches apart from each other.
Step 8: Enjoy Your Headphones
Clean up
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Ah, why wasn't this here a year ago? One of the wires in my old headphones broke and I had no idea how to fix it! Oh, well. I'll just stick with earbuds=). Great job!
    Earbuds break in the same way, so you could apply this fix as well. Hopefully, you will never have to do this, though ;)
    Excellent tutorial! I love seeing projects like this that cover common fixes we're all going to need at some point or another. Nicely done!
