Step 2Tap into the UPS
Drill two holes in the side of the case. The holes only need to be large enough for the wire to pass through. You don't want the connectors to be able to sneak outside the case, to be safe. Make sure there are no sharp spurs or edges around the holes that might cut or damage the insulation. Thread the wires from the inside out, with the connection inside the case as shown.
As noted in the parts list, you'll want to keep the wires short to minimize voltage drop, but long enough that you can place the UPS and batteries comfortably near each other and the device you're powering (computer, stereo, etc.). Lay everything out, including battery box(es) if desired, and clip the wires to an appropriate length.
Add Comment
