3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rework a UPS with Massive Capacity
Step 3Connect the Battery / Batteries
Here's where you connect up the battery or batteries. Remember that the batteries are likely charged and can supply a LOT of current. I think there's another Instructable that tells how to use them for welding. You do NOT want to do any welding, so make all crimped connections before you connect them to the batteries!
If you have two batteries, make sure to cut a short piece of wire before you add the ring terminals to the other end of the wires you connected into the UPS wires in the previous step. Make sure that this jumper wire is not too short if you are putting the batteries in containers (see end of article).
Note: You might have to ream out the inside of the ring terminals if you could not find terminals with the right inside diameter.
Once you know that the ring terminals will fit, crimp them to the red and black wire ends. If you have two batteries, make the jumper with the other two ring terminals and the small piece of wire you cut off.
Connect the red wire to the positive terminal of one battery. Connect the short jumper between that battery's negative terminal and the positive terminal of the other battery. Then connect the black wire to the negative terminal of the second battery. If you do not connect them this way, you will not get any power into the UPS.
6 comments
Nov 10, 2009. 3:32 PMdwltn says:
These batteries are not sealed like the ones that came out of your UPS. This means that the gas produced when they are charged (hydrogen) will be released into your storage area. Use longer wires and place the batteries outside to prevent a possible explosion when you turn on a light. ( think Hindenburg)
Nov 11, 2009. 5:36 AMdwltn says:
 The wire is pretty cheap. When we install large UPS systems (for data centers) we need direct forced air venting to the outside by code. You know someone's wife or girlfriend is going to make them hide it in a cabinet and close the door to keep the house presentable. Any switch or relay (present in some of the older systems) makes a great ignition source. Outside would be better. New sealed batteries start around 30$, new (and more efficient) units are in the $100 to $150 range. new house is in the 100,000 range. Caution and more caution
Sep 3, 2009. 11:59 AMpedxing says:
please note that even unplugged, with the battery disconnected, you can get a nasty (perhaps fatal) zap from the capacitors inside the unit. Be very careful when working around the circuit board - don't touch anything but the insulated wires.
Aug 31, 2009. 8:22 PMosgeld says:
For large terminals check out places that sell car audio
if you can find a place that sells this to the public
http://www.theinstallbay.com/product_section.php?pn=1
nothing special but cheap :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:Surferdude
