3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ribbon Cable Wrist Bracelet
Use a small ribbon cable to make a nerdy, but stylish wrist band/bracelet. All you need is a small (in length) ribbon cable, ideally around 8 to 10 lanes, a pair of pliers and something to snip plastic and thin metal (I used a pair of wire cutters). Obviously when I say small in length, I mean the sort of length that is ideal for your wrist circumference.
You can find the sort of cable you need in old computers. They are normally at the back of the metal PC casing, and you need to unscrew it from this.
Step 1Dismantle the plastic cased end
Use a pair of pliers to take out the screw-type objects that connect the plastic housing to the metal part. You cannot unscrew them because they are not screws- they are like bolts, with annother thread inside. They are for when you have annother component to attach into it, with the little screw thingys on the wings of the casing, like for a monitor cable.
After unscrewing the plastic casing, snip it open and get it off the wire( you cannot slide it off as both ends have parts attached that are larger than the gap in the plastic casing). Discard the plastic.
3 comments
May 10, 2009. 1:30 PMpenguinlord1313 says:
a belt would be pretty kickass =D
Nov 7, 2008. 1:57 PMfwjs28 says:
better pics plz...oher than that very creative
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mishypie
