Some sewing experience recommended but it's easier to make than it looks.
Step 1: Supplies
What you need:
Ribbon (Any type of cloth ribbon will work. The type that you can curl with scissors won't work)
Sewing needle
Sewing thread
If the ribbon has wire in the edges, remove the wire once your pieces of ribbon have been cut by simply pulling the end of the wire straight out. If the wire isn't already sticking out, push the edge upwards till a small part of the wire is sticking upwards. This small part can be bent down and pulled out.
I usually use ribbon that is 1.5 inches wide, in which case the length of the pieces should be about 3 inches.
WriterChick says: Dec 29, 2012. 9:02 PM
What a great idea! Thanks for sharing it with us.
Penolopy Bulnick says: Dec 29, 2012. 7:31 PM
These are really cute! That last one looks so complicated! Was it hard to make?
llash-rosenberg (author) says: Dec 29, 2012. 7:41 PM
Thank you! It's actually just the same flower, but there are 2 stacked on top of each other. The fake pollen you can just buy and sew underneath the pouch!! It's a bit more difficult but not by much.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
