Step 3: Find Neutral
Unlike in a manual transmission car, finding neutral can be quite confusing for a new rider. Neutral is almost hidden on motorcycles and simply switching between gears will not get you into neutral.
Before starting your motorcycle, you should ensure that it is in neutral.
1. Pull in the clutch lever.
2. Press down on the gear shifter and release it repeatedly until you are in first gear (it can no longer be pressed down).
Note: If you cannot press the gear shifter down than you are already in first gear.
Note: You will hear a click every time you switch a gear.
3. Place your foot underneath the gear shifter.
4. Slowly press the gear shifter up until it clicks. The gear shifter should be about half way raised.
Note: Neutral is between first and second. It isn't really its own gear which is why the shifter is only halfway raised. Pressing the shifter up all the way will put the motorcycle into second gear.
5. The green neutral (N) indicator light will turn on when you are in neutral. If it did not, repeat from step two.
6. Release the clutch lever.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
