loading
Step 6: Turn the Motorcycle
Now that you are comfortable with where the motorcycle starts to move you should now practice turning. Motorcycles turn much differently when they are moving slowly than when they are moving quickly. Under 10 miles per hour (or so) motorcycles use conventional turning. If you want to go right you turn the handlebars right, if you want to go left you turn the handlebars left. A trick to turning with motorcycles is to always look through your turn. That means that you are looking at where you want to go the entire time you are turning, not in front of you. Again, the motorcycle wants to go where your head is looking.
       Tip: Do not pull the front brake whenever the handlebars aren't square, especially at low speed. This can cause the wheel to lock up and the bike to fall, taking you with it.
1. Release the clutch to the friction zone and begin to accelerate.
2. Add a small amount of throttle.
3. Continue releasing the clutch and adding throttle until you are moving at 8-10 MPH.
3. Look at where you want to go.
4. Turn the handlebars in that direction.
5. Even out the handlebars as you finish your turn.
6. Ride around in any pattern you like, practicing your turns. Remember, turn left - go left, turn right - go right. Be sure to stay under 10 MPH.
        Tip: A weaving pattern or a figure-8 are both great.
<p>Really great tutorial for riding a motorcycle.</p><p><a href="http://www.earmoldsydney.com.au/motorcycle-ear-plugs/" rel="nofollow">Motorcycle Ear Plugs</a></p>
<p>So what happens if i was strolling at 60kmp on 3rd then red light comes up, (I would normally pull in the clutch, front brake, rear brake and down shift to 1st, all at the same time) then green light suddenly comes as Im slowing down. (I pull out clutch, then give gas) but my bike get jumpy and it gets rough. Ive been having that trouble.I have ninja 250</p>
You need to watch a couple of videos on rev matching. I pull in on the clutch, and i might downshift 1 or 2 depending on my speed. I only shift back to 1 if im 100% sure that i have to completely stop or my speed and revs are low enough. Im on a ninja 300.
<p>Although this 'scructable provides great advice, when taking a certified course, upon completion, a certificate eliminates the need to take a road test at the DMV to get a Motorcycle Endorsement on your Driver's License. A road test in front of a DMV employee is a very stressful event for most new riders.</p>
My state and several other states don't care who says so. They want at least one &quot;road test&quot; before they will believe you at least know the basics and don't fall off or hit things too often. <br>When I took my first test (1964) the &quot; examiner &quot; had the discretion to ride on the bike with you DURING the road course/test portion! That after you got a permit to pratice &quot;under supervision&quot; of a certified motorcycle licensee with &quot;more than&quot; one year licensed &quot;experiance and drive you to the examination station and prove same.<br><br>I don't think you want to but: Sir, I pushed the bike hear manually wit the engine off. Then pick the coldest day with as much rain/sleet as you can take.<br>I brought a Honda with a step thru frame and &quot;automatic clutch&quot; (centrifugal) with an electric start so i wouldn't fail by stalling the engine taking off from a stading start. (I forgot to turn the gas valve petcock back on before the &quot;test&quot; and the ran out of fuel and quit. <br><br>The electric starter and my academy award acting skills got me throught it?<br><br>Take the course, talk to veteran riders, look at the crash pictures/visit hospitals and artificial limb shops ( my dad worked at one, mom loved me too much and signed for me) then and only then: forget the whole thing!
<p>The MSF Basic Rider course only grants an excemption for the raod test in certain states, check your local laws.</p>
I got my license, yay!
Ride on! Congratulations and condolences, pick one.
Xaqfixx; <br>My state and several other states don't care who says so. They want at least one &quot;road test&quot; before they will believe you at least know the basics and don't fall off or hit things too often. <br>When I took my first test (1964) the &quot; examiner &quot; had the discretion to ride on the bike with you DURING the road course/test portion! That after you got a permit to pratice &quot;under supervision&quot; of a certified motorcycle licensee with &quot;more than&quot; one year licensed &quot;experiance and drive you to the examination station and prove same.<br><br>I don't think you want to but: Sir, I pushed the bike hear manually wit the engine off. Then pick the coldest day with as much rain/sleet as you can take.<br>I brought a Honda with a step thru frame and &quot;automatic clutch&quot; (centrifugal) with an electric start so i wouldn't fail by stalling the engine taking off from a stading start. (I forgot to turn the gas valve petcock back on before the &quot;test&quot; and the ran out of fuel and quit. <br><br>The electric starter and my academy award acting skills got me throught it?<br><br>Take the course, talk to veteran riders, look at the crash pictures/visit hospitals and artificial limb shops ( my dad worked at one, mom loved me too much and signed for me) then and only then: forget the whole thing!
Excuse the spelling. I can't and the spell check won't?
Reply if you can't decide the pros and cons, I've made most of the mistakes and had a lot of fun: so far.<br><br>Live long and ride safe!
You may want to also try releasing the throttle before any up or downshifting then pull in the cluch as the RPM's fall/slow at first.<br><br>Power shifting is an art, sometimes accompanied by a death wish and or a large reduction in net worth!<br><br>Furthermore &quot;Kicking&quot; the gear shifter has a similar effect yet mostly to a lesser degree.<br>Press it gently and smoothly at the right time will reduce the pucker factor and increase your sucess rate of staying alive and solvency. <br><br>Forget that start up heel toe rolling/rocking or your orthopedic knee amd ankle surgeon's will take better vacations and tell you the same thing. Wear apprpriate footwear; no shower shoes or sandals! Maintain balance asyou slowly accelerate from a stop and your foot will appear to raise itself then place it upon the peg. Stop and go uphill is another story. Yet allow tje egine to go slightly faster than the stoped rear wheel untol both wheels roll the sme speed as you fully engage/release the clutch SLOWLY AND SMOOTHLY until it is time to upshift as the speed and RPMs dictate.<br>Wear extra clothing until you can do that without having to constantly think about it amd then keep wearing extra or protective clothing at the least from now on.<br>Pain, surgery, medication and rehabilitation costs much more and you can't give it away or sell it.<br><br>If you decide the safety coyrse is a very good and basic start. Old age is an excellent end 8-)
<br>Can i watch you do that: left turn- push the left handlebar away from you! Right turn, push the right handlebar away from you! While looking in the direction of the turn you want to make/ are going to go.<br><br>Let me get this straight. After riiding for 52 years. and 12 bikes if i want to turn left, look left and PUSH THE LEFT HANDLE BAR AWAY FROM ME? <br><br>What do I do as I slide down the roadway on my left knee, left elbow and nose?<br><br>Actually: you can try thst on a mile dirt track: At 120 MPH push the left handle bar away from you as you lean left but, look right as the bike is dancing on it's fron wheel next to another rider or the fence and rhe rear wheel is going faster them the front wheel sideways to your right. Continue to pull right handlebar and slide your steel left foot plate on the ground behind the dancing front wheel until yoi are out of the turn then reverse the procedure until you ane straght and perpendicular to the track and accelerate harder into the next left turn. Try that on asphalt or a concrete track ad you will win or punch a hole in the fence.<br>On a regular day and on a regular motorcycle just pretend it's a bicycle but with out pedals but a motor!<br>Twist the right handle bar down (counterclockwise) make the front wheel go up and twist it up (clockwise) to make the front wheel go down.<br><br>If anything happens you don't expect; 99% of the time pull in the clutch first and prey you do the right thing next!<br><br>I fell a few times at an obscene speed but I lived to tell theis tale.<br>Do likewise, else slower
<br>Can i watch you do that: left turn- push the left handlebar away from you! Right turn, push the right handlebar away from you! While looking in the direction of the turn you want to make/ are going to go.<br><br>Let me get this straight. After riiding for 52 years. and 12 bikes if i want to turn left, look left and PUSH THE LEFT HANDLE BAR AWAY FROM ME? <br><br>What do I do as I slide down the roadway on my left knee, left elbow and nose?<br><br>Actually: you can try thst on a mile dirt track: At 120 MPH push the left handle bar away from you as you lean left but, look right as the bike is dancing on it's fron wheel next to another rider or the fence and rhe rear wheel is going faster them the front wheel sideways to your right. Continue to pull right handlebar and slide your steel left foot plate on the ground behind the dancing front wheel until yoi are out of the turn then reverse the procedure until you ane straght and perpendicular to the track and accelerate harder into the next left turn. Try that on asphalt or a concrete track ad you will win or punch a hole in the fence.<br>On a regular day and on a regular motorcycle just pretend it's a bicycle but with out pedals but a motor!<br>Twist the right handle bar down (counterclockwise) make the front wheel go up and twist it up (clockwise) to make the front wheel go down.<br><br>If anything happens you don't expect; 99% of the time pull in the clutch first and prey you do the right thing next!<br><br>I fell a few times at an obscene speed but I lived to tell theis tale.<br>Do likewise, else slower.
<p>Just take a class, most community colleges have a one for cheap and lowers your insurance when you finish. Most have their own bikes too.</p><p>★★ Signature: &trade;<a href="http://www.hideplate.org/" rel="nofollow">Hide Car/Motorcycle License Plate by Remote</a>&trade;★★ <br></p><p>.</p>
it's too dangerous to learn it yourself. you should take a teacher, it's better not to ride on a motorcycle at all.
I taught myself on my dads 1500cc Vulcan. Started in the driveway. Ended up riding it for a year then bought my 440LTD, someone hit me, now have a Rebel. Just like riding a bicycle.
Yeah, well, you know, that's just, like, your opinion, man.
it's really dangerous
just letting you know i taught myself to ride on a 50cc dirt bike when i was 12 i am now 21 and my only accident was caused by somebody that ran a red light, there was nothing any class or instructor could have taught me that would have stopped the other driver from hitting me. this being said the est thing you can do is be alert and wear your safety gear
So is driving a car. Or walking down the street. Or smoking. Or cooking. <br> <br>Also, if we're not here to learn something by ourselves, why are we on instructables in the first place?
Solid instructable. I had taken a MSF class a couple years ago and read up using your guide it was helpful getting the mental check list back in you head. Once you know how it feels / how to counter steer it stays with you forever.
thank you for going in to detail on the safety gear, i would not be hear today if i wasn't wearing mine. i live in a tropic climate where every day is ridding weather and i see guys ridding their motorcycles in shorts a t shirt and flip flops and it drives my crazy when i see somebody being that dumb
I learned to ride on a big pile of sand near Corona. Sand is a good thing to fall on, better than grass or asphalt, if you're gonna fall, and you will likely fall. Then take a class or three. When you do get out on the road, ride like you are invisible, because you are, simply because you are not a car, and that's all most folks are looking out for.
Hey! I'm super glad you are promoting safe riding, and for the most part you are putting verbatim from your MSF class. But there needs to be a change to how you talk about high speed steering. <br><br>The way you put it, the wheel is actually going to turn the opposite way from where you want to turn. Someone back in my MSF class actually tried this at 20 mph. Leaning right, and FORCING his wheel left, instant high side. This is not what you do. <br><br>The push right, turn right is just that. By putting pressure on the inside handle bar, the gyroscopic forces of the front wheel will initiate the lean and turn. The more pressure you put, the harder your bike will lean. But if you pay close attention to your hands, as you push, the bars will push back, and your hands will move in the opposite direction you push. <br><br>My reccomendation, before you try and conciosly create counter steer, get to 15-20 and let your instincts take over. Look and lean into your turn, and the bike will follow. Once you're comfortable, then figure out exactly what is going on with the bars.
That is a good recommendation but counter-steering and leaning is initiated by the handlebars briefly turning in the opposite direction of the turn. It's a subtle turn of the handle-bars, nothing nearly as pronounced as in a low speed turn.<br><br>You are definitely right by saying the handlebars aren't completely turning like in a low speed turn though as that could lead to a nasty high side.
This is a good walkthrough. As a fellow rider I started only 6 months ago and have fallen in love with riding. My uncle taught me to ride around the back lane before taking me out on the open roads. But I will say many motorcycles handle differently i.e. A chopper or sled has a much wider turning circle compared to a sportsbike or dirt bike. Just take it slow and ease into it.
I learned on a cruiser and dirtbike, then bought a sportbike. The sportbike is a sail in the wind unless you get right down on the tank, the cruisers feel very top heavy and the dirtbikes have really twitchy throttles. Practice practice practice until you're comfortable! <br>Very good and detailed instructable! Wish I had this when I started out.
I have been riding since 1964 ! Many moons ago! Over the years, I have owned many motorcycles. I still ride and own four. It is the most free and rewarding thing to do on two wheels. But lately, due to the increase in driver distracting toys (GPS, Cell Phones, Cameras, video players, DVD players, TEXTING, etc...) in autos, there has been a great number of accidents (many deaths) with motorcycles getting run down! A few of my riding buddies have been victims ! I now get very cautious and concerned when I ride and see people that are not paying attention to the road and ME!! So now I ride less and worry more about my next ride! Will I live to see another day, because of someone being stupid? Think about this! Call and or email your state politicians, especially NEW YORK, to get them to pass the law that says: NO TALKING OR TEXTING ON PHONES! It will save your life,maybe! Thanks, Live to ride, ride to live! Triumphman
We've had those laws here for several years now, really anything that can distract a driver can earn you a ticket here. It doesn't help because there just aren't enough police to enforce it. I have a Kawi Ninja 636 and every single ride I go on I'm dodging people in cages not paying attention. Just yesterday a car packed with teenagers came 2 or 3 feet over the mustard at me and laughed their arses off as they passed me. Hours before that, going through an intersection someone who was paying attention didn't see me, then when he did see me he panicked and stopped dead right in front of me as I was leaning, it was close. Getting cut off and dumping your pretty new bike is not fun folks, you really have to watch for EVERYONE! Including the cop who suicidally ran out into the middle of the road to stop me...
insted of ''gear up '' why not ''armor up''?
This is an awesome walkthrough! Lots of good tips.
About This Instructable
441,783views
106favorites
License:
More by eeverett:Riding a Motorcycle
Add instructable to:
