Rig Remover
Published
Introduction: Rig Remover
This tool in stop motion pro 7 let you remove images from one photo by replacing it with images from other photos
In this one I we'll be making someone fall off a building
Step 1: What to Use It on
So the reason to use this tool is to remove prop holders or rigs so you will need a photo or video
Step 2: Finding the Program
To find rig remover look under tools and there should be a blue square
Step 3: Sub Tools
Eraser
Shape mover
Shape drawer draw around your shape so you don't erase stuff you need
Undo the last thing you did
Redo the last thing you did
Step 4: The Other Side
Find a slide that looks alike using the arrows in the red
Step 5: Removing the Rig
So now click on the eraser and drag it over the rig
Step 6: Example
Step 7: Fine or Tricky Bits
Use the radius tool to make the eraser smaller or bigger
Step 8: Example
Step 9: The End
The hit next to move switch slides
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
