Introduction: Right Angel Weave Bracelet Tutorial-Make an Embellished Red Bead Weaving Bracelet
This is a right angle weave bracelet tutorial. Hope you like this embellished red bead weaving bracelet patterns. In this right angle weave bracelet tutorial, you don't need to learn some complicated beading skills, because it is a very simple bead weaving bracelet pattern. Here I choose red beads to make this embellished right angle weave bracelet so delicate and festive. Now let's begin.
Step 1: Materials on Embellished Right Angle Weave Bracelet
8mm red glass beads
2mm white seed beads
Lobster clasp
Jumprings
Tiger tail
Wire cutting plier
Flat plier
Step 2: Make Basic Bead Weaving Bracelet Patterns
1st, cut down a 100 cm tiger tail, fold it in half, thread 10 seed beads to wire, cross both wires through a red bead and tighten, add 1 red bead to each wire, cross both wires through a red bead and tighten; add 3 seed beads and 4 red beads to upper wire, thread the wire back through the first red bead and tighten, do the same with the below wire;
Step 3:
2nd, add 3 seed beads to each wire, cross both wires through a red bead and tighten, add 1seed bead to each wire, cross both wires through a red bead and tighten, that is the basic beading pattern;
Step 4:
3rd, continue this pattern until reach ideal length;
Step 5: Finish Bead Weaving Bracelet Patterns
1st, cross both wires through 10 seed beads and then cross both wires through the last red bead, add 12 seed beads to upper wire, thread the wire to the upper bead on the red bead rhombus, add 12 seed beads again, thread the wire to the upper bead on the next red bead rhombus;
Step 6:
2nd, continue until reach the end, do the same with the below wire; thread the wires back to adjacent beads to fasten the beaded strand;
Step 7:
3rd, at last, connect the embellished right angle weave bracelet with jumpring and lobster clasp;
Step 8: The Final Look of Red Embellished Right Angle Weave Bracelet:
Now the right angle weave bracelet tutorial is over. Do you like this red embellished right angle weave bracelet? Besides, you can use pearl beads and seed beads to make a right angle weave bracelet. Just take a try, create your own bead weaving bracelet patterns.
