Ring Box
Introduction: Ring Box
This ring box is made from purple heart and beech. A simple box for a special occasion. This box can be completed in a few hours.
I was asked to make this box for a friends son who has now proposed to his girlfriend i was delighted to be asked to make the box and im happy to report she said "yes".
2 inch square of purple heart wood.
1 inch x 2 inch of beech
3mm brass rod 2 1/2 inches long
3.5mm drill bit
1/4 inch bandsaw blade
1/8 inch bandsaw blade
Sand sealer
Clear lacquer
Foam to hold rin in box
Step 1: Step 1
Cut the purple heart to 2" x 2" square
Cut Beech to 1" x 2"
Get the 3mm rod, and 3.5 mm drill bit
Use a compass to draw a circle at top right of purple heart this will be the hinge for the lid so does not need to be big just needs to have a centre mark so you can drill the hole for the rod.
Draw the design of the lid and box on side of purple heart.
Step 2: Step 2
Drill hole in purple heart making sure the wood is square so the drill hole is straight.
Cut the lid out on the bandsaw using 1/8 inch blade
Cut box out ( Dont make the sides to thin 1/4 inch should be enough to make a strong ring box)
Thats the box all cut, Now for the sides
Step 3: Step 3
Draw around the box onto the beech put a marker where you want to drill.
Drill hole for rod
Put purple heart on top of beech wood place rod through as a guide to draw around box shape
On bandsaw with 1/8 inch blade cut around box shape this does not need to be to close as this will be all sanded once glued up.
Using 1/4 inch blade cut down the centre of beech to make the two sides
Looking good time for glue up
Step 4: Stap 4
Glue up box (DONT PUT GLUE ON LID) just on box bottom put rod in for glue up
A few hours should be fine but to be sure leave overnight
Sand the box with lid in closed position
I used a small dremel tool sander to make a dip in wood on lid to help with opening lid
Time for the finish
Step 5: Step 5
With a small brush i used 50/50 sand sealer and cellulose thinners
one coat was enough for me
when dry give a very light sand
one light spray of clear lacquer
Cut the foam and place in the box
All done congratulations
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Great design!! This really turned out beautiful.
    Yeh was delighted with finish. Thank you
    beautiful design and box but you really need to tension that blade and set up your bearings correctly...
    Lol yeh you are right thanks for comment
    ooops sorry , just saw the end about tensioning...
    love how it looks reminessant to a tiny treasure chest! excellent design! voted!
    Thank you so very much.
    Very nice. I'm glad I took the time to watch the whole video
    Thank you very much. Im not very good on camera but as long as it does not distract from the purpose im happy.
