3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rio Riot overhaul
Rio Riot overhaul
*** As with all instructables, you are taking your item / health / whatever into your own hands. Be patient and careful and you will be successful ! ***
This is my second instructable.
I bought this player on the internet, hoping that a firmware upgrade and a new battery would solve the 'low battery' message problem.
It was a fight to install the new firmware (since you can't skip the warning message), and when the new battery was installed and charged the warning still wouldn't go away.
The only other major component was the HD, so I picked one online and viola ! It works !
I would recommend reading this entire instructable before starting the project. It's not that long, and could help you avoid breaking something that isn't easy to fix !
Step 1Disassemble and replace battery
The Riot has 4 torx head screws holding it together. I found that a 2mm straight tip screwdriver works well in removing these screws.
After you take the screws out, gently lift the top cover off. The volume control is a single part that is easily removed by lifting it straight up, and the power button removal is the same.
Now gently remove the entire assembly, being careful to grab the battery (on the left side) as soon as possible to keep it from damaging the connector, or breaking a wire (don't let the battery dangle by the wire !)
Gently remove the battery plug from the connector and place it aside.
If you're just replacing the battery, do so, then put it all back together, paying special attention to the battery temp sensor. Be careful not to pinch the wires, or break the connections on the board, or the player will not work !
Here is a link for the Riot with battery recalibration information, firmware updates, manuals, etc.
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=2
If you're just replacing the battery, you are finished with the hardware part. Now go to the link above and follow the directions on how to properly calibrate the battery.
If you are going to install the HD as well, head to the next step.
7 comments
Jun 14, 2011. 5:26 AMmmaroni says:
Hi TheRealAnubis how did you change the PCB on top of the battery to the replacement? Is there anything I need to watch for?
May 1, 2010. 1:11 AMshaysab says:
 i am about  to change the hard drive but i really don't know if it going to support a bigger one (40gig or 80gig)!!!
Nov 18, 2008. 1:09 PMtricia70 says:
what is the part number for the rio riot battery?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:TheRealAnubis
I usually end up doing an instructable because I have to figure out how to do something myself. I just get pictures during the process, and if it works out, BOOM, an instructable!
