#RioVisivel - Build Your Own Podia
Introduction: #RioVisivel - Build Your Own Podia
Download instructions to print or view online.
Step 1:
Find Pallet and dismantle it. Keep all the timber planks
Step 2:
Hammer the sharp end of the nail and use pliers to remove the nails completely
Step 3:
Measure crate and cut supports and top pieces to fit, allowing for a 15mm overhang on all edges on top crate, and the three outer edges on the two bottom crates
Step 4:
Screw supports into place
Step 5:
Screw top pieces to the supports
Step 6:
Cable tie the crates together - how you do this may change depending on the type of crate you have chosen
Step 7:
Measure sides and cut pallet wood to fit. Screw in place
Step 8:
Measure front and cut pallet wood to fit. Screw in place
Step 9:
Add a kick board to the sides at the bottom
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Nicely Done. the only change I would recommend is to either add planks or some sort of fabric to the front face to hide the crates and give it a finished look. If you really want to take it to the next level .. do one side with planks and the other side with fabric .. that way you have two choices of "faces" to present to the audience
