3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rip, Burn, Copy DVD Movies - The best, simplest way.
This instructable explains how to copy whole DVD movies, including compressing them so they fit on cheaply avaliable 4.7GB blanks.
Software needed: (check out www.doom9.net for downloads)
- DVD Shrink
- DVD Decryptor
Hardware needed:
- DVD Movie
- DVD Blank
- Computer, DVD Burner, etc.
This will be the basic instructable, showing how to copy a full disk with some changes to compression of the disk to give best movie quality. If there are enough requests I will write an advanced instructable to show how to copy only the main movie with no menu's or extra's (for large movies to get greater quality).
  • Obviously only copy DVD's that you have rights to copy, copying commercially made movies is a breach of copyright and ILLEGAL!
Step 1Overview of DVD Shrink
When you open DVD Shrink this is what your window will look like.
Mouseover the window below to view description of the main screen.
73 comments
1-40 of 73next »
Jul 23, 2010. 8:19 AMgreenwaldc69 says:
i have dvd fab i use to burn movies on a reg dvd disk . now when doing so it tells me pls insert a double layer media disk . why does it do this now and how can i get it to go back to a reg dvd copy
Feb 12, 2011. 11:44 PMacs1207 says:
some where in 'options' or 'settings' , the target size can be set. It should be 4.7 GB.
Aug 16, 2010. 2:47 PMmatheshphy says:
Hello, Can we burn audio files on DVD disc ( not in MP3 or MP4 format)uncompressed file?
Feb 12, 2011. 11:47 PMacs1207 says:
If you have uncompressed audio files , you can create an Audio DVD by using Audio DVD Creator. DVD Shrink and DVD Decryptor is just for shrinking (DVD9 to 4.7) and backing up DVD Videos .
Jul 27, 2009. 12:05 AMcartoonprincess says:
does this process 'finalize' the disc? thanks
Nov 28, 2010. 12:01 PMpecker001 says:
yes it does. Look in the log once it is done and you will see it
Aug 29, 2010. 7:50 PMpgd5000 says:
when i open DVD Decryptor i gives me an error saying: ParseVTSM runtime exception! File: VTS_13_0.IFO Message=EAccessViolation if i click ok then it just comes up again. i have no idea what to do any help?
Jul 18, 2010. 9:49 AMcgoeppne says:
Try using DL-DVD.
Jun 2, 2010. 1:23 PMMy Sanity says:
Amazing instructions, thank you so much!
I made an account here just to thank you.
5/5
Jan 6, 2010. 6:10 PMyengvue says:
hi there i have a question:
 when you click on the backup icon and the window pops up ,
you have to slect the "ISO Image file and burn with DVD decryptor"
but somehow my only comes up as "ISO Image file" and there
is no DVD decryptor.? how come it's like that?
Feb 17, 2010. 11:02 AMnewbie888 says:
Hi Yengvue
Have you received a reply or resolved your problem, because I have the same difficulty.
Would like to know what to do about it!
Thanks
Jan 28, 2010. 6:01 PMkjwhytrym says:
This worked perfectly, even on backing up my disney movies for the kidds!!   THANX!
Jan 26, 2010. 11:18 AMchuggingacoldone says:
The Best way to burn absolutely ANY MOVIE, even if it's copyright protected is: buy Anydvd and clonedvd2 from www.slysoft.com anydvd removes the copyright protection from all movies including disney. then shrink the movie using dvd shrink 3.2 (freeware) then use clonedvd2 to burn the movie, it's the best! I should do an Instructable on this, I guarantee it's way better than this Instructable!!
Jan 6, 2010. 6:43 PMyengvue says:
thank you this works great!
Dec 24, 2009. 3:59 PMnpatters says:
 Using AnyDVD and Xilisoft DVD Ripper to rip Disney's "UP". very easy. copied .VOB in 15 minutes.
Dec 10, 2009. 9:51 AMraul3958 says:
I followed all of these instructions, but when I play it on the dvd player it doenst read it . The computer doenst read it too. What is happening here and how can I fix it?
Sep 10, 2009. 12:14 PMtmemphis says:
@ picture_man36: As for Disney copyright, Use DVD43 and 1Click DVD Pro.
DVD43 will decrypt the DVD when you insert in into the DVD Drive. before copying. DVD43 then allows you to use the Drive to copy the files off the DVD to anywhere. Copy and paste if you want from DVD to hard drive. But we just want to copy it from DVD to DVD. (http://www.dvd43.com/)
So!
just use 1Click DVD Pro. You select the DVD as the source and the DVD drive as the Destination, click copy and that's it. 1Click DVD Pro only copies, it does not decrypt the DVD, but that's already done by DVD43.
(http://www.lgsoftwareinnovations.com/1clickdvdcopypro.asp)
I like 1Click DVD Pro but you can use Nero, Roxio or whatever program your comfortable with.
Aug 9, 2009. 3:44 AMpicture_man36 says:
Hello. I've scrolled through a few of the suggestions, and also googled this problem, and it doesn't work. I usually use Magic DVD, and this doesn't get around the Disney copyright, nor does DVD Shrink, or Magic DVD ripper. I don't pirate DVD's. What I do do to protect my DVD is take a 'backup' which I allow my 6 year old watch and use. In the past, I've ended up buying the same DVD again, as the original has been scratched when we lent it out, or my son has been a bit careless. I would be appreciative if anyone knows of a program that actually works, and I am now wondering what to do when the industry changes its method of copyright protection. Thank you
Jul 24, 2009. 4:43 PMeveyyyx3 says:
i basically have the same question as "ironmanandy" i followed all the steps correctly up to this one. when i load the blank disk into the tray it says "Device not ready (Medium not present - tray closed)" i used different brands of dvds with different movies on two different computers too. can anyone tell me the problem?
Jul 18, 2009. 6:23 PMmrmoneybagss says:
i have another question. this (of course) works for movies, but will this work for games?
Jul 2, 2009. 2:54 PMmrmoneybagss says:
nice instructable. but i couldn't quite find the dowload button for the software. could you provide a direct link for me?
May 23, 2009. 2:32 PMthierry.kok says:
DVD shrink for live!!!!!!!
May 16, 2009. 9:16 AMsuesse says:
loved the easy step by step directions, thank you!! everything worked great, kids are watching the movie I just finished right now (so right now nothing wrong with it, well see). it took me some time but hey it was my first. i only tried with two for right now, and it was two because the first movie it didn't do anything, so i did a second one so now i just need to figure out why it didn't work with the first one.
Jan 16, 2009. 5:08 PMfoxpac_40 says:
why is it that when i get to this point of my dvd being donei put it into the dvd player and it doesn't read it
Apr 19, 2008. 9:04 PMkaran01 says:
hi when i open my dvd decrypter, it looks exactly the same as the one in the image but instead of it having the picture from the hdd to the dvd it goes from the dvd to the hdd, would u be able to tell me how to get it to go from the hdd to the dvd drive?
Dec 15, 2008. 5:11 AMisaaco2006 says:
yes, you go to mode, iso then write not read
Dec 7, 2008. 11:05 AMcollard41 says:
when i try to backup some new films (10000 BC) with DVD shrink it comes up with an error something to do with copyright protection. do you know how to get around this. apparently DVD decrypter can get around this, do you know how to rip DVDs with DVD decrypter? thank you
Jun 6, 2008. 5:36 AMWalter47 says:
MyspaceHi all!
I burnt a dvd useing this methode
- Decrypted the files useing dvd decryptor
- Shrunk the files useing dvd shrink
- Burned the shrunked files useing nero 8.
So I was watching it before and it started getting jummpy and skipping, after a while i got quite bad, stopping for 10seconds at a time. You guys got any idea or tips on how to fix this? Should I burn at a slower speed or somthing?
Cheers
Nov 8, 2008. 6:26 PMyokozuna says:
A lot of times a burned disc will not be supported by certain DVD players. It's a compatibility issue of +R or -R, the disc brand, and other related factors. The best way to go is to find discs that work in your player first, then try to burn movies to that type of disc. If your disc will play fine in another player (computers seem to be the best testing place) then you know for sure this is the problem.
Oct 3, 2008. 5:59 AMchikid68 says:
yes burn at slower speeds as it reduces the errors also if you unless you have a multi core cdu do not do anything else on your pc while burning the disk . I have used dvd shrink and dvd decrypter with great results.
Oct 3, 2008. 7:03 AMkburesh says:
Use Videora to convert to your ipod!
Jul 27, 2008. 5:00 PMironmanandy says:
hey how come when i insert my dvd-rw or my dvd+rw nothing happens, it says medium is not present. How do i make my computer read my discs?
Jun 2, 2008. 4:49 PMpatatoeman says:
I can never get the compression to go over 60% with out making the menu and extras still images. Any ideas?
May 2, 2008. 4:08 PMSwert says:
I could just totally be making this up in my head, but is that a video of openSUSE you are working with in step 4, second image?
Feb 27, 2008. 11:16 AMREAL6 says:
FOr me, the quickest way is DVD Decryptor then use Clonedvd2. Takes 20 minutes toatl between both. Ive done over 200 movies in about 2 months. best way!!!
Feb 26, 2008. 4:30 PMdkfa says:
I see this one that says DVDFab Decrypter 3.0.5.0 it says its always updated...is this one better?
Feb 20, 2007. 1:23 PMtrailblazer852003 says:
I am having trouble backing up disney dvds. Is there a way to copy them?
Feb 24, 2008. 8:05 AMidogis1 says:
Disney dvds use a different copy protection. If you can't copy with the program you are using then it will be pretty hard to do it with any other program. Sorry but your SOL.
Dec 5, 2007. 12:39 AMchuggingacoldone says:
buy anydvd at www.slysoft.com, I guarantee it works great!
Apr 30, 2007. 3:33 AMbinnie says:
lol "backing up" thats what i call it too:)
1-40 of 73next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:silliou
