3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rip UMDs from any PSP
FIRST OFF: You need a PSP with Custom Firmware 3.52M33-4 or higher. This guide is only on how to rip UMDs and not on how to hack the PSP into running CFW.
Disclaimer: THERE IS NOT A VERY HIGH RISK OF BRICKING YOUR PSP, BUT IF YOU DO, I HOLD NO LIABILITY FOR WHAT YOU DO IN THIS GUIDE REGARDING YOUR PSP.
Things needed:
PSP with CFW 3.52m33-4 or greater (there are guides for lower firmwares but this is for 3.52 or greater)
Computer
UMD (Movie or Game)
PSP USB Cable - NO MEMORY STICK READERS
Step 1Rip UMDs into ISOs
Rip UMDs into ISOs
Step 1: Go into the recovery menu (Boot while holding R), go into Configuration -> and change the XMB Usb Device (currently: ?????????) to UMD Disc by hitting X over the selection and hitting left or right on the D-Pad. Then exit the recovery menu.
You could also do Step 1 from the VSH menu. In the XMB hit Select (or Home on some versions) and the VSH menu will pop up. Change the USB Device to UMD Disc
Step 2: Connect The PSP to the computer
Step 3: Go into USB Mode on your PSP
Step 4: Open up your PSP which will be under the name of the UMD's ID#, and you will see a file called UMD9660.ISO
Step 5: Copy it to your Computer and Rename it to the name of your game.
Your Done Ripping!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:conradev(Kramer Software Productions)
Programmer. iPhone hacker. Geek.
