Riveted Maille from Scratch. by armourkris
Featured
There are already a number of Instructables on making maille, and making various projects from maille. The one thing that I found was missing was how to make riveted maille.
Now, in the past I've dabbled in riveted maille a bit, my maille and plates cuise (that's thigh armour) and all the repairs on my cuirass. Thing is, for those projects I went and bought pre-made rings and rivets then just assembled them. That is hardly the DIY ethic that Instructables espouses now is it? So with a quick prayer to the gods of tedium and insanity I decided to try my hand at making my own riveted maille, from scratch.
Riveted maille is really done 2 ways, wedge rivets and Round rivets. the difference is pretty self explanatory. Wedge rivets are tiny triangles, Round rivets are tiny bits of wire. To the best of my knowledge maille started out with round rivets, then at some point, around the 14th century i think, a lot of European armouries switched over to wedge rivets, whereas maille from the middle east and Asia stuck with the round rivets. that's all pretty generalized, but it gets the idea across.
In any case, I'm making maille sleeves for my armour and my armour is a near/middle eastern style. So, round Rivets it is.
Enough of my babbling, this seems like a decent enough intro. Now onto the good stuff.
Step 1: The Tools I Use.
Tool wise you only really need a few more tools then you need to make butted maille.
Here is what you'll need.
Standard maille tools:
-A pair of small pliers
-a mandrel for winding coils
-side cutters to cut the coils (these will be modified slightly)
The special stuff
-Rivet setting tongs
-a ring flatener
-a hammer
-a punch.
Now, to start with You'll need to grind or file a notch in your side cutters a little back from the tip. this will let you cut your rings with a little overlap. that's pretty simple.
Rivet setting tongs are pretty simple too. I made mine from a $4 pair of carpenters nippers. You could also make them from some linesman pliers, or really any pliers with about 6 inches of handle. just grind the jaws down till they are smooth and close flush, then take a 1/8" drill bit and put a little divot into one side of the jaws. that's all there is to it.
For flattening my rings I use a piston setup. I scrounged and scavenged mine. it's just a really big brake caliper from something, and 2 chunks of 1" steel plate, one of which has hole that's about the same size as the caliper on it. alternately, with some practice you can skip the piston and flatten your rings with just a hammer, or I've seen pictures of a Whitney punch with bits modified to flatten rings. My experience is that the piston setup has the quickest learning curve and gives me the most consistent results.
the hammer is pretty self explanatory, use it to bash stuff.
That just leaves the punch. Historically speaking you'd most likely have a set of tongs with a drift and a matching hole in them and you would just pierce a hole in your rings. A lot of people still use variations on this method. I've also seen arbor presses modded to hold punches or drifts. Myself, I'm using my knock off Whitney punch with a 1/16" punch and die in it. In the future I'd like to try re-working a punch into a drift to see how that works, but until then, I'll just punch holes.
Step 2: Making rings
Ok, so making rings for riveted maille is almost exactly the same as it is for butted maille. The only 2 differences are that you can use thinner wire, and you need to cut them with an overlap.
In this case I'm using 16ga. tie wire. you can usually find this stuff pretty cheap in most hardware stores. You're looking for the black stuff that leaves black crud on your hands as it is not galvanized and is already annealed.
My mandrel is an old roller from a garage door and is about half way between 3/8" and 1/2" I couldn't tell you exactly what size that it is but the rings look about right for the larger rings that seem to be common with near eastern armour.
Anyways, just wind your coil like you would for any other maille, then cut them with your freshly modded side cutters. You'll want to leave 3/16" to 1/4" of overlap.
Once you've got your rings all cut it's time to normalize them. This step isn't strictly necessary, but I
find it does help a bit. I get about 10% less bunk rings in the flattening stage if I normalize them first.
To normalize them I string them onto a loop of wire, then heat them up red hot and let them cool to room temperature. I'd heard you can do this on a gas stove, but my stove was taking too long. I prefer to use a blowtorch. Alternately I'm sure a BBQ would work wonders, or a fireplace.
Lastly, do not hold the wire with your fingers while you are blow torching the rings, it is a bad idea. Also, do not put the recently red hot rings onto anything flammable while they are cooling, it is also a bad idea.
Step 3: Flattening your Rings
Flattening the rings with a piston is as simple as putting a ring in the hole, placing the piston on the ring, and bashing it with a hammer. on my thigh it takes me 6 or 8 strokes. when i can put the anvil on something solid it takes me 4 strokes.
I find I get the most consistent results if i place the overlap facing away from me, parallel to the hammer handle.
Step 4: Punching the rings
To punch my rings I use a knockoff Whitney punch with a 1/16" bit. I think it's important to mention that historically the rings would have been pierced rather than punched as punching the rings removes a small amount of metal weakening the ring slightly. To this end I'm planning on buying another 1/16" punch and re-grinding the punch into a piercing drift. I'll update the instructable when I get to that point. In the meanwhile.....
The first thing to keep in mind punching the rings is that your overlap is sufficiently flattened, i try and have my overlaps flattened to the point where they are at least 1/8" wide and preferably a little closer to 3/16". I can still punch a hole in less, but i find that during the riveting stage the swelling rivet will often cause the sides to tear out if they are to thin.
Actually punching the rings is simple enough with the ton or so of pressure coming from the punch. just center the overlap on the die, under the punch and squeeze the handles.
Sometimes the punch will catch on one half of the overlap. if this happens and you pull the punch back the rings get deformed and are a pain to get out. to counter this problem I took a short strip of pallet banding and cut a small slit down one end with some tin snips. After I punch a ring I slip the strip of banding over the ring and around the punch then retract the punch. the banding stops the ring from getting sucked up into the punch housing and keeps everything laying nice and flat.
Step 5: Riveting the Rings
To rivet your rings shut the first thing you'll need are rivets. fortunately 16ga. wire happens to be 1/16" in diameter so it fits in the holes we punched perfectly. To make rivets just grab a foot or so of wire and cut it down into bits about 1/8" long. Now you have your rivets. Pretty simple eh?
To rivet a ring shut start by slipping a rivet through the hole. try and get it more or less centered.
Next take your set tongs and grab the rivet so that one end is in the divot then with smooth even pressure squeeze the tongs shut. This should compress the rived lengthwise causing it to swell on either side of the hole,leaving a flat bump on the bottom and a domed one on the top.
When it comes time to actually weave maille I like to rivet 4 rings, feed them onto a fifth ring then rivet it. I usually make a few dozen of these at a time then connect them all together. I don't think it's actually any faster than going one ring at a time, but it looks like it goes together faster, and that helps keep me sane.
As well riveted maille has an inside and an outside. if you're making for example a shirt the inside should have the flat sides of the rivets and the domed side should be the outside. I'm not sure if it really makes much difference in the long run, but that's how it was done back then, so that's how I'm doing it now.
1-40 of 105Next »
Timfee says: May 1, 2012. 3:22 PM
Man, this is fantastic . I wonder how you don't get mad doing this, but the result is beautiful . I love it . Congrats !
Gelfling6 says: Mar 11, 2013. 3:38 PM
it takes eons of patience! I've been knitting for close to 30 years now.. so, it takes patience, and lots of callouses.. (even with padded tools, you're going to compress skin at the finger joints.. it's unavoidable!) It's kind of a lost art that many still try to maintain.
armourkris (author) says: May 2, 2012. 11:08 PM
patience seasoned with insanity, lots and lots of insanity, you see, I do get mad, just not the angry kind of mad.
Gelfling6 says: Mar 11, 2013. 3:42 PM
Too true! I usually save that anger mad for the LARP, where its allowed (within a certain degree.) But, the insanity part? Oh yes, it's definitely a madness! As someone once put on the forum of "The Ringlord.com", "You have not attained the true insanity, until you have been commissioned to knit your own straight-jacket in E6-in-1" (Someone had that as their forum tagline many years ago.)
Gelfling6 says: May 14, 2012. 5:46 PM
I resemble that remark! :-D I've been making butted maille for close to 28 years, and I tried to make some rivited rings once.. after a few failed attempts to get the ends to stay parallel, I gave-up.. (not out of lack of patience, more lack of good fingers.. began suffering a BAD case of carpal-tunnel!) Right now, have been keeping a 4 year old aluminum hauberk & coif mended for local faires.. Just noted in someone else's instructable on pop-top tab maille, I've still got the same duck-bill pliers from 11 years ago, when I finished my 1st hauberk. (made from recycled coat hangers.. I kept running out of hangars?!?!?!) My method for softening the metal, was similar.. I modified a Coleman camp stove to burn hotter, and using Propane, to anneal the metal... I later stepped back in time, taking a cast-iron pot, filling it with rings, putting a few pieces of paraffin wax (about 1/4 a slab from a box of 4), and a little gasoline to get it started, sitting on the same stove to keep it going. (nothing says psycho, like a blazing cauldron full of metal rings!) Alas, age, time constraints with my job (school bus driver), and a weak back told me to stop using the steel rings (especially when the last one weighed 95Lbs!) and I started looking to the aluminum. (quite a few spools of Fy-Shock 14-guage)..
SacredDemon says: Nov 5, 2012. 8:12 AM
Quick question, how would it affect the strength of the rings if you only flattened the overlapping part? Now i know that would take more time, but would it be stronger or weaker?
Gelfling6 says: Mar 11, 2013. 3:36 PM
Usually, that is the only party that gets flattened.. The weak point, would be right at the rivot, though.. Because you have already weakened it by flattening the ends, then creating a fault above & below >|o|< with the hole through.. Now, mind you, the idea is to make the maille less likely to fall apart or tear, like butted, but now, enough force to strike, would cause the links to tear right at the hole through.. I like the design, but round rivots? I seem to remember the rivots were actually triangular. /\ , cut from a strip, (/\/\/\/\/\) but inserted/peened the same method. the actual rivot would be a little longer width.. =,.. I learned this back when I started tinkering with chain.. Now, I stick strictly to costume quality.. (aluminum.. Lighter, butted, easier to fix, far easier to keep clean.) The last steel one I made, was killing my back after 9 hours straight... (I was 45 at the time. I'm 49 now. yeah, I'm getting old...)
moe88 says: May 2, 2012. 6:16 PM
hello armourkris, have you had any problems with the whitney 1/16 punch braking while punching the ring?
armourkris (author) says: May 2, 2012. 11:05 PM
I went through 4 punches before i decided to just buy pre made rings. Of those 4 punches only 1 of them broke, the other 3 just wore out
moe88 says: May 3, 2012. 12:12 AM
I'm on my 3rd punch now, the last two broke after a couple of rings, i'm going to start annealing the rings again before i punch them. By the way where do you buy the pre made rings?
armourkris (author) says: May 4, 2012. 2:32 PM
I got my rings from Ice Falcon Armoury, Kult of Athena and Historic Enterprises also carry them though.
moe88 says: Apr 18, 2012. 8:46 PM
Hello, i have the same knock off Whitney punch as yours but it does not include the 1/16 punch and die. where did you get the 1/16 punch and die set?
love your tutorials
thanks
armourkris (author) says: Apr 19, 2012. 11:04 AM
I went to the roper whitney website, i think it was roperwhitney.com and ordered it from them, i nded up gwtting 3 sets of punches and dies for $33 .
moe88 says: Apr 19, 2012. 3:34 PM
Ok thank you
seabee890 says: Feb 19, 2011. 11:26 AM
If you can find a bar with a slot in it, or grind one into the bar that you want to use. you can use a dremel tool to cut a bunch of rings faster. I undrstand wanting to do this some- what old-school (can't remember where to put the damn dashes) however, the sheer volume of rings needed to complete any project might turn some people to the amazing art of mail working, good luck i am looking forward to see what readers create. ( and you also)
armourkris (author) says: Feb 21, 2011. 1:50 PM
That's true, but it doesn't leave the overlap I need for riveting the rings and when I'm making butted maille I cut my rings with a pair of tin snips, but first i stretch the coil open. it doesn't leave as nice of a cut as a dremel and cut off disc, but it's way faster, leaves me with pre-opened rings, and 1 pair of snips has made 2 shirts and i don't know hoe many small pieces, so it's a lot cheaper than getting a new cut off wheel every couple hundred rings.
Rowen27 says: Mar 16, 2012. 12:52 AM
I know this goes back a ways but, in an old Stephen Biesty 'Cross-Sections Castle' book I had as a kid, it gave a fairly detailed description of how wedge riveted maille was made, along with diagrams of the tools used (For what was essentially a children's book, it was surprisingly comprehensive). I seem to recall that for labor saving purposes it described cutting the rings in a line the way seabea890 posited, and then performing the added step of passing them through a plate with a vaguely funnel shaped hole (similar to a draw plate) that created the overlap as they were constricted. This may be more trouble than necessary, but I thought it was worth mentioning. Great instructable!
armourkris (author) says: Mar 18, 2012. 10:50 AM
I've seen pictures of similar setups, but in the end i just opted to notch my sidecutters so that i can just clip them with the overlap built in. Glad you like the instructable
bmelton1 says: Nov 12, 2011. 4:40 PM
I do not care how long this has been here. It is absolutely fantastic.
ilovefire70 says: Jul 14, 2011. 4:23 PM
I have a question.
Where did you get the punch?
ichbinoadie says: Aug 22, 2011. 10:09 AM
If memory serves, Princess Auto is a Canadian seller. For those in the US, Harbor Freight sells a similar set. Quality control on most items is dodgy, but they've got a solid return policy. Mine hasn't given me any trouble in its several years of service (primarily punching smaller holes in 16g mild steel). Unless you'll be doing some serious and frequent punching, Roper Whitney equipment is overkill. It's great quality, but you pay for it, even used (a testament to their lasting quality).
armourkris (author) says: Jul 14, 2011. 10:53 PM
I got mine from Princess Auto, it's a Chinese knockoff of a Roper Whitney no.5 the knockoffs are pretty hit and miss. this one works great, i got another one and it doesn't work at all. f your after one I'd recommend just checking out E-bay for a used one.
mshate says: Aug 16, 2011. 2:57 PM
Beautiful crafting sir. I am currently getting my feet wet with simple galvanized wire bent into rings. I think I will use your guide when I move onto my next mail project.
Awesome work!
Pyropitcher says: Jul 10, 2011. 12:37 PM
This is insanely awesome, but I have a question. When you say "cut them with an overlap", you do this to make sure the flattened rings are wide enough in one area so the rivets can go through, correct? If so, wouldn't cutting them straight down the line, even with an overlap on the end, produce one overlapped ring and a bunch of normal ones? Can you describe how this would work to me please?
armourkris (author) says: Jul 12, 2011. 7:37 PM
yes, cutting them with the overlap ,makes sure the ends are flat enough to punch and rivet. as for getting one overlapped one and a bunch of normal ones, I dont actually cut them in a straight line, I rotate the coil about 3/16" each ring to make sure there is an overlap in every ring.
ninja of suburbia says: Jul 6, 2011. 7:32 PM
Oh just noticed something, fyi-ish, sorry for being a coner, but you are not normalizing the rings here, you are simply annealing, or softening them. I would recommend taking the patches of mail as you finish them, and then heating them and quenching them to harden the rings, and then tempering them. might be too much work for a costume, tho.
armourkris (author) says: Jul 7, 2011. 4:12 PM
Ahh, but I am normalizing them, to anneal them I would need to cool them slowly by burying them in sand or vermiculite, or tossing them in a kiln or something similar, just letting steel air cool doesn't make them quite as soft as actually annealing them would.
ninja of suburbia says: Jul 7, 2011. 5:08 PM
no actually, to normalize the rings you would have to align them north-south, so that the crystals in the steel realign north-south, or normalize.
ninja of suburbia says: Apr 29, 2011. 7:15 PM
I very much like your 'ible. This is by far the most economical and concise set of instructions I have yet seen. As a blacksmith, allow me to offer some advice. Your last step before actually hooking the rings together should be to quench them, hardening the metal, but making more brittle. this is acomplished by heating the rings to a bright orange glow, then immersing them in cool water. Then, temper the metal, thus softening it to the proper consistency. this is achieved by polishing some part of the ring. (grinding, polishing, sanding, whatever, you just need a shiny surface.) then, lightly pass the blowtorch over it until you see colors in the polished metal. I would recommend doing this until you see the slightest tinge of yellow on the metal. then let it cool, and the rings will be about twice as strong. Props for the 'ible!
jimmyjames85 says: Apr 10, 2011. 12:40 PM
did you make the piston you use to flatten the ring or did you purchase it?
armourkris (author) says: Apr 16, 2011. 10:39 AM
I made it. the piston itself is a big brake caliper from something and the anvil was a block of steel i found with a convenient sized hole in it.
Aklash, The hunchback says: Dec 1, 2010. 9:15 AM
Could you make an instructable for wedge rivets? I checked and there don't seem to be any
anex says: Mar 21, 2011. 3:10 PM
With my experience in riveted mail, using wedge rivets isn't that complicated. In essence you flatten a ring (easiest to me because you have many anyway ) and flatten it nicely. Now to be honest i was taught by an experienced maker with out the use of measurements so i don't really know how flat. Then you take either a chisel and crease a line and use pliers to bend it back and forth till it breaks off or your wire cutters and cut pieces that are triangular in shape. The angle is such that when you insert the pointy end into your drifted hole it goes in about 2/3 the way. The rivet is then hammered flat in opposing directions (one side to the left and one to the right..... the resulting wedges smash together and fill the hole and extend to the out side and mash to the left and right causing a secure hold.
I understand this might be confusing but I hope this helps a bit.
armourkris (author) says: Dec 8, 2010. 6:30 PM
I tried making up tools to make wedge rivets and rings, but it failed miserably, so if your looking for how to make the rings themselvs then i cant really help there. the rivets themselvs are easy enough, just take a suitably small diameter wire, flatten it out with a hammer and then use some side cutters to clip off tiny tiny triangles. the specific size depends on your rings though, so a bit of trial and error is needed there. as for riveting them, I used the same tongs that I use for the round rings, and did evrything pretty much te same, the only difference being that I was putting tiny triangles into a slit in the ring instead of siny bits of wire into a hole in the ring. i did find that you need to be a little more carefull lining everything up with the wedge rivets though so that they mushroom out instead of folding over.
I home that helps somewhat.
ichbinoadie says: Aug 22, 2011. 10:44 AM
To add to the author's advice:
In my experience, wedge rivets made from flattened wire work best if your material is 1-2 gauges thinner than your ring wire (e.g. 17g or 18g for 16g rings). You can also clip the wedges from strips of sheet metal, but I actually found that to be more work than simply flattening a length of wire.
The only significant difference in the process is the riveting, itself. For wedge rivets, you are PIERCING (i.e. no material is actually removed) a slit, not punching/drilling a hole. The piercing drift can be a manual (like a center or pin punch) or it can be mounted in a mechanical punch. I've found masonry nails to be perfect stock for making the piercing drift - they're cheap (you WILL need multiples, whether to refine your head design or to replace broken drifts) and the steel holds up well. Some people recommend a trapezoidal head (like a fine slot-head screwdriver), but I found a pointed "bullet" shape to be more effective. Keep water handy while grinding the head - short bursts of grinding interspersed with dips in the water will help keep temper-destroying heat in check.
When setting the wedge rivets, I used a two-hole approach (easily doable with setting tongs/pliers - I just used a scrap block of steel and a flat hammer). The first hole was deeper than the rivet length, while the second was a more shallow bowl (smaller is better, in both cases, as more of the overlap is supported, but it need be at least as wide as the potion of the drift/rivet that will project through the thickness of the ring's overlap). First, the overlap of the ring was pierced, using the drift over the deeper hole. Don't overdo it, here - you want to break through the overlap, but only slightly, otherwise your slit will be too large for a reasonable rivet. A rivet was then pressed into the slit firmly (sometimes they're finicky and decide to fly away, stick to fingers, etc. so make plenty of extras!). The ring is placed back over the deep hole and the back is struck lightly with a flat-faced hammer (or the tongs are squeezed), seating the wedge firmly in the slit and leaving the back side (currently facing up) flush. The process is then repeated over the shallow bowl, which peens the now protruding tip of the wedge into a nice dome.
A bit long-winded, but hopefully helpful.
Grolm says: Jan 18, 2011. 11:57 PM
I am brand new to making chain mail and would very much like to specialize in making riveted mail, so I was wondering if you would be able to point me in the way of a sort of starter kit? My hopes are to eventually be able to make a leather/chain mail set of armor for the local Faire.
Rozarius says: Jan 20, 2011. 4:15 PM
The only starter kit I'm aware of is a German made one that runs about 100 euros plus shipping, so it's pretty damn pricey. I your interested I can try and find the URL for the site though.
I would honestly have to recommend asking some questions on the maille artisans forums, and maybe the riveted maille group on yahoo groups and see what other people are using for their set ups.
http://groups.yahoo.com/group/rivetedmaille/
http://www.mailleartisans.org/
I'm assuming you're thinking about making rings from scratch and so on, I'd personally recommend against that, start to finish it takes me about 2 minutes per ring, which isn't much, until you factor in that there is 20 or 30 thousand rings in a shirt, then you start to go a little crazy. Instead I'd consider looking into bulk ready to rivet rings from India or maybe an appropriately sized circlip then either making or buying a pair of rivet setting tongs.
Grolm says: Jan 20, 2011. 10:46 PM
Awesome thanks for the help i'll definitely start looking into it. ^^
Blacklance says: Nov 10, 2010. 10:26 PM
AWESOME! What material was the "rivet wire" made out of though? Steel or something softer?
armourkris (author) says: Nov 23, 2010. 10:42 AM
I use the same wire i made the rings from. it's the black tie wire available at most hardware stores. It's 16gauge, anealed, and kinda black and dirty, but it works great.
1-40 of 105Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
