I will walk you through the untraditional way of makeing a 100% real katana
The Quality depends upon you!
:DISCLAIMER:
I AM NOT RESPONSIBLE FOR ANY MISUSE OR INJURY CAUSED AND OR INFLUENCED BY THIS INSTRUCTABLE.
making swords in some countries is illegal without an arms license, and you can get fined and possibly charged for wielding a weapon if someone sees you in public with this
Remove these ads by
Signing UpStep 1Tools and Materials
Two vice grips, you can probably get by with one pair and a friend.
Pliers with cutting edge
Carpenters hammer
One handed sledge hammer
Power drill with a drill bit(s) as wide as the nails and dowel rod you have.
Vice with anvil on the back
Anvil if you don't have a vice with one.
Large sledge hammer if you don't have the two above.
Power grinder or belt grinder
Sharpening stone
Materials:
You can get great steel deals at www.admiralsteel.com
20 gauge sheet metal for Tsuba(Guard) ,habaki (blade collar) ,and for the pommel witch I have not figured out how to make.
1/4 inch by 1 inch wood for handle
Steel pictured in thumbnail 5.
Flat and wide shoe laces black are best but you can use any color.
if you try it you gotta msg me so i can check how you did it :D
The curve comes from a special trick during heat treatment insulating the backbone of the blade with a clay charcoal powder mix. and keeping the blade more lightly insulated. Heating the blade up to critical temperature evenly and submerging it evenly and quickly in water.
I get my curve simply during the process of putting the edge into the blade I only lightly straiten the blade so eventually it's going to curve.
The way I made mine is, I took a large chunk of cast iron and cut out what i wanted and then fine tuned the shape.
if you don't need too much extra weight use the first method if possible.
http://www.youtube.com/playlist?list=PL44E66FD76428D65D That link will help big time with the handle and fittings.
For one it makes things look nicer, it helps keep the hardware snug, it secures the blade into the sheath, and also helps match up the blade with the handle.
afterwards place it in a bed of ash, leave it overnight.
In Tamahagane each of the individual steel layers are first folded repeatedly to purify the steel, and raise the carbon content; a side effect of which is providing the ability to be honed to only a few atoms thickness. Different steels are then selected for their relative hardness, color, and spring. Then chosen steels are arranged or layered in a pattern based on the intended use, and welded together prior to forging. In a final step, varying layers of clay are applied to the back of the blade prior to quenching, to introduce variable hardening.
On the positive side, this is a pretty good instruct for beginners, and I applaud your ventures into the world of bladesmithing. Keep it up. I recommend you take up Kobuse or even Gomai in future blades. Both are relatively easy, and will dramatically improve the quality of the finished product.
I'm pretty-sure I said the untraditional way, haha.
I'm still polishing my second sword but I'd say it came out like 100x better than this one. I'll still need to heat treat it then re polish it, it takes a long time because i don't have the proper polishing supplies. I have a very low grit grinding stone but the sword grinds through it haha and the one that actually works is around 1000 grit so i cant do the polishing job very quickly, I'm thinking about buying a diamond hone block.
Be very conscious about creating large dips and dings in your blade they'll take quite a lot more effort to grind out than it will take to just go slow.
