Step 5Pickets 2
Cut a spacer block to your desired picket spacing (we went with 1-1/4") and put that against the picket you just mounted. Chock the next picket against the other side of the spacer block, pin, plumb, screw, and repeat.
For a more finished look, the students suggested we use the pickets we cut off the edges of the signs -- the ones with rounded corners -- to set off each eight-foot section. We set the four edge pickets, then worked towards the center of each eight-foot section, ensuring that the fence looked symmetrical if our spacing ended up a little off between the last two pickets.
When you're done, a quick pressure wash will brighten 'er up.
Our fence adds a bold color to the campus by day, and a ghostly reflectivity at night. The aluminum will last forever, and the pressure-treated lumber should last a decade at least.
Sorry for rambling on so much, my inner capitalist just went into overdrive!
