Step 8Stirring and cooling
I also recommend gloves, especially for the mixing hand, and especially in the summer. This is going to get HOT, and you need some protection. Plus the gloves come in handy when dumping out the super-hot bowl.
You will also need to cool the coffee when you finish. There are tons of ways to do this, from carefully hitting them with a slight mist in a very controlled environment (way beyond me) to just setting them on a cookie sheet outside in the winter. When I first started, I would dump the hot beans into a metal colander (did I mention it was metal?) and flip them around a lot until they were cool enough to touch. Then I would spread them on a cookie sheet to cool more while I roasted another batch. A friend actually has a wicker harvesting/chaff sorting thing that is used for rice harvesting; he puts the beans in and flips them in the air till they cool. Nowadays I use the contraption in the photo, which is a metal screen (did I mention metal? That's pertinent!) stapled to the bottom of a 2x4 frame, with small cross bracing under that in the corners. I put that on a box fan which I have elevated off the ground, then blow air up through the beans. It cools very fast.
Add Comment
