Roast Your Own Coffee With a Popcorn Popper
20,715
88
13
Published
Introduction: Roast Your Own Coffee With a Popcorn Popper
About: I like to make things for the internets. I also sell a pretty cool calendar at supamoto.co. You'll like it.
Enjoy delicious coffee with beans that you've roasted all by yourself. All you need is the right kind of cheap popcorn popper and some raw beans. It's really easy and so totally worth it.
If you grind your own beans at home and look forward to that first hit of caffeine in the morning, then this is for you. With just a bit of effort you'll be enjoying it so much more.
Warning: doing this and getting good at it has the potential to turn you into a coffee snob who complains that coffee shops are burning their beans. Just keep it to yourself because few other people will care, OK?
Step 1: What You Need - the Basics
The core element here is the air popcorn popper. Mine is the Toastess TCP-713, but there are many others that work as well. The key is to get one that has its air vents on the side of the main chamber and a solid bottom. There's more info about that here and here.
If you're willing to trek through some thrift stores you might be able to find one of these for $5 or so. Otherwise, it's not too bad to get a new one for under $30.
I got the raw beans from Sweet Maria's in Oakland. They offer lots of different beans for $6-$8 a pound. I'd recommend getting the sampler which can get you 8 pounds for $40 or $5 each.
The last part you'll need is a couple of metal bowls or, even better, colanders.These will be used to catch the chaff and cool off the beans.
Step 2: What You Need - a Little Fancier
If you want to have more of an insight into the process you can install a thermometer into the lid. Drill a hole into the top, insert a flattened tee nut, and insert the thermometer.
For the thermometer you'll want one that can go up to at least 450, but 500 would be even better.
Step 3: Let's Go!
Enough chitchat, let's roast some coffee!
Fill the popper up to the max fill line with the raw beans and turn it on. That's it your beans are now heating up and moving in circles.
After a couple minutes small pieces of chaff will be coming off of the beans. If this doesn't bother you (maybe you have a sawdust floor?), then just watch it fly. Or you can be like most people and catch it with one of your bowls.
After that you'll hear a cracking sound, almost like popcorn popping. After this has happened you now have roasted coffee. How much longer you leave it in for determines just how roasted it gets. Here's the scale of roasts:
City (426F)
City+ (435F)
Full City (444F)
Full City + (454F - second crack happening)
Vienna (465F)
French Roast (474F)
Fully carbonized (486F)
Imminent fire (497F)
After doing this for a while I've been happiest with the City+ level of roasting. The flavors stand out and you can really tell the differences between beans. You can also see that the popular French Roast is essentially the last stop before death. A lot of the flavors are gone and it's very bitter.
Back to the roasting! When you're ready to pull the beans, turn off the popper, carefully take off the plastic lid (it's hot!) and pour the beans into the bowl or colander. Now shake the beans around and around to cool them off as quickly as you can as they're still roasting.
Step 4: Enjoy
Now you have roasted coffee. Don't get too excited and grind right now, though. The beans will offgas CO2 for a little while. Let them sit in a lightly closed container for 12 hours and then seal in an airtight container. I like using old jam jars.
Grind the beans after 24 hours or so. They're good for about 5 days. Since you can always roast just a little more this is a great way to enjoy fresh coffee even if you buy several pounds of raw coffee at a time. Raw coffee is good for 6-12 months.
A big, big thanks to Sweet Maria's for almost all the information in here as well as being an excellent source of beans.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    13 Comments
    Do you by chance remember where you got your thermometer? My supplies arrived today so I will be trying this tonight, in hopes of having some fresh homemade coffee this weekend.
    I've been using this one. If you have the rest of the supplies, you can go by the sound. Also, if you do have a thermometer and the temp isn't getting high enough, replace the plastic top with a piece of wood to cover it and keep more heat in.
    I roasted my first batch last night using sound. I quit roasting it just after the first crack (so a city roast?) I like lighter roasted coffee that let the beans shine through. Ill be trying it Saturday morning, hoping its good. Thanks for the instructable.
    Great instructable, I'm a coffee addicted lover and I will definitly try this. Now I'm thinking, can this method be used to roast other grains and beans to make delicious snacks?? humm
    excellent ible, oh fungus the great!
    that's the way i roast my beans too. same popper as well. lately, however, i'm thinking of lining the plastic container's roof with foil (ripping thru slots with a knife) because it tends to melt over time. thanks again for your detailed work here!
    While I read about home roasting before, your instructable really sparked my interest and this morning I had my first cup of home roasted coffee! So, a tip of the hat to you Sir!
    Glad to hear it! This has long been on my to-do list so I totally understand.
    Thanks, but not really. Was just trying to put together the basic info together in a clean way. Notice all the links to Sweet Maria's? Learned a lot from them.
    That's what it's all about! Thanks for sharing!
    Cool beans! Er, yeah...
    I love coffee, must drink 5 pots a day. I don't know if I can get raw beans around here though. Probably online.
    Good 'ible.
    Try talking to a local roaster. If you drink 5 pots a day (!!!) then you can probably ask for a 20-lb bag. The more you ask for, the more likely you'll get it.
    That's not 5 pots to myself; My wife drinks it too.
    I don't believe there are any local roasters, unless stoked does their own beans.
    Alas really. I'm sure I can find it on the net.
