Roasting a Turkey in a Charcoal Grill by Phil B
Featured
A 22 inch or larger charcoal grill works very well for roasting a Thanksgiving turkey.
Advantages--
+ This gets the men out of the house and allows them to bond over adult beverages without getting in the way of the women.
+ It is like having another oven available and allows other things to be prepared in the regular oven while the turkey is cooking outside.
+ The turkey will have a delightful hint of smoke in its taste.
I regret I do not have an actual turkey cooking to include in the illustrations.
Step 1: Make Protection for the Sides of the Grill
First, I made a shielding band of sheet metal to protect the finish on the sides of the grill from the very hot coals. Whether you do this or not is your decision.
In the photo, the red loop identifies a joint between two pieces of sheet metal. You can see a couple of pop rivets. The yellow lines show the top and bottom of the side protector band of sheet metal. The white paper shows how to develop a pattern for cutting the sheet metal sections.
Remove the grates from your grill. Hold a piece of paper against the side of the kettle where the charcoal grate goes. Trace the outline of the ledge that supports the charcoal grate to get the right curve. Draw a curved line parallel to this one about 3 1/2 or 4 inches away from this one. Use this as a pattern to cut sheet metal sections. Fit these sections to the inside of your grill and mark them for alignment. Remove these sections from the grill. Drill holes and fasten the sections together with pop rivets. When finished you will have a sheet metal band that fits the inside of your grill just above the charcoal grate.
NDaussie1 says: Jan 22, 2012. 11:24 AM
A turkey on the Weber is just in my opionion the best way to cook Thanksgiving or Christmas Dinner. I live in North Dakota and it is my ritual to cook even in the coldest weather.
The main difference is I use a foil pan with water in between the charcoal (indirect heat method). And I do leave the upper grate on the grill. (I use the type I can add more charcoal on ether side of the grate without lifting out the enter grate). A turkey with a pop up timer is really helpful.
Cooking time about 11 min / lb unstuffed, 14 min /lb stuffed.
A great treat is if you have some apple twigs, soak them in water for about an hour before cooking then add them to the beginning. Umm Goood!
nrkey4ever says: Sep 7, 2010. 3:39 PM
What is this 'chimney'? Is it a tool bought in the barbecue section of the hardware store? I've never encountered one before, I just light the charcoal directly in the grill.
Phil B (author) says: Sep 7, 2010. 5:31 PM
Over the years I have lit charcoal by every means known to mankind, and have settled on a chimney as the best and only way to do it. There is no lighter fluid smell or taste. The coals are flaming red more quickly than any other method I have used. Only one match is needed. You can get chimneys in barbeque sections of hardware-type stores. You can also make your own from some wire and a piece of stove pipe or a large can. There are even some Instructables on making these. A handle that stays cool to the touch is essential. The cutaway graphic in step 3 is a pretty good depiction.
pdagrizley says: Mar 30, 2011. 6:27 PM
I just use an electric charcoal starter, though its not as fast its more convenient
Phil B (author) says: Mar 30, 2011. 7:33 PM
Borrow someone's chimney sometime and try it. If you have not already tried a chimney, I think you will be surprised at how very well it works.
pdagrizley says: Apr 4, 2011. 4:40 PM
Wow I tried one on the weekend, Its so much faster I think ill buy one
Phil B (author) says: Apr 4, 2011. 5:27 PM
It scares me when people like something I suggested. I am glad you like it. I really do, too. ;-)
dpolson says: Nov 13, 2011. 7:48 PM
I am the grill master in my house and I swear by my chimney. And this tutorial is what I was looking for. Hubby wants grilled turkey this year and I love grilling!
Phil B (author) says: Nov 18, 2011. 6:28 PM
Thanks. Allow plenty of time for unexpected disasters, like cold ambient temperatures or a strong cold wind. Those will slow your cooking time. Another problem happens when the fire gets too low and it takes too much time to gain a good cooking temperature again. It should work out well for you. Please let us know how it was for you.
dpolson says: Nov 19, 2011. 6:56 AM
Thanks for the tips. I will make sure to keep a close watch on it. Being that I live in the midwest it is going to be a bit chilly and although I am a year round griller (I even do Christmas dinner on the grill) like I said, I never did a turkey. I may even do it beer can style like a commenter below said. I did it that way in the oven last year and it was a hit. I'm very excited about this and will tell you how it turned out!
Phil B (author) says: Nov 19, 2011. 8:15 AM
The one possible problem with beer can style is that I think you need to turn the turkey so the neck end is up. There may not be enough clearance under your lid. Also, it will be more difficult to place a meat thermometer in the breast and read it through the vent holes. But, you could depend on a pop-up doneness button or lift the lid periodically when you are near to finished. You can always set up a protective windbreak on the windward side of the grill to reduce the effects of any wind. Maybe you will have a calm day. When we wanted to eat around noon, I started the fire around 7 AM. I will be glad to hear how it works for you.
dpolson says: Nov 19, 2011. 2:54 PM
last year when I did beer can turkey in the oven, instead of opening the top of the can I popped a hole in the side so I could still lay the turkey down. It still had the same effect, just a little different setup. With the onions and whatnot I had shoved in there I was able to prop the can in place. But I guess I'll play that by ear. I work until midnight the day before Thanksgiving so I don't know how in the mood to play with fire I'll be at 7 am. But yea I will start it early.
Phil B (author) says: Nov 19, 2011. 6:46 PM
It sounds like you have all of the bases covered. I figure there are windows of about 45 minutes when you might be able to schedule a nap before anyone arrives.
dpolson says: Nov 29, 2011. 10:55 AM
Phil, oh my goodness - my turkey was amazing!!! It was juicy and delicious, evenly cooked and mouth wateringly good. I used some apple and some hickory chips (alternated as I added coals) and it gave it the perfect smoke flavor. I think I have found my new favorite way to really impress at Thanksgiving. It was more labor intensive than throwing it in the oven but DEFINATELY worth it. I keep thinking about all the other meats I want to cook like this. Thanks for giving me the knowledge and confidence to pull this off!
Phil B (author) says: Nov 29, 2011. 1:59 PM
Thank you for the report. I am very pleased it worked well for you. I trust you also used the beer can.
I have had some things vary in the cooking procedure, but the results have always been very good.
Phil B (author) says: Nov 21, 2011. 8:21 AM
I cooked a 10 pound turkey breast on this grill yesterday afternoon. Outdoor temperatures were around 40 degrees F. with winds of about 7 mph. My wife applied a spice rub and wrapped the bird in aluminum foil. The turkey had a smaller footprint in the grill than usual. There was more room than usual for coals. I was busy with a couple of other things and could not give it my full attention. The fire produced more heat than usual and the candy thermometer in the upper vent holes registered well beyond its top end of 400 degrees. After about two hours I choked off the vents and the temperature slowly dropped to around 380 degrees F. I expected another hour or more of cooking time and opened the aluminum foil so the smoke could flavor the meat. I inserted the probe for a remote temperature indicator my daughter gave me. To my surprise the turkey was finished cooking in only a little over two hours. The meat was just right when we began to eat.
bl0rq says: Nov 19, 2011. 6:31 PM
This is a pretty bad method. For starters, 185 is about 22 deg too high for the meat. Having the bird that close to the coals will really mess up the cooking evenness. If you dont have the right equipment for the job, just use the oven. If you want to do it right, get a Big Green Egg and use something more like http://www.nakedwhiz.com/madmaxturkey.htm
Phil B (author) says: Nov 19, 2011. 7:27 PM
Well, I have done what I described many times over quite a few years and the meat was always evenly cooked, but not overcooked. But, suit yourself.
erothman2 says: Nov 18, 2011. 3:18 PM
I love using a chimney when I'm lighting charcoal. When I was a kid, my dad made one out of a big coffee can, with vent holes around the bottom- made with a church key? Tin snips?- and a wire bail handle. If you don't want to pay the $20, you can make it, but if you have the $20 it will be a lot easier to use if you buy one.
Phil B (author) says: Nov 18, 2011. 6:29 PM
There are some Instructables on making your own chimney from a large can. I always thought ours would rust or burn out, and I would made a replacement, but it has endured very well. It was purchased in a store.
The Big Plugowski says: Jun 27, 2011. 4:37 PM
looks yummy..
you should try the turkey plug roaster for the grill.. that would be awesome!
nrkey4ever says: Sep 7, 2010. 3:37 PM
Clever. Very clever idea over all.
Phil B (author) says: Sep 7, 2010. 5:33 PM
Thanks. I think the basic idea was included with instructions that came with our grill. I made some adaptations with the candy and meat thermometer. I also learned some things on my own about how and when to add charcoal.
treehugger30341 says: Nov 4, 2009. 7:25 AM
I have never put my turkey that close to the charcoals.  I usually put mine on the grill itself.  I can smoke a 22lb turkey in about 3-4 hrs.
Phil B (author) says: Nov 4, 2009. 8:41 AM
Thanks for your comment.  You are doing well if you have room between the grill rack and the top cover for a 22 lb turkey.  Our kettle grill is not that large.  The tips of the wings singe a little from being close to the coals.  We could put aluminum foil over them to protect them.  It works out well to have the meat so close to the coals.  3 -4 hours is a good time.
erniesthings says: Oct 31, 2008. 1:31 PM
Nice instructable. I grilled my turkey last year, BEER CAN style. Fosters all the way.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
