Robo Mover
14,295
118
10
Posted
Introduction: Robo Mover
This motorized, remote controlled heavy-load-carrying surface helps me move heavy projects, materials and machinery around my shop.  Having thrown my back out a few times lifting things I probably should have had a helping hand with, I thought that making something like this would be a great way to repurpose a broken electric wheelchair that was no longer needed of off craigslist and save myself from grief.
After Psycho Scooter Scramble, life really wasn't ever the same.  The practicality and robustness of the electric wheelchair as a project platform is unparalleled.  I have no idea why it took me and my fellow psycho scooter scramblers so long to start messing around with electric wheelchairs.  They are simple to hack, lots of fun to use, and are really efficient and well built machines!  I am sure that this is just the beginning of fun and impractical things that we re-use the hacked electric wheelchairs for.
Hopefully this Instructable will serve more as inspiration for your own whack-job creative electric wheelchair builds rather than an actual set of directions to follow.  I can't say enough how much potential there is for re-using these amazing machines.
Step 1: Get Electric Wheelchair
Hop on Craigslist and search your area for "electric wheelchairs".
Now the wheelchair that you decide to buy will determine a lot about how easy or difficult the next couple of steps will be.  If you are looking for an adventure, buy any old wheelchair you see in your price range and saddle up for a few hours or days of troubleshooting and hacking.
If you'd like to make things a bit easier on yourself, buy a wheelchair that you can test and make sure it works.  If the wheelchair's batteries are dead or don't hold a charge, don't worry about it as that's an easy replacement.  The unit should however power on, not give any trouble codes, and drive around.  If it does these things, load it into your car and take it back to your cave.
Audrey and I purchased 4 wheelchairs in one day a few months ago and spent an average of $150  - $250 per wheelchair that met these requirements.  Some even came with fully functioning batteries!
Bring ramps for your car or truck if you can, and drive the wheelchair right inside.  It will make life easier.  Otherwise, bring a friend and do some heavy lifting.
Step 2: Triage and Possibly Replace Batteries
Once you get back to the shop you can do some more thorough testing to make sure everything is working.  If the batteries that come with the wheelchair don't hold a charge, you can easily replace them with another comparably sized 12V battery.  All the wheelchairs I have seen so far run off of 24V, which is supplied by (2) 12V batteries.
We found some old batteries that were part of a very large uninterrupted power supply from a forklift retailer in East Oakland who was selling them at a good price.  Battery prices vary wildly - do some research before pulling the trigger on replacing the wheelchair's deep cycle batteries.  Used batteries are just as good as new ones if they hold a charge.
Replacing the batteries is electrically pretty straight forward - it's a simple swap, just make sure you hook up the wires exactly as they were on the dead batteries.  The batteries are wired in series.
The batteries we replaced on this particular model were just a few inches larger than the batteries that we removed.  That's not ideal, but it's not the end of the world.  We modified the battery compartment a bit to accomodate the larger newer batteries.
Note - our replacement batteries are sealed and therefore can be turned on their side.  If you are not using a sealed battery it must remain upright.
We used plumbers strapping to lock the new batteries in place on their plywood shelf.
Step 3: Remove Chair Part
The chair part on top of the wheelchair is comfortable to sit on, but not all that great of a work surface.
Remove the chair by unscrewing the locking pins in the shaft of the bracket and pull the whole assembly off the motorized base.  I decided to reuse the bracket on the bottom of the chair as a bracket for my work surface, so I removed the bolts from the chair and isolated the chair bracket.
Step 4: Weld Bumper
Meanwhile, a friend of mine went to town on creating a metal bumper for the wheelchair so, that if it were driven into something, it wouldn't damage the chair.  This step is entirely unnecessarily unless you are planning on playing Psycho Scooter Scramble, or some other motorized apocalyptic team sport, as the bumpers were welded onto the chairs mostly so we wouldn't break our legs while riding in the chair crashing into things.
The bumpers are simply a strip of 2" x 1/8" steel flat bar welded in a loop around some 3/4" square stock.  The square stock is welded onto the steel base of each wheelchair.
Step 5: Check Level
With the replacement batteries installed, slide the bracket back into place on the wheelchair.  You will notice that it's not quite level as the chair it once supported is positioned in a reclining angle.
Step 6: Make Bracket Level
Leveling the top surface of the bracket is pretty simple.  I measured the angle that was necessary to level the top of the bracket surface and cut it on the table saw out of some scrap stock.
Step 7: Mount With Sturdy Platform
The bracket is bolted onto some 2 x 6's to form a very stable and strong work surface capable of supporting medium sized items.  A larger surface can be bolted on if necessary.
I recessed the bolt heads to retain the flat work surface.  Also went with hex bolts instead of carriage bolts because I foresaw removing these planks from time to time if I wanted to bolt on other tops to the motorized base.
Step 8: Charging
I charge the batteries from time to time with a 12V battery charger.  Some electric wheelchairs come with their own charging modules so you'd simply plug the whole chair into the wall.  This charging module on this model was malfunctioning so we ripped it out.  The clamp on style charger works just fine.  Remember to power the unit down while charging.
Each battery charges separately and the process lasts overnight.  The chair has good battery life when everything is charged and can be driven for several hours.
Step 9: Operation
I use the robo pallet like a tiny pallet jack in my shop.  It's great for moving stacks of material, boxes and heavy parts around.  If I have to paint something outside by work on it inside, it shuttles the project back and forth.  Just got back from the junk yard with a load of goodies? No problem, the robo pallet is always around to help carry supplies in from the car.
Simply pick up the controller module and operate the wheelchair while walking along side it.  The total load capabilities for the wheelchair are about what a person would weigh.  I'm sure it could take a whole lot more, but I tend to make multiple trips rather than overload the thing and risk a problem.
In the future I'd like to put a few tie down points onto the sides of the 2 x 6 work surface so that projects and supplies can be strapped down if need be.
While not toting piles of metal or heavy boxes, the robo pallet is fun to ride around on like the Silver Surfer or Michael J Fox in Teen Wolf.
There's a whole lot of potential here for the electric wheelchair platform.  I recommend it to anyone looking for an easily hackable, powerful, reliable motorized base.  Wireless control of the electric wheelchair is not easy, but definitely possible.  See steps 5 and 6 from Psycho Scooter Scramble for directions how.
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
10 Comments
yea I got two robo mowers to build... any advice
My Sweet wife, cuts the grass.always has, house related job, I can see this as fun, eye to hand control type of a game..
Just not sure want to go down this road...
Big Jake
Great idea - how do you load the stuff on it without risking the back?
I did mine ~10 years ago picking up a box of blank CDs from the floor.... its not the carrying, its the initial lift that does the damage.
This really is cheating... I mean brilliant! And I agree with you, I don't know why I didn't see it before, it's such an obvious robotic platform, one you think about it. My mother even still has my grandmother's electric wheelchair in her shed. I'm going to have to give it a real hard look. :D
That's really great.
Unfortunately, Craigslist has nothing below $400 in my area. ;(
Great job! I think with yellow and black painting, it would look very industrial :-)
Add a foot-plate over the castor wheels and you wouldn't have to walk either..
I would add 2 metal bars to the front & a foot jack - then you could slide it under a wooden pallet jack it up to the table & use it like a fork lift - never have to pick up a heavy box again.
HAHAHHHA!!! This is the best up-cycle for these scooters.
