UStepper Robot Arm
8,962
129
19
Posted
Introduction: UStepper Robot Arm
This instructable takes you through the process of building your own cool robot arm!
The Robotic Arm is developed entirely by me, the nut covers are however, from a guy on thingiverse. All STL files are avilable for you to print (for personal use - not for selling!) on our GitHub.
So let's get to it!
Step 1: Parts Needed
First you will need some parts. Besides the 3D printed parts, which I will introduce in the next section, you will need bearings, nuts and bolts. I have spent some time on reducing the number of unique items on the BOM, but there is still a few.
Bolts:
  • 1 pc. M8 x 40 mm
  • 1 pc. M8 x 70 mm
  • 4 pcs. M4 x 20 mm
  • 4 pcs. M4 x 35 mm
  • 20 pcs. M3 x 10 mm
  • 3 pcs. M3 x 16 mm
  • 10 pcs. M3 x 20 mm
  • 9 pcs. M3 x 25 mm
Nuts:
  • 21 pcs. M3
  • 8 pcs. M3 self locking
  • 8 pcs. M4 self locking
  • 2 pcs. M8 self locking
Washers:
  • 2 pcs. M8, OD: ~15.8 mm
  • 2 pcs. M4, OD: ~8.8 mm
Bearings:
  • 4 pcs. 608Z
  • 12 pcs. 624Z
Rods:
Aluminium rods, the diameter is outer diameter, they are of 1 mm material, making the inner diameter of the 15 mm rods = 13 mm. I found these rod sizes (diameters) in the local hardware store.
  • 1 pc. 15 x 200 mm
  • 1 pc. 15 x 150 mm
  • 2 pc. 6 x 170 mm
  • 1 pc. 6 x 165 mm
Additional items:
  • Super glue
  • Micro servo
  • 3 pcs. NEMA 17 stepper motor
  • 3 pcs. uStepper control boards (optional)
Tools:
  • Adjustable wrench
  • Hex Keys (if you use hex bolts like I did)
  • Philips screwdriver
Step 2: Printed Parts
Now for the 3D printed parts. First of all, I printed all of them in PLA. The infill was set to 25% for all parts, besides the three motor gears which are printed with 100% infill. The numbers on the parts will be used in the assembly instructions given in the following section. All STL files are available on our GitHub for personal use.
Step 3: Assembly
Just follow the instructions in the pictures here. The only thing to notice is that the motor gears has changed since I took these pictures. This was done to make them more robust, and get a better grip on the motor.
Step 4: Electronics
For the robot arm to run, you will need some stepper driver. I recommend uStepper, but there are plenty of other solutions out there. What I go through here is based on the uStepper setup.
The three uSteppers are connected as shown here on the diagram. One uStepper is master, receiving data through the UART and distributing this to the two slaves.
To make it easy, I used a prototype shield on the master so that I could easily connect bluetooth module, servo and slaves.
If using USB cable for communication, it is essential that it is secured properly to avoid breaking the USB on the uStepper when rotating the arm.
Step 5: Programming
Programming the arm is relatively easy, since I have already made a working sketch :) The sketch is based on a teach mode operation principle. That is, you move the robot arm around and record positions, which you then play back. The code setup is shown in the video below, and the code is found on our GitHub.
In the video, you can also see how to interface with the Robot Arm using the example code.
The code does not make closed loop movements, but this is possible with the new uStepper library, by adding the PID in setup like shown in the video:
Step 6: Final Words
That is pretty much it! All the rod lengths can be adjusted to give the robot arm a different range than that shown in this instructable.
As it is now, no inverse kinematics has been implemented, but we are working on it together with a suitable protocol between master and slaves.
More information about uStepper and the Robot Arm can be found on www.ustepper.com
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    19 Comments
    Dear respected sir, Hope you are in good health with success and happiness. I am really happy for your awesome works.
    I'm doing my project on this robot arm.
    I'm not using close loop system and using A4988 stepper motor Driver. Please could you help me to do my arduino code to control the robot?
    I will be grateful to you.
    Sorry for the late reply... You can have a look at the code on Git, and take what you need to get it working. I simply do not have the time to do custom coding for people :)
    HI,
    uStepper OPTIONAL means that I can use even other boards to control the arm, in this case I should write my own sketch right?
    Hi,
    Yes, you could use any other stepper driver solution out there, be it GRBL shields, 3D printer controllers etc.
    Of course the sketch I wrote was done for the uStepper, but the principles would be the same as long as you have feedback. If you don't have feedback, then you will have to run it open loop (like a 3D printer og GRBL machine does).
    Really nice work!! Thanks for sharing.
    I just have a question about programming. I don't understand why do you have to comment in one of the two functions (master or slave) in the loop.
    Thanks again.
    Hi!
    Thanks for the nice words. Two of the controllers are slaves and one is the master. Commenting in either of the two in the loop will configure the board as one of these. It just calls the appropriate function. Scroll up in the code, and you will see :)
    Best regards,
    Mogens
    If you wan't to buy it, kits are available at www.ustepper.com If you wan't to build it yourself, you just have to get the parts listed in the instructable. The highest cost is the stepper and drivers.
