Robot Blade Holder by Kris82
Featured
   This is a great Fathers day, Birthday present, or just some thing for you. You can also decorate it or paint it as well. I like natural finishes. So I kept this one all natural. This Robot will be able to hold your saw blades as well as your scroll saw blades. This way you don't have to sit them down some where and ruin your blades. Also this is a good way to have storage while having a piece that everyone will like and talk about.
Equipment Used:
  1) Band Saw
  2) Drill Press
  3) Hack Saw
  4) 1/4", 3/8" & 1/2" Drill bit's
Materials Needed:
  1) 4'x4'x1/2" plywood
  2) 4'x4'x1/4" plywood
  3) 4"x4"x1' lumber
  4) 1/4"x3' All thread
  5) 3/8" x1' All Thread
  6) 3/8"x3' Dowel Rod
  7) 2"x4' Dowel Rod
  8) 2"x4' Dowel Rod
  9) 6 - 1/4" Hex Nut Cap
  10) 4 - 1/4" ID Locking Washers
  11) 2 - 1/2"x1/4" ID Spacers
  12) 1 - 3/8" Hex Nut Cap
  13) 2 - 3/8"-16 x 7/16 Tee Nuts "Pronged"
  14) 1 - 2 1/2" Rope Cleat
  15) 6 - 1/4" ID Washers
  16) Wood Glue
  17) JB Weld
  18) 2 - 1" Lag Bolts
  19) 2 - #12 Finish Washers
Step 1: Cutting out the Body
   You need  to first cut out the body. The pieces that I used the 1/2" plywood, you can use 3/4" plywood. The reason I choose to use 1/2" is because I wanted more slots for blades.To do this I used a band saw to cut out the following pieces. You need to cut out 2 pieces of figure "A" from a 1/2" plywood. Next cut out 10 pieces of figure "B" from 1/2" plywood and lastly cut out 12 pieces of figure "C" from 1/4" plywood. Over all size of figure "B & C" should measure 11" by 13" Once all of the pieces are cut out next you will need to drill 3 holes through each piece in the same spot so that a piece of all thread will go straight through them all.
chobbs1957 says: Aug 7, 2012. 4:26 AM
At that size, what size blades will it hold? 5-1/2, 7-1/4, 10, 12's? I'm too lazy to figure for myself.....
moseph says: Jun 23, 2012. 11:15 AM
I don't have any circular saw blades so I don't have much use for this (although I guess the head part with the scroll saw blades could be handy) but I gotta say this is adorable and clever!
pjamestx says: Jun 21, 2012. 6:57 AM
Fantastic! I love that it combines form and function. Very clever!
zorwick says: Jun 19, 2012. 3:30 AM
This is great, I have also these small saw blades and bits...thanks for sharing :)
electfire says: Jun 15, 2012. 11:21 PM
Very cool!
Though personally I would keep the saw blades away from the robot. The only robot I would trust with such potential weapons would be the Instructables Robot... Any others might not take to kindly to living in my workspace, as there is hardly any space for them to live.
All joking aside this is such a creative way to store
those saw blades, you can never seem to find
, when you need them.
Though, I would be tempted to electrify it in some way.
(Lasers anyone?)
scoochmaroo says: Jun 16, 2012. 12:34 PM
You should definitely not trust the Instructables Robot. I can tell you first hand, he is mischievous.
electfire says: Jun 16, 2012. 3:33 PM
Mischievousness I can deal with, I myself can be very mischievous. I am more worried about the robot going all homicidal on me.
ultimut cat says: Jun 16, 2012. 3:24 PM
he looks soooooooooo menacing with those in his belly
This is awesome.
Creativeman says: Jun 15, 2012. 8:30 PM
Very clever! Good work.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
